Old 29th August 2008, 20:51   #5961  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
* new option "-progressnumbers" replaces progress bar with percentage numbers
Oh yeah!!!!!!!!!!!!!!!!!!!! Thanks man for that!!!!!!!!!!!
Atak_Snajpera is offline
Old 29th August 2008, 21:02   #5962  |  Link
madshi
Thanks for the nice feedback, guys!
Originally Posted by moshmothma View Post
I noticed that program changes within an h264 stream has been addressed. What about VC-1? I still have problems processing the NIN BD.
This might be a similar problem compared to the "program mapping changes" problem. Does the problem also occur at the very end of the remuxing process for you (when you almost think it's done and successful)? And does the playlist 1) also contain multiple m2ts parts of which the last one is very small? In that case please upload that last m2ts file for me and another 20MB from any of the other m2ts parts of the playlist 1). Then I can probably fix it. Thanks!
madshi is offline
Old 29th August 2008, 22:39   #5963  |  Link
itsancho
hi, madshi and 10x again 4 the great tool, btw is this a bug or...
MkvToolnix (2.2.0.0, 2008-08-19) is up to date
There's a new beta version (2.2.0.0, 2008-08-21) available
itsancho is offline
Old 29th August 2008, 22:50   #5964  |  Link
rica
What is that and why is here?
rica is offline
Old 29th August 2008, 23:23   #5965  |  Link
Snowknight26
rica, you really need to stop posting useless junk. :\
Snowknight26 is offline
Old 29th August 2008, 23:44   #5966  |  Link
rica
OK, i'll ask to you next time, you tell me me what to post
rica is offline
Old 30th August 2008, 05:36   #5967  |  Link
Snowknight26
I can only guess that there isn't any data in the subtitle track.
Edit: Something about that vob file is strange, though. eac3to cannot demux video/audio tracks for whatever reason. Will look into that. But the subtitle track seems to be really empty. E.g. EvoDemux doesn't even list it.
Disregard that. When joining the VOB, I forgot to include the very 1st VOB that was only 8 KB. Didn't think it'd make a difference; guess I was wrong.
Old 30th August 2008, 07:41   #5968  |  Link
madshi
Check "mkvmerge --version". It reports 19th of August. That's the cause of the problem.
madshi is offline
Old 30th August 2008, 08:15   #5969  |  Link
Gleb Egorych
madshi, thank you vey much for your GREAT tool! It's indeed awesome, man.
Gleb Egorych is offline
Old 30th August 2008, 09:16   #5970  |  Link
shambles
many thanks for the new release
it seems to have broken one thing though.. any pcm blu-ray i try spits out this
[a04] Reading RAW/PCM...
[a04] The sample sorter received a non-supported data format.
Aborted at file position 16384.
also, any eta on the 24->24/1.001fps conversion?
shambles is offline
Old 30th August 2008, 09:51   #5971  |  Link
Audionut
Hi, I got this problem.
ArcSoft DTS Decoder (1.0.2.2) is not working correctly
http://www.arcsoft.com/products/totalmediatheatre
Here's the xml from graphstudio.
?xml version="1.0" encoding="utf-8"?>
<graph name="Unnamed Graph">
    <filter name="K:\movies\Hitman.ts" clsid="{55DA30FC-F16B-49FC-BAA5-AE59FC65F82D}">
        <ifilesourcefilter source="K:\movies\Hitman.ts"/>
    </filter>
    <filter name="ArcSoft Audio Decoder HD" clsid="{1A89085B-B654-4ED8-8831-5AC629A05FF5}"/>
    <filter name="ffdshow Video Decoder" clsid="{04FE9017-F873-410E-871E-AB91661A4EF7}"/>
    <filter name="AC3Filter" clsid="{A753A1EC-973E-4718-AF8E-A3F554D45C44}"/>
    <filter name="Video Renderer" clsid="{B87BEB7B-8D29-423F-AE4D-6582C10175AC}"/>
    <filter name="Default DirectSound Device" clsid="{79376820-07D0-11CF-A24D-0020AFD79767}"/>
</graph>
Audionut is offline
Old 30th August 2008, 10:17   #5972  |  Link
madshi
I can't reproduce this problem. Can I see the full log including the exact command line, please?
I don't give etas.
You may need to add the ArcSoft folder to the environment path. Search this thread for "environment" to find more details.
madshi is offline
Old 30th August 2008, 11:09   #5973  |  Link
shambles
tried encoding/extracting pcm now and it works.. seems the error only happens when using '-check'
C:\Program Files\eac3to>eac3to test.m2ts -check
M2TS, 1 video track, 1 audio track, 0:56:16
1: h264/AVC, 1080p24 /1.001 (16:9)
2: RAW/PCM, English, 5.1 channels, 16 bits, 48khz, -41ms
[v01] Extracting video track number 1...
[a02] Extracting audio track number 2...
[a02] Reading RAW/PCM...
[a02] The sample sorter received a non-supported data format.
shambles is offline
Old 30th August 2008, 11:10   #5974  |  Link
Audionut
No go. Triple checked to make sure I had it right, and rebooted.
Audionut is offline
Old 30th August 2008, 11:19   #5975  |  Link
madshi
Ok, thanks. Will be fixed in the next build.
Well, then I don't know why it doesn't work. Does it work in GraphEdit? Have you installed the latest ArcSoft update(s)?
madshi is offline
Old 30th August 2008, 12:11   #5976  |  Link
Audionut
It would connect and play, but no audio out.
Re-install seems to have fixed it. Working now.
Audionut is offline
Old 30th August 2008, 12:19   #5977  |  Link
hdpete
TrueHD tracks on HD DVD - Please can someone tell me if it's possible to remove the TrueHD audio from an HD DVD unconverted to enable me to mux it using tsMuxer with a 'fixed' VC1 evo file to make a Blu-Ray. I don't want the TrueHD converted to flac, as I'll be burning to a BD-R for playback via an HD amp.
hdpete is offline
Old 30th August 2008, 13:21   #5978  |  Link
Fer
Great, thank you Madshi.
Fer is offline
Old 30th August 2008, 14:18   #5979  |  Link
Thunderbolt8
what exactly was meant with that 2.57 fix that 16-bit truehd track were incorrectly decoded to 24-bit? there didnt seem to be any increase in filesize for the FLAC track at least, the files had the same sizes as typical 16-bit flac tracks for me. do I still have to redo all those thruehd -> flac tracks done with 2.57?
Thunderbolt8 is offline
Old 30th August 2008, 14:50   #5980  |  Link
madshi
tsMuxeR doesn't properly support TrueHD muxing, as far as I've heard.
The FLAC files are alright, they are just marked as 24bit and decode to 24bit, with the lower 8bit all zeroed out. Not a problem at all. The files are not bigger than 16bit FLAC files nor do they sound different. So you don't really have to redo them. It's just not "nice" that they are flagged as 24bit, although only 16bit are filled with data. But it's just a cosmetic issue.
madshi is offline
eac3to
