27th October 2009, 12:00 | #8901 | Link |
again Remote API - delphi - DrawOSD
while trying rev. 3117:
1. \n or \\n doesn't work 2. I mean I call shortosdmessageabsolute faster than the delay value, cause I can't always know did it played the delay frames already or not (e.g. while FFWD or Rev) Last edited by swordsman; 27th October 2009 at 12:03. |
27th October 2009, 14:38 | #8902 | Link |
swordsman,
Regarding 1: thanks for letting me know, I made a stupid mistake, it's fixed in rev. 3118. (sorry) Edit: swordsman has updated that the issue is solved with rev. 3118 Regarding 2: for such scenarios, shortOSDmessage is recommended, that way messages will be shown in list. Last edited by tal.aloni; 27th October 2009 at 17:22. |
27th October 2009, 15:51 | #8903 | Link | |
27th October 2009, 16:07 | #8904 | Link |
A.K.A Mangoat
It works fine for me.
Basically the article notes what has been said above - you can't run traces against proctected processes. However, the author of that page has created a tool to unprotect the protected processes, and specifically mentions audiodg.exe I'll have a shot of this within the next few hours, using albain's tool and see if anything happens. |
27th October 2009, 18:37 | #8906 | Link |
Media Control author
Great, also can you try it on TMT like this :
1/ Launch the tool and launch TMT with it 2/ Unprotect the tmt process Maybe the process needs to be unprotected before putting the hook in it, I am not sure of that |
27th October 2009, 19:24 | #8907 | Link | |
A.K.A Mangoat
I will keep working on it. http://matureasskickers.net/wbb2/thr...3ee6661&page=3 You can get it from the 3rd post above. Last edited by Skinleech; 27th October 2009 at 19:26. |
27th October 2009, 21:46 | #8909 | Link |
27th October 2009, 22:39 | #8910 | Link |
A.K.A Mangoat
It didn't work on my HTPC - the software I mean. I keep getting an error message. It seems if you add a reg key via regedit it works, but the regkey is already there on my system and no joy.
Anyone else with any luck? |
27th October 2009, 23:45 | #8914 | Link |
A.K.A Mangoat
Replied - hope you have better luck than me.
FYI, if you get an error as I have been, this is allegedly the way round it: [code]I got the same error, until I created [HKLM\SYSTEM\CurrentControlSet\Services\drmkaud] and added a REG_DWORD named “Type”.[code] BUt I already have that REG_DWORD on both my Win7 pc and my HTPC yet still get the internal error reported. |
28th October 2009, 06:20 | #8917 | Link | |
DEVMGR_SHOW_NONPRESENT_DEVICES=1 devmgmt.msc It should then show up under "Sound, Video and game controllers" and will be listed as "Microsoft Trusted Audio Drivers". With my Xonar removed, it has the following error: "Currently, this hardware device is not connected to the computer. (Code 45)". I'm not sure if it was different when the Xonar was installed as I didn't check it then. Last edited by whurlston; 28th October 2009 at 06:23. |
28th October 2009, 09:16 | #8918 | Link | ||
A.K.A Mangoat
28th October 2009, 09:34 | #8919 | Link |
For now no new info with unprotect.
I have try this : I launch TMT via hook tools : I unprotect TMT and also audiodg.exe with command line : tasklist to find PID and dpinpurr.exe PID with ou without /P And i launch BD and idem in the log of debugview and bitstream.txt. After that if i close TMT, My computer crash. I have test 3 times and also crash (3x). Seb. Ps : i'm on Win7 32bit.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
28th October 2009, 12:49 | #8920 | Link | |
A.K.A Mangoat
If I run "dpinpurr 1234" from a command prompt I get an error message each time. I'm using process explorer to get the PIDs of each service. |
