16th September 2010, 20:02 | #801 | Link | |
Note: do not edit a post for adding a question, I receive no alert with edits.
Want to know all about your media files? http://mediaarea.net/MediaInfo |
16th September 2010, 20:05 | #802 | Link |
Mr. Sandman
ok and ok
16th September 2010, 21:08 | #803 | Link | |
Software Developer
[EDIT] Does anybody know if the "Generate intrinsic functions (/Oi)" option does effect CPU compatibility? If I look at the MSDN documentation, I see no indication of that: http://msdn.microsoft.com/en-us/libr...(v=VS.90).aspx
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 16th September 2010 at 21:22. |
17th September 2010, 01:10 | #804 | Link |
Mr. Sandman
the problem is described here: http://forum.doom9.org/showthread.ph...78#post1442978
13th October 2010, 15:47 | #805 | Link |
Zenitram - You'll be very kind if one day you put some simple ID3 tag editing in to MediaInfo for mp3/wma/ogg/mpa and for some of video containers. Thats not only my wish, but as well as many others. Atak_Snajpera says its possible...
13th October 2010, 15:50 | #806 | Link | ||
Currently, I have more than enough to do with reading, and a business model, and I have no business model for writing, so not a priority for me.
13th October 2010, 16:01 | #808 | Link | |
So now I display SBR and PS only if the header has an explicit information in the AudioSpecificConfig. Implicit SBR/PS will be detected when I implement a more complete raw AAC parser (I have a sponsor for this, but he continues to postpone the feature, he wants other features before this one)
14th October 2010, 10:50 | #810 | Link |
Thousands of $ ;-)
But already sponsored, just a problem of time. Theses tools would be broken in all cases with wrong info for other files without PS/SBR. I understand this is a problem, but I remove it from the official version for correcting otehr problems from other software. I could add it again but deactivated by defaut (you set a #define), and you know this may be wrong for some other files.
16th October 2010, 19:50 | #811 | Link | ||
war59312.com
Anyone have any vb code to parse the fps of a given file using mediainfo ?
Update: OK making progress.. Quote:
So for example if I run that on a video that has a 23.976fps I get back 23976. BTW the original string would be "23.976 fps" before ExtractNumbers does its thing. So yeah all I am trying to do is loose the fps. I'm newbie so learning by trying. So now just to have the decimal back in the right place? Any ideas? Update 2: Easy fix.. Thinking too much. fps = s.Replace(" fps", "") That gets rid of the fps. Problem solved. Whooo!!! New build of XenonMKV coming soon. Last edited by war59312; 17th October 2010 at 22:01. |
16th October 2010, 19:58 | #812 | Link | |
+ MI.Get(StreamKind.Video, 0, "FrameRate"); //For the first video stream of the file
5th November 2010, 01:59 | #813 | Link |
Software Developer
Zenitram,
I'm currently re-writing LameXP from the scratch, based on the Qt Framwork. And this time proper Unicode support has high priority for me Unfortunately I noticed that an unpatched MediaInfo CLI doesn't output Unicode characters to STDOUT properly. And a quick look at the code turned out why that is: Code:
inline void STRINGOUT(ZenLib::Ztring Text) { #ifdef __WINDOWS__ Text.FindAndReplace(_T("\r\n"), _T("\n"), 0, ZenLib::Ztring_Recursive); //MediaInfoLib handle differences between platforms, but cout too! #endif //__WINDOWS__ std::cout<<Text.To_Local().c_str()<<std::endl; } The good news is that this is easy to fix by using the UTF-8 multi-byte encoding instead: Code:
std::cout<<Text.To_UTF8().c_str()<<std::endl;
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th November 2010 at 02:01. |
20th November 2010, 01:30 | #814 | Link |
Originally Posted by Lawk
by default, "Enable context menu" is not ticked, but it's still in the context menu. Ticking and unticking makes no difference. Whats up with that? Do you use an official version (from mediainfo.sourceforge.net)? Which version? Which OS? I tested it again, and if the box is unchecked, there is nothing in the explorer. I have the same problem. I'm using Windows 7 home premium 64-bit. I downloaded the K-Lite codec pac 6.3.0 full, because I got no sound using gom player for video and saw a thread to d/l the pac. Problem solved, but it added 'features' I did not want. This K-lite pac included Mediainfo 0.7.34. During installation I was careful to opt-out of any shell integration additions if they were given, but they were installed anyway. I prefer a short list when I right click a file because 99% of the time have no need to use the many apps listed. I certainly don't need Media Info when right clicking on a txt file. I was able to ferret out the shell installed for MPH Media Player and delete the keys with a search, but for "Media Info" there is no registry key, and for "MediaInfo" I couldn't find a reference to shell integration. So I get the same issue as op, - ticking and unticking makes no difference. Navigating to K-lite > Tools > MediaInfo.exe "the program can't start because mediainfo.dll is missing from your computer" I went to sourgeforge and downloaded 0.7.36 and installed the 64-bit. Checking and unchecking explorer extension in preferences of the application also doesn't get rid of it. I wanted to post this last week but the forum makes you wait FIVE DAYS to post anything after joining! |
20th November 2010, 02:24 | #815 | Link |
Look here:
HKCR\*\shell\MediaInfo
MPC-HC 2.2.1 |
23rd November 2010, 02:35 | #816 | Link | |||
Tested with Example.ogg (in the SVN in MediaInfo/Release): Reference: ARABIC : ئابةتثجحخدذرزسشصضطظعغـف HEBREW : אבגדהוזחטיךכלםמןנסעףפץצְֱ COMBINERS : ˆˇˉ˘˙˚˛˜̣̀́̃̉ CYRILLIC : ЁЂЃЄЅІЇЈЉЊЋЌЎЏ ENGLISH : abcdefghaijklmnopqrstuvwxyz FRENCH : aàäâåáãæÅÆ cçÇ eéèëê uùüû GREEK : αβγδεζηθικλμνξοπρςστυφχψω LATIN : ĀāĂ㥹ĆćĈĉĊċČčĎďĐđĒēĔĕĖėĘęĚěĜĝĞğĠġĢģĤĥĦħĨĩĪīĬĭĮįİıIJijĴĵĶķĸĹĺĻļĽľĿŀŁłŃńŅņ Current version: ARABIC : ??????????????????????? HEBREW : ????????????????????????? COMBINERS : ^?¯??°?~`´~?? CYRILLIC : ?????????????? ENGLISH : abcdefghaijklmnopqrstuvwxyz FRENCH : aàäâåáãæÅÆ cçÇ eéèëê uùüû GREEK : aß?de??????µ???p??st?f??? LATIN : AaAaAaCcCcCcCcDdÐdEeEeEeEeEeGgGgGgGgHhHhIiIiI iIiIi??JjKk?LlLlLl??LlNnNn With UTF-8 forced: ARABIC : ئابةتثجØ*خدذرزسشصضطظعغÙ?Ù ? HEBREW : ×?×'×'×"×"××-×-×~×T×s×>×o×?×z×Y×*סעףפץצ Ö°Ö± COMBINERS : Ë+Ë+Ë%Ë~ËTËsË>ËoÌ?Ì?̃Ì%Ì£ CYRILLIC : Ð?Ð'ЃÐ"Ð.Ð+Ð+Ð^Ð%ÐSÐ<ÐOÐZÐ? ENGLISH : abcdefghaijklmnopqrstuvwxyz FRENCH : aÃ*äâåáãæÃ.Ã+ cçÃ+ eéèëê uùüû GREEK : αβγδεζηθικλμνξοÏ?Ï?Ï'σÏ"Ï.Ï+Ï +Ï^Ï% LATIN : Ä?Ä?Ä'ăÄ"Ä.Ä+Ä+Ä^Ä%ÄSÄ<ÄOÄ?ÄZÄ?Ä?Ä'Ä'Ä"Ä"ÄÄ- Ä-Ä~ÄTÄsÄ>ÄoÄ?ÄzÄYÄ*ġĢģĤĥĦħĨĩĪīĬÄ*ĮįİıIJijĴĵĶķĸĹĺĻļĽľ Ä¿Å?Å?Å'ŃÅ"Å.Å+ Forcing to UTF-8 is worse. Tested on Windows 7 French. But maybe the Qt wrapper you use accept UTF-8 as input, so this is OK (for example, if I redirect the output to a file, this is UTF-8). But Command line does not accept UTF8... So I can not put your code "as is", I will try to see if I can add an option for UTF-8 output.
23rd November 2010, 02:38 | #817 | Link | |
It include somebody else "MediaInfo Lite". This is not a product from me. Due to lot of complains about MediaInfo in K-Lite pack + Official MediaInfo install, I remove the contect menu from K-Lite during installation of MediaInfo since version 0.7.36.
23rd November 2010, 20:34 | #818 | Link | ||
Software Developer
Huh?
Inside ZenLib the To_Local() function calls WideCharToMultiByte() with "CP_ACP" selected, which "...instructs the API to use the currently set default Windows ANSI codepage". Also the MSDN doc of WideCharToMultiByte() clearly states: "The new character string is not necessarily from a multibyte character set." And indeed, if that target Codepage doesn't support the Unicode character contained in the original wchar_t (UTF-16) string, it is simply replaced by a "?" char For example on a German system the default Codepage is "Windows-1252 (Western European)", which doesn't support any Russian or Arabic or Chinese or Japanese characters. Since the default Codepage can differ from system to system (depending on what the user has configured), it's extremely unreliable to use this method... Quote:
Thus UTF-8 is able to preserve the complete Unicode space. So when converting from wchar_t (UTF-16) to UTF-8, absoloutely no information get's lost. Of course the result only looks correctly, if the application, who receives the UTF8-encoded data, is treating the character stream as UTF-8. The Windows console, by default, does not do this! You have to enforce it by calling "chcp 65001". This can also be done with SetConsoleOutputCP(CP_UTF8). If a custom application is reading the 'stdout' from MediaInfo, then it's of course up to the programmer to handle the character stream properly! But with UTF-8 encoded data the program at least has a chance to handle the input correctly A stream that was converted to the "local" CP already might contain unrecoverable "?" chars, so there is no way for the programmer to retain the original string. Here is a good article on the topic that I found quite helpful: http://www.codeproject.com/KB/cpp/un...le_output.aspx (Strange enough, using wprintf() with a wchar_t* does not work, as it converts to the local Codepage again and thus will fail on characters that aren't support by the user's default Codepage. The normal printf() works, but only by converting the wchar_t* to an UTF8-encoded char* first and only when setting the Console's CP to UTF-8 and only when a suitable Console Font, such as "Lucidia Console" is selected)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 24th November 2010 at 00:29. Reason: Correction! |
23rd November 2010, 23:12 | #819 | Link |
Software Developer
Okay, after some more testing, it seems even printf() sometimes screws up the UTF-8 string
So I think it's more safe to use a "raw" WriteFile(), which also avoids your FindAndReplace(). There is a special WriteConsole() function, but it fails on File redirection. Thus after all I would suggest this code: Code:
inline void STRINGOUT(ZenLib::Ztring Text) { #ifdef __WINDOWS__ DWORD CharsWritten; std::string Buffer = Text.To_UTF8(); SetConsoleOutputCP(CP_UTF8); WriteFile(GetStdHandle(STD_OUTPUT_HANDLE), Buffer.c_str(), Buffer.length(), &CharsWritten, NULL); #else std::cout<<Text.To_Local().c_str()<<std::endl; #endif //__WINDOWS__ } Seems to work fine for me. For both, Console output and File redirection (Just make sure you use the "Lucidia Console" font. The "Raster Fonts" Font doesn't work with Unicode! Some Asian chars don't even show up with "Lucida Console" though)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 24th November 2010 at 00:23. |
24th November 2010, 00:33 | #820 | Link | |||||
I am revamping my GUI with Qt too.
And the proposed solutions were not good. Quote:
So I use thie method.
