29th December 2015, 03:51 | #34901 | Link | |
Here is a quick explanation of what i wanna do: My masking reduces the screen size to the most common aspect ratio these days: 2.4:1. Only the upper side of the screen is masked, so i need to movethe image to the bottom of the screen, which is no problem for madvr. The problem is, that there are movies with an asprect ratio of 2.35:1 an i want to crop the extra pixels to perfectly match my masked screen. I don't know, if madvr has an option for this. Last edited by daglax; 29th December 2015 at 04:00. |
29th December 2015, 06:37 | #34902 | Link | |
Frankly, I think the only tricky part about it is making sure that your projector is defined as such so that the 'screen option' appears. After that, everything else seems quite obvious. |
29th December 2015, 10:58 | #34903 | Link | |
Only turn off dithering for testing, never for normal use. Dithering does not restrict the color gamut. What does dithering have to do with the color gamut?
madVR options explained Last edited by Asmodian; 29th December 2015 at 11:01. |
29th December 2015, 16:12 | #34904 | Link |
Is there an option in the madvr script language to activate profiles based on the active display?
For example: if (device = Samsung XY) "profile1" else "profile2" @jomnier Thanks that did help! I needed to adjust a video playback option in MPC-HC and then it worked! |
30th December 2015, 16:00 | #34905 | Link |
I'm Siri
@madshi
http://forum.doom9.org/showthread.php?t=173005 could this be implemented real time in madvr so I don't have to go re-encode all my videos to 4:4:4? |
30th December 2015, 17:14 | #34906 | Link |
Mouse Cursor and FSE mode
Forgive me if this has been asked and answered before. I did a search, but couldn't really find an answer.
The issue I'm having is that the mouse cursor always shows up in the center of the screen for a few seconds when play back starts up, which is kind of annoying. I tried moving the cursor off screen before starting play back but that doesn't seem to help. Is this a known issue? Is there anything I can do to avoid this from happening? Spec: MadVR 0.89.17 on Win 7 x32. Nvidia GTX 950, with 358.87 drivers. Zoom Player Pro 10. Thanks. |
30th December 2015, 18:58 | #34907 | Link |
That's odd, as ZoomPlayer hides the cursor more reliable than other software, at least for me. There's an option in ZoomPlayer ->Interface ->Mouse -> Hide the mouse cursor (at the top)... maybe you can adjust the seconds?
30th December 2015, 20:39 | #34908 | Link | |
and bilateral and superres(not sure of the current version) try to do the same. |
30th December 2015, 21:03 | #34909 | Link |
Is there anything I can do to improve the awful clock deviation on my AMD 7850? It seems no matter what settings I change (and I've tried them all), I always get at least 1 dropped or repeated frame during a 2 hour movie and it's really jarring. Video micro-stutters and the audio makes a loud glitching noise. It will fluctuate between 1 frame repeat every couple hours or sometimes days, but then will sometimes drop into the minutes for no rhyme or reason.
I'm about to throw this card out the window because I don't remember having these problems when I had a GTX 960. |
30th December 2015, 21:29 | #34911 | Link |
I'm Siri
It's different from super res, kind of similar to bilateral but not the exact same thing, bilateral could constantly produce both magic and garbage, that filter almost never produces garbage (because of super sampling and low frequency protection)
30th December 2015, 22:08 | #34912 | Link | |
I used to have a 960. Used custom resolution and never had any of these issues. I see AMD released 15.12 drivers with custom timing option so I will play around with that. |
30th December 2015, 23:40 | #34913 | Link | |
madVR options explained |
31st December 2015, 02:05 | #34915 | Link | |
You don't see this issue at all? The cursor never appears in the middle of the screen for you? Do you use the display mode switching feature? Thanks. |
31st December 2015, 16:39 | #34917 | Link | |
31st December 2015, 16:59 | #34918 | Link |
I'm Confused
I paid attention while watching last night and mine also leaves the pointer visable for a few seconds when loading a file in MPC-HC/madVR so maybe it's not the player. I wouldn't be surprised if this was Windows fault in the hand off for exclusive mode, but I'm no expert. Just confirming you aren't alone
HTPC/NAS: i7-4770 - GTX970 - 16GB RAM - 512GB SSD RAID 0 - 16TB HDD - mITX |
31st December 2015, 18:10 | #34919 | Link | |
Does that apply to you as well? |
31st December 2015, 18:54 | #34920 | Link |
I'm Confused
I do have a logitech TK820 and if I watch a 24p Bluray there would be switching since my desktop is at 60hz. I can try turning off the setting in madVR to switch the rate to match the source (in "Display Modes" section). I can also close the logitech systray application that controls things like pointer speed and gesture support.
HTPC/NAS: i7-4770 - GTX970 - 16GB RAM - 512GB SSD RAID 0 - 16TB HDD - mITX Last edited by Kranium; 31st December 2015 at 18:57. |
