28th November 2011, 13:43 | #4221 | Link |
Handling of interlaced sources
Slowly I am getting a little deeper into the software...
For converting interlaced sources with X264 the process seems to be less automatic than it first looks. Right now I see two problems: 1. The source filter automatically adds "ConvertToYV12()" to the script. For interlaced sources this is incorrect, it should be "ConvertToYV12(interlaced=true)" instead. This means that the user has to edit the source filter parameters manually. 2. If Yadif or TomsMoComp are used for deinterlacing, the field order of the source must be specified with "AssumeTFF()" or"AssumeBFF()". This means manually editing the field filter parameters. My question is if this could be done automatically. The source already gets analyzed by MediaInfo, so the scan type and scan order of the source are known (at least in most cases, I hope). StaxRip would have to introduce 2 new macros called %source_scanorder% and %source_scantype%, and depending on these values the correct commands for field order and color conversion could be set. If I decide to not deinterlace my source, am I correct that I have to use "Config Codec" and add a custom switch to the commandline which must be either "--tff" or "--bff" ? It looks like the "--interlaced" switch is not supportet by the current X264 any more. Cheers manolito |
28th November 2011, 19:52 | #4222 | Link | |
@manolito,
do i understand you right, that you would like to keep your video interlaced while converting? The question would be why? Unless you use a non-flat tv for watching you just give your viewing equipment a hard time doing a real-time de-interlacing (I am in no way an expert on video-technology but i always thought i had understood that right :-D so feel free to correct me!) edit: I just had an interlaced source (might be something special, it is bonus material on an otherwis non-interlaced dvd) and it came out just as interlaced as it was. i did not notice the interlace before, so i will now do the encode again with yadif-filter @stax: one of my nightly encodes just gave me this right after the start of encoding: Quote:
So, the encode was set to the following parameters: source: mkv (dvd). Target: mkv (x264), 1pass. x264 settings: 18, medium, film. Audio settings: "just mux" (original ac3) Filters: ffvideosource, (auto)crop i used no resizing (progressive) My System is Windows 7 x64. I loaded and demuxed the source twice in staxrip, the error kept coming. Greetings Henrik Last edited by willscarlett; 28th November 2011 at 20:34. |
28th November 2011, 22:24 | #4223 | Link | ||
From my previous post: Quote:
Cheers manolito |
1st December 2011, 22:14 | #4225 | Link | |
Are you actually encoding DTS to something else, like AAC? I might be incorrect, but I'm pretty sure that if you're doing anything other than a straight mux of your DTS audio, then you'll need the ArcSoft DTS components. |
2nd December 2011, 05:26 | #4226 | Link |
Thanks for the update Stax
A couple of change in x264 api were missed though:
In any case though, its still a changed option the -open-gop change is the most important one for now, since in its current state when either option is selected it actually prevents x264 from starting. A simple change to a checkbox without the bluray/normal settings? Thanks! Last edited by burfadel; 2nd December 2011 at 05:30. |
5th December 2011, 08:49 | #4227 | Link | |
i spent some hours trying to fix that issue by myself and looking for a solution here in this thread before disturbing you with it. I got exactly the same problem like the person i just quoted: I have many many MKVs to encode. I really love to use Staxrip for that. Did someone find out how you can batch encode files in a way, that you add your files, let them all demux one by one and afterwards edit your jobs in the joblist, do your work like selecting the subtitles, audiotracks etc.? Lg, heldiX |
5th December 2011, 16:17 | #4228 | Link |
the batch encode works as you said above... set template and filters for all the movies in directory... but just one time, the first time before you add your files... staxrip takes the same settings for each job, so if you resize to 480p, all the movies you encode will have 480p height...
7th December 2011, 01:45 | #4229 | Link | |
http://audioconverter.heartware.dk/ |
19th December 2011, 21:06 | #4230 | Link |
Two question for you
Thanks for your useful program (and it's fast as hell ) and thanks for you help... |
24th December 2011, 01:15 | #4232 | Link | |
http://www.tbkhomeworld.com/staxrip Been using StaxRip since V1.1.1.0 days, so I have some experience with it. |
25th December 2011, 07:31 | #4234 | Link | |||||
@TBKHomeworld!
Unfortunately I don't have a sample file with similar format, most of my sample files are PAL. Maybe you can upload a small sample file and pm me the download link. If the DVD has only big files maybe you can create a smaller one trimming with DVD Shrink. Quote:
@willscarlett to quote kemure 9: Quote:
Thanks for the info, it will be fixed. Quote:
26th December 2011, 14:34 | #4235 | Link | |
I tried 2 VOB files with the current CLI version of MediaInfo 0.7.52, one is progressive, the other one interlaced. Here is what I got within the Video section: Progressive Code:
Scan type : Progressive Scan type : Progressive Interlacement : PPF Interlacement : Progressive Code:
Scan type : Interlaced Scan type : Interlaced Scan order : TFF Scan order : Top Field First Interlacement : TFF Interlacement : Top Field First Cheers manolito |
4th January 2012, 21:34 | #4236 | Link |
I want to rotate a clip and save this in a Template. I've found that the function TurnRight() should do it, but I can't figure out where to write this in StaxRip. PLS help me.. I've search for hours... |
14th January 2012, 01:44 | #4237 | Link |
Latest MKVToolNix versions
In the recent versions of MKVToolNix there has been some confusion about the correct track IDs and track numbering. The current version 5.21 definitely does things differently than earlier versions, it even required an update to MKVExtractGUI2.
This current version 5.21 of MKVToolNix does not work with StaxRip. Audio tracks will not be identified correctly. So please stick with the version 5.01 which comes with StaxRip. Cheers manolito |
14th January 2012, 23:28 | #4238 | Link |
I work quite extensively with Android OS on tablets and handsets, so I spent several weeks testing different variations to create a more-or-less universal template for encoding. The quality is coming out amazing, but I'm wondering if there is anything I can do to increase the encoding time without sacrificing quality. TBK, any thoughts?
Attached are the two templates I created (one for Blu-Ray, one for DVD). My avisynth plugins folder is an absolute mess from working with different filters, but I did zip it up and upload it to multiupload HERE. Edit: Since attachment is still pending approval, here it is from Multiupload.com I have tested the encoded video files on iPhone 4, iPad, iPad2, Motorola Xoom, Samsung Galaxy S, Samsung Galaxy S2, Galaxy Nexus, LG Optimus 3D (althought not ripped in 3D), Motorola Atrix, HTC Sensation, and HTC Desire. Stax, one small annoyance I have is that I cannot use the same source audio file for both tracks. I have to make a copy of the audio track and manually select it for the second track. Is that something that could be addressed in a future update? If two audio tracks are specified for encoding that they will both populate in the GUI and encode from the same source file? For making my templates sort of "universal" the two audio tracks are essential. The first (default) track needs to be Stereo AAC-LC for compatibility with many devices, but the second track is AAC VBR 5.1 so when outputing to my TV I can select to have surround sound. Miraculously, this works perfectly in the MP4 file container as well! Last edited by Navalynt; 17th January 2012 at 06:12. |
19th January 2012, 02:22 | #4239 | Link |
I am curious why I cannot "Just Mux" an MKV to mp4 for video passthrough, only re-encoding the audio to AAC (whether 2.0 or 5.1). I can "Just Mux" from MKV to MKV with audio re-encode, but not to MP4. The error I get is that mp4 container does not support this this format and StaxRip will not let me click Next. Any ideas?
Right now I use StaxRip-YAMB in combination to go from MKV to MKV to re-encode the audio and then YAMB to convert it to mp4. (My apologies, if this has already been asked.) |
20th January 2012, 11:14 | #4240 | Link | |
Important note: Before following this manual, make sure you HAVEN'T loaded any source file. If you have StaxRip running, the safest way is close StaxRip and then run it again.
gui, h.264, h.265, hevc, mkv, x264, x265 |
