11th June 2017, 16:13 | #201 | Link |
Life's clearer in 4K UHD
Thanks again
13th June 2017, 22:25 | #202 | Link | |
Special SeeD
14th June 2017, 09:45 | #203 | Link |
I've just run the newest build through Windows Defender and it's reported this: -
14th June 2017, 11:46 | #204 | Link |
@SquallMX
@SeeMoreDigital Thanks for your reports. I have here W 7 and Windows Defender without problems. Please check if that exe run without problems: https://www.sendspace.com/file/t75su0 If not, you can try compile yourself the source (.au3) using the free tool Autoit3 from here (recommended Download Zip without install): https://www.autoitscript.com/site/autoit/downloads/ Like you can see Autoit3 seems stop their development in September 2015 and don't mention W 10 like OS supported. - The source is free of trojan/virus like you can see. - The Autoit3 compiler seems also free of trojan/virus (I don't see any report about that since 2015) - My machine seems also free of trojan/virus (I hope, but if your compile work please report me!) After that only rest a false positive or a W 10 issue.
14th June 2017, 15:52 | #205 | Link | |
I've just run your new compile through Windows Defender and "all is well" Cheers
14th June 2017, 20:45 | #206 | Link |
Sorry, I was using a previous version to compile, with the last AutoIt v3.3.14.2 seems there are some changes to avoid malware false positives.
@SquallMX Work for you?
15th June 2017, 03:02 | #207 | Link |
New version 1.2.5
Changelog ========= - v1.2.5 2017-06-15 Audio recode: decoder admit parameters change (for ffmpeg). INF: ffmpeg report of tracks in any container. Can extract audio tracks. I hope than this new version don't have malware false positives.
19th June 2017, 14:23 | #209 | Link |
New version v1.2.6
- v1.2.6 2017-06-19 Bug fix: Autoit v3.3.14.2 write files by default like UTF-8 Before are writed like ANSI. Corrected. Filenames with spanish characters (ñ's, accents, etc.) are accepted now. Also affect to modified srt's.
19th June 2017, 15:18 | #210 | Link |
Hi tebasuna51,
Windows defender is reporting a malware issue with this new version
11th July 2017, 22:09 | #213 | Link | |
Maybe is the samplerate (192 KHz).
I don't have a sample like this to test. But work fine with a: Quote:
EDIT: I deleted your post in eac3to thread, please remember the forum rule : 8) No cross posting. Post your message once, to the appropriate forum and nowhere else or it will be locked or deleted without warning.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 11th July 2017 at 22:20. Reason: add info |
12th October 2017, 13:28 | #214 | Link |
New version v1.2.7 to support eac3to v3.32
Changelog ========= - v1.2.7 2017-10-12 Support eac3to v3.32 (UHD BD's y HEVC) Force ANSI to read text files. TwoLame replaced by ffmpeg to encode MP2.
12th October 2017, 14:06 | #215 | Link |
Thanks
16th October 2017, 11:58 | #217 | Link |
New version 1.2.8 to support MkvToolnix v17.0.0
Changelog ========= - v1.2.8 2017-10-16 Support MkvToolNix v17.0.0. New MkvExtractGUI. Don't work with previous MkvToolNix versions because the mkvextract.exe have different syntax, before: mkvextract {mode} {source-filename} options extraction-spec Now: mkvextract {source-filename} {mode1} options extraction-spec1 mode2 options extraction-spec2 … With mode: tracks, timestamps_v2, chapters, attachments Now we can use a unique job for all modes.
30th October 2017, 20:30 | #218 | Link | |
Cheers
30th October 2017, 23:41 | #219 | Link |
eac3to don't support mp4 container.
You can try 'MkvExtract/INF' to extract tracks with ffmpeg or 'A/V Recode' to decode/recode audio.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 30th October 2017 at 23:47. |
31st October 2017, 09:54 | #220 | Link |
Well that explains it then...
I could have swore I've used it before to de-mux streams out of the .mp4 container.... Alzheimer's
