13th July 2008, 17:26 | #1983 | Link |
Thanks on the latest update, but I'm unable to grab it either the .7z file or the automatic install from Ajax_Undone. Would it be possibly to upload the files to a different file sharing site? MediaFire recently has been causing a lot or problems when I've been trying to use it, don't know if anyone else has the same problems.
13th July 2008, 17:38 | #1984 | Link |
I haven't been able to find anything in the post, so forgive me if this has already been addressed. I want to take one of my bluray disc and back it up to a dvd9. I know the process on how to do it, but with the newer versions of ripbot when I select the source file it recognizes it as a bluray disc and starts to convert the movie to a mkv automatically. Is there a way around this besides moving the source out of the directory?
13th July 2008, 21:04 | #1985 | Link |
The easiest way to rip Blu-ray disc is
1) install AnyDVD HD (allows decrypting on fly) 2) Open file in RipBot264 directly from disc
13th July 2008, 22:50 | #1986 | Link | |
I dont care so should you
My Installer's || |
14th July 2008, 10:15 | #1988 | Link | |
One might have a number of jobs to add to the queue, it would be good if we can start the encoding as soon as the first job is in the queue while we can take our time to configure the next job. It will definitely save a some time. Right now, after the encoding has started, there is no turning back for the user. So let the user modify /edit /delete queuing jobs after the encoding has started would be very nice. Last edited by dchao; 14th July 2008 at 11:19. |
14th July 2008, 16:51 | #1990 | Link |
1.10.3 & 1.10.4 Troubleshooting when playing the AVCHD blu-ray conversion in ps3 and blu-ray players. Audio track, sounds goes on/off tested with 2 different blu-ray players, and 1 ps3.
Probably something wrong with the conversion? And one question, i have an movie (die hard 1) the audio track are too low for the sound. I want to modifiy the audio file to accurate the sound. Boost the sound output, did we can have an option with ripbot to to that? Thanks.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 14th July 2008 at 16:53. |
14th July 2008, 16:58 | #1991 | Link | |
Enjoy!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 14th July 2008 at 17:00. |
14th July 2008, 17:12 | #1992 | Link | |
15th July 2008, 03:50 | #1994 | Link |
Ok, here is my first try for the NeroAAC and mono wrapper. Not beautiful, but it works for me
You have to rename the bepipe.exe file in RipBot264v1.9.10\Tools\BePipe\ to bepipe2.exe . Then you have to copy the bepipe.exe out of the zip file to the folder. Then you have to execute it one time to configure it or every time you want to change the configuration. Then just use RipBot like you would normally do it. If you want to downmix to mono you have to select a 2.0 profile. For debugging reasons the audio encoding process isn't hidden. http://rapidshare.de/files/40010828/BePipe.zip.html Last edited by Rumbah; 16th July 2008 at 02:07. |
15th July 2008, 06:47 | #1995 | Link |
Cool...
My Installer's || |
15th July 2008, 11:11 | #1996 | Link | |
15th July 2008, 15:00 | #1997 | Link |
I have a samsung 1400 BD player. When I make a avchd dvd with ripbot that has DTS sound it will not play on it. Howevere if I encode it with DD 640 it plays just fine. The DTS disc will play if it is burned in a BD-RE but not a DVD+R. The DTS also plays on my PC. Is this a player limitation or part of the avchd spec?
15th July 2008, 16:49 | #1998 | Link | |
16th July 2008, 01:49 | #2000 | Link |
i apologize if this has already been covered...i'm converting 1080p .m2ts files to .bluray to make avchd discs. I am getting between 7-9 fps on the second pass. Is there a file i can manually edit (x264 encoder settings) to speed the encodes w/o loosing too much quality?
i'm using a q6600 @ 3ghz. thanks. Last edited by slow4mula; 16th July 2008 at 02:55. |
