Old 9th August 2010, 22:46   #10401  |  Link
mr.duck
quack quack
Definitely use FLAC. There's nothing else that's better while being open source and widely supported. For stereo music, file size is around 60% using FLAC compared to WAV.
mr.duck is offline
Old 11th August 2010, 21:57   #10402  |  Link
ajamils
I'm trying to rip a Blu-ray using HdBrStreamExtractor (which is a GUI for eac3to) and I'm getting the following error. I also tried ripping the same blu-ray with anotherEac3to GUI and Blu-rip and all failed with the same error. It seems like eac3to does not like extracting the audio which is in Mayan language. Any suggestion ?
15:52:07] a03 Creating file "M:\Hidef Movies\1080p\Apocalypto\1_3_audio.flac"...
[15:52:18] The "-seekToIFrames" option may work around that.
[15:52:23] v02 Waiting for DirectShow decoder thread to finish. Please wait...
[15:52:28] Error: Unfortunately the Haali Muxer cannot handle this source file.It doesn't contain enough seek/recovery points.Aborted at file posi
[15:52:28] Stream Extraction Completed
ajamils is offline
Old 11th August 2010, 22:51   #10403  |  Link
TinTime
It's nothing to do with the audio. eac3to (or specifically the haali muxer) doesn't handle some AVC streams when muxing to mkv. The Apocalypto blu-ray is one of these types.
Demux to raw AVC and then mux with mkvmerge.
TinTime is offline
Old 12th August 2010, 05:39   #10404  |  Link
Shamus76
Earlier post by madshi explains the error:
"There's a bug in the Haali Matroska Muxer which results in a total freeze when muxing some h264 movies. eac3to detects this situation and aborts processing directly before the Haali Matroska Muxer freezes. Currently there's no way to properly mux such a movie with eac3to respectively with Haali's Matroska Muxer. You can use the option "-seekToIFrames" to mux the movie in a different way. This should succeed. However, this comes at a cost: Sometimes when seeking such a movie there are very noticable image artifacts for a short time (max a few seconds). Haali knows about this problem but hasn't fixed it yet, sadly."
I used the "-seekToIFrames" option and it works fine and i haven't yet had any problems with artifacts.
Shamus76 is offline
Old 12th August 2010, 15:35   #10405  |  Link
ramicio
Banned
I have a mono (1.0) DTS-HD Master audio file I'm trying to decode and it won't work. The output is:
"The ArcSoft DTS Decoder reported an error while decoding.  Aborted file at position 262144."
Tried it directly from the m2ts file and it gave the same error, just a different position number. Eac3to shows the correct info about the file, but the decoder doesn't like it. Anything else to try here? I want lossless, I don't wan't just the core!
ramicio is offline
Old 12th August 2010, 18:48   #10406  |  Link
deathlord
Try -sonic !
deathlord is offline
Old 12th August 2010, 18:59   #10407  |  Link
ramicio
Banned
Hehe I am ripping my hair out trying to find the sonic decoder. I don't even know what to look for. I am trying to get Cineplayer HD-DVD Player 4.2 with no luck so far. And I'm sure once I do, it probably won't work.
Well I found it, and I am ripping my hair out once again trying to figure out why it won't work. It's giving a "can't find mfc71.dll" error when I run "eac3to -test" and it gets to the part where it checks the sonic decoder.
The mfc71.dll error is gone, and I found 4.3.0.169. This version is showing as installed but not working in eac3to as well. Would this have anything to do with having an x64 version of windows? I can use the sonic filter in graphedit but it makes a 16-bit file, not 24 The sonic decoder is only decoding the core of the dts file. HELP!!!
ramicio is offline
Old 13th August 2010, 12:36   #10408  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
I must be blind. Again. Please tell me how do I create six WAV files decoded from a 6ch dts source?
I always end up with one (probably 6-ch) wav file when I use "eac3to input.dts output.wav". I only get 6 intermediate wave files when I set .dts as output format to feed the dts encoder directly afterwards.
But I dont want that, because my DTS encoder is on another machine where I'd like to import those WAV's.
LeXXuz is offline
Old 13th August 2010, 12:53   #10409  |  Link
nurbs
eac3to input.dts output.wavs
nurbs is offline
Old 13th August 2010, 13:08   #10410  |  Link
LeXXuz
LeXXuz's Avatar
Ah no way! It can't be that obvious.
LeXXuz is offline
Old 13th August 2010, 14:03   #10411  |  Link
[)370|\|470!2
dentist-experimenter
[)370|\|470!2's Avatar
eac3to v3.22
command line: "D:\TRANS\eac3to3.22\eac3to.exe"  "E:\Batman.The.Dark.Knight\odds\Batman.track_4354.ac3" "D:\Batman\Batman.track_4354.flac"
TrueHD/AC3, 5.1 channels, 48kHz
(embedded: AC3, 5.1 channels, 640kbps, 48kHz)
Extracting TrueHD stream...
Decoding with libav/ffmpeg...
Encoding FLAC with libFlac...
Creating file "D:\Batman\Batman.322.track_4354.flac"...
[libav] Substream 0 parity check failed  <WARNING>
[libav] Substream 0 checksum failed  <WARNING>
[libav] Lossless check failed - expected 87, calculated 92  <WARNING>
[libav] Substream 1 parity check failed  <WARNING>
[libav] Substream 1 checksum failed  <WARNING>
[libav] Lossless check failed - expected 85, calculated 33  <WARNING>
[libav] Lossless check failed - expected fd, calculated c9  <WARNING>
[libav] End of stream indicated  <WARNING>
The original audio track has a constant bit depth of 16 bits.
Superfluous zero bytes detected, will be stripped in 2nd pass.
Starting 2nd pass...
Decoding FLAC...
Reducing depth from 24 to 16 bits...
Creating file "D:\Batman\Batman.track_4354.flac"...
The processed audio track has a constant bit depth of 16 bits.
eac3to processing took 24 minutes, 28 seconds.
Done.
Any ideas what could be wrong with the track? Oh, and inb4, I own the original disc.
20 years and ubuntu has just restored my faith in humanity ...lol
[)370|\|470!2 is offline
Old 13th August 2010, 17:49   #10412  |  Link
BatKnight
BatKnight's Avatar
Looks like a corrupted or broken track. You could try to re-rip the track, since you own the original disc. Or, better than that, you could rip the TrueHD track directly to FLAC, using eac3to.
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers
MPC Home-Cinema
madVR
LAV Filters
BatKnight is offline
Old 13th August 2010, 20:20   #10413  |  Link
[)370|\|470!2
But of course, it was the first thing I've tried to no avail.
Already done. The question is how am I to be sure if it's b0rked or not.
Old 13th August 2010, 21:19   #10414  |  Link
setarip_old
setarip_old's Avatar
@[)370|\|470!2
Post the log (Just as you did for the ripped-to-harddrive version)...
setarip_old is offline
Old 13th August 2010, 22:23   #10415  |  Link
[)370|\|470!2
Originally Posted by setarip_old View Post
@[)370|\|470!2
The log posted above actually is.
Old 13th August 2010, 23:09   #10416  |  Link
nurbs
What happens if you convert to flac without demuxing the track first?
Also, since the source file in the command line is a .ac3 I find it strange that it says the content is TrueHD. I thought the had a .thd extnsion.
nurbs is offline
Old 14th August 2010, 01:26   #10417  |  Link
[)370|\|470!2
That's brilliant. Just tell me what command line to use to achieve that.
And I thought file's being recognized by its headers, not the extension.
Old 14th August 2010, 03:36   #10418  |  Link
setarip_old
@[)370|\|470!2
This line from the log certainly doesn't indicate that the source is your original disc (as I suggested you use)...
Old 14th August 2010, 08:27   #10419  |  Link
nurbs
eac3to DiscFolder shows the playlists
eac3to DiscFolder 1) shows the tracks in the playlists
eac3to DiscFolder 1) 3:audio.flac encodes the third track in the first playlist to flac
Well that depends, doesn't it? I suspect eac3to does, but if you double click on a file with a .doc extension I wouldn't expect a media player to pop up even if the file is actually an .mp3, at least not on windows.
Anyway what software did you use to extract the audio? Did that software put the wrong extension on the file or did you do that?
nurbs is offline
Old 14th August 2010, 15:17   #10420  |  Link
[)370|\|470!2
Obviously you should learn a bit about the file assotiation per se and how it works.
Let me get this straight — you're claiming that extension is a problem there?
eac3to
