Old 13th July 2017, 19:50   #15001  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
I wish I could but MKVToolnix recognizes .w64 as AVC
Old 13th July 2017, 19:54   #15002  |  Link
byteshare
ByteShare
byteshare's Avatar
Is there a possibility to add the option while batch importing to select "No Audio" or something so we can avoid dealing with the audio all together if we know there will be issues and/or don't want. Import would be much faster...I guess same for subs too.
Thoughts?
Old 13th July 2017, 20:40   #15003  |  Link
Danette
PCM/WAV Problem
It doesn’t look like you demuxed the source file into separate video and audio files, since I see you are adding the mkv container into MKVMerge, unless you stripped out the audio from that mkv. In any case, can’t you convert that audio file into a basic pcm/wav file?
For my tests, what I did was to demux two source files into separate video and audio files (I used source files that contained ac3 and aac audio files). I then converted the ac3 and aac files into pcm/wav files, using LameXP, and then added the video stream and pcm/wav stream into MKVMerge to create the mkv files containing the pcm/wav streams. I then took those two mkv test files and put them into RipBot264 and get the [NO AUDIO] problem each time.
Danette is offline   Reply With Quote
Old 14th July 2017, 11:10   #15004  |  Link
slalom
slalom's Avatar
Originally Posted by nekrosoft13 View Post
there is no specific reason for specific size, when ever I tried CQ even picking the same number there is always that uncertainly what size file I end up with, sometimes compression seems crazy good, but sometimes the file ends huge for no apparent reason.
You can use 1-pass with specific size
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 15th July 2017, 17:17   #15005  |  Link
slalom
slalom's Avatar
@Atak, regarding the subtitles
Can you add a field, MKVToolnix calls it "Track name" for a short description to enter, for example "commentary" or anything?
Old 15th July 2017, 22:36   #15006  |  Link
byteshare
ByteShare
byteshare's Avatar
I've been having to mux it in myself after the encode since it can't handle all of the audio video tracks sometimes.
Old 16th July 2017, 17:56   #15007  |  Link
slalom
slalom's Avatar
I'm talking about the subtitles
Old 17th July 2017, 20:57   #15008  |  Link
byteshare
ByteShare
byteshare's Avatar
How hard would it be to get SSIM scores into the media info from the encoding log (automatically)?
Old 20th July 2017, 21:55   #15009  |  Link
klopsknoedel
I'm having some trouble with the MDegrain2 - Plugin. Seems like avisynth can't find this plugin even the path is correct. Someone else facing this issue or know how to fix it?
klopsknoedel is offline   Reply With Quote
Old 22nd July 2017, 17:06   #15010  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by klopsknoedel View Post
Since no one else has responded. I'd try reinstalling your AVISynth (start with r1825MT before doing any of the newer versions) and then reinstall: Visual C++ Redistributable for Visual Studio 2015
You could also try running the AVISynth Script you get from the job in avspmod to see if it gives you any more information (but it might not).
Old 23rd July 2017, 15:17   #15011  |  Link
klopsknoedel
Hi byteshare. Reinstalling VC (32/64 - bit) did the trick. Thanks a lot for your reply.
Old 24th July 2017, 13:18   #15012  |  Link
burt123
burt123's Avatar
Atak, Just got the latest auto update, and you've finally gotten around to adding some more DE Servers, "we" now have 16 server's
2 rows of 8.....
Thankyou, thankyou, thankyou !!!!
burt123 is offline   Reply With Quote
Old 24th July 2017, 16:44   #15013  |  Link
byteshare
ByteShare
byteshare's Avatar
2 rows of 8.....
It is awesome!
Old 26th July 2017, 03:45   #15014  |  Link
burt123
burt123's Avatar
Atak,
Have just used the newest build with the extra servers (thanks again), for the first time, and I have a suggestion.
Would it be possible to show just one (1) DE Server icon in the Taskbar, with a small number (like the Ripbot icon shows how many jobs are queued), instead of an icon for each server, it just crowds the Taskbar a bit, when you have then all enabled.
Another thing I have noticed is that the auto shutdown isn't working on the other pc's that are processing.
I'm pretty sure I have everything enabled to do that, but the settings seemed to have changed a little, since the extra servers were introduced. (they don't appear in the .ini file, where the original 10 are.....)
Old 3rd August 2017, 03:31   #15015  |  Link
Viper714
Failed to Load OpenCL
So, I have three machines that I am encoding my Blu-rays. I updated all three to version 1.20 of RipBot today. While encoding my movies two of my machines are using OpenCL
My third machine which is the most powerful (Nvidia 1070) shows failed to load OpenCL.
Reading through thread I ran GPU Caps Viewer and all seems fine
Appreciate any help.
Viper714 is offline   Reply With Quote
Old 3rd August 2017, 06:48   #15016  |  Link
Wishbringer
Silent Reader
Wishbringer's Avatar
Is GTX1070 selected in Ripbot-Settings, or did you copy settings from other machines?
Wishbringer is offline   Reply With Quote
Old 3rd August 2017, 11:20   #15017  |  Link
Atak_Snajpera
Run
OpenCLinfo.exe /gpu
on AMD system and nVidia system and show me what you get.
I suspect that --opencl-device index is wrong for nVidia card.
I will check that.
Old 3rd August 2017, 14:16   #15018  |  Link
Danette
Suggestion For Improvement
Please consider adding the capability of dealing with PCM/WAV audio in the next build.
Old 3rd August 2017, 20:01   #15019  |  Link
Viper714
Run
OpenCLinfo.exe /gpu
Snajpera thanks for the quick response. Here is the results:
AMD machine that works OK:
Platform 0.
    Name             : AMD Accelerated Parallel Processing
    Vendor           : Advanced Micro Devices, Inc.
    Version          : OpenCL 2.0 AMD-APP (2348.3)
    Profile          : FULL_PROFILE
    Extensions       : cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices
0.0 Device name      : Hawaii
    Hardware version : OpenCL 1.2 AMD-APP (2348.3)
    Software version : 2348.3
    OpenCL C version : OpenCL C 1.2
    Compute units    : 44
Nvidia Machine that works OK
Platform 0.
    Vendor           : NVIDIA Corporation
    Version          : OpenCL 1.2 CUDA 8.0.0
    Extensions       : cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer
Platform 1.
    Vendor           : Intel(R) Corporation
    Extensions       : cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir
0.0 Device name      : GeForce GTX 660
    Hardware version : OpenCL 1.2 CUDA
    Software version : 382.05
    Compute units    : 6
1.0 Device name      : Intel(R) HD Graphics 4600
    Software version : 20.19.15.4531
    Compute units    : 20
Nvidia Machine that fails to load OpenCL
Platform 0.
0.0 Device name      : GeForce GTX 1070
    Software version : 382.33
    Compute units    : 15
Hope that helps
Old 3rd August 2017, 21:13   #15020  |  Link
Atak_Snajpera
It has to be something else because all devices are sitting at index 0. When it says "Failed to load OpenCL" it most likely mean that x264 was unable to load opencl.dll from your HDD/SDD.
Check this and maybe it will help
https://answers.microsoft.com/en-us/...d-bc827010c321
