11th September 2012, 09:32 | #15721 | Link | |
Fyi, I did same for Men In Black II. No problems. Funny how it only happens with MIB I Aloha |
12th September 2012, 06:36 | #15723 | Link | |
Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk |
12th September 2012, 18:45 | #15724 | Link | |
12th September 2012, 19:10 | #15725 | Link | |
I should correct myself, though. I said "Almost all discs have pulldown applied..." -- I should have said "Almost all NTSC discs have pulldown applied... TSMUXER does have an option to remove pulldown. Last edited by jdobbs; 12th September 2012 at 19:17. |
12th September 2012, 19:58 | #15726 | Link | |
Player or tsmuxer -- it seems advisable to avoid --pulldown if possible. |
13th September 2012, 07:34 | #15727 | Link |
I am storing all my movies into ISO rips using a custom 9GB setting, movie-only mode, high-speed option and both encoding un-ticked to enable 2-pass encoding. This results in crunching the movie down in a few hours. I will be storing an HD audio stream wherever possible within the 9GB iso and leaving the rest for video.
Has anyone used this option and compared the results without the high-speed option and highest (very slow) encoding selecting instead? If so, are there big difference in the resulting output or is it only marginal, if at all? I'm trying the second option and see how long that takes and what the outcome is and will compare it to the original. I just did a run using the first option using kick-ass as the movie input and the output seems excellent. Though, I'd have to wait for this second one to finish to compare the results. As I have a BDP-93, I'd want the ISO rips to be large enough so I would prefer the better outcome video quality wise, even if it takes many hours longer. My initial intention will not to burn these to bdr-25gb blanks as I want to store my rips into a reasonable size so that I can fit as many onto a 2TB disk without compromising video quality and thought 9GB was a good place to start. I do have an LTO Ultrium 4 backup drive and will instead backups my rips to tapes. Your input appreciated. Cheers Last edited by pasadena; 13th September 2012 at 07:46. |
13th September 2012, 11:35 | #15728 | Link |
a question, HIDDENOPTS.txt file does not appear, or rather, only appears ...
AUTO_BIAS = n n = 0-3 n=4 would use the writing process:work? AUTO_BIAS=4 ENCODE_QUALITY=4 Quality: Ultra High Quality (Extremely Slow) |
13th September 2012, 13:01 | #15729 | Link |
The AUTO_BIAS setting affects the threshold as to where the decision points are made using AUTOMATIC mode. So if you select anything other than AUTOMATIC, it has no affect at all. But if you set it to a higher value, there is a bias toward using higher quality settings as opposed to lower quality settings. But the decision is still based on frame counts, target size, and bitrate.
13th September 2012, 13:39 | #15730 | Link | |
AUTO_BIAS = 4 ENCODE_QUALITY = 4 would be compatible with each other? or AUTO_BIAS is limited to (3) edit rebuilder.ini [Options] VERSION=0.42.0.2 MODE=0 AUTO_BIAS=4 ENABLE_TEST=1 BLANK_THRESHOLD=1 DTSX_ENABLE=1 AUTO_BIAS=4 MULTIPROCESS=16 MIN_M2TS_SIZE=1 MIN_PLAYLIST_MINS=1 ENCODE_QUALITY=4 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=24925 PRIORITY_CLASS=1 QUICK_EXTRAS=0 AUTO_BURN=0 TARGET_SIZE=24925 ENABLE_BLANKING=1 "I just got a good price an i7-980x (multiprocess = 16)" Last edited by lauguru; 13th September 2012 at 13:49. |
13th September 2012, 18:49 | #15732 | Link |
@pasadena
Hi! The purpose of this thread is specifically to bring to light bugs that arise during beta testing, so that jdobbs can resolve them. You should feel free to start a new thread for postings of other questions and/or observations regarding BDRebuilder... |
13th September 2012, 19:26 | #15734 | Link |
I think I'm missing something in the options. With the new Importing method, I noticed using the SD_PROGRESSIVE that 29 does get changed to 23.976...no re-rendering for 720x480 sources. Video is still jerky via LG Player and software. Would it be possible to add a re-render feature that keeps the same resolution to get a smooth output (SD to SD with Pulldown)? Or are there options I'm not using correctly, or a combination? The SD to 720p does look Good, but I'd rather keep the same 720x480 with a 2 pass encode.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
13th September 2012, 21:55 | #15735 | Link | |
But... if both of those are set, and it doesn't IVTC -- then the source isn't pulldown and it can't be output as FILM (23.976). In that case then if it is jumpy, then either the original or your players are at fault. If you don't want to IVTC, then just uncheck those two and let BD-RB reencode at 29.97. I'd also suggest you use the DEINTERLACE option. Those settings are the default in BD-RB. If you are experiencing jerkiness with the defaults set -- you'd better check on your players -- because the jerkiness isn't coming from the processing. Just as a note... I'm POSITIVE the IVTC/SD_PROGRESSIVE combination is working correctly. All 45+ of the DVDs I've converted in testing worked correctly using those options and they all used pulldown. Last edited by jdobbs; 13th September 2012 at 22:19. |
13th September 2012, 22:15 | #15736 | Link |
BD Rebuilder v0.42.03 (beta)
I have updated the first post of this thread with links to a new release of BD-RB (v0.42.03). Changes for this version:
- Added code to correct for the occasional audio PTS start delta during DVD importing. - Corrected an issue in which the framerate for imported PAL DVDs could be incorrectly pulled from the source IFO files. This would result in audio sync issues. - Made changes to video file import so that DTS-HD, TRUE-HD, and LPCM sources are properly handled in .TS and .M2TS files. - Corrected an error in which importing .TS files will fail during attempt to create BD structure. - Other minor corrections and cosmetic fixes. |
13th September 2012, 22:18 | #15737 | Link |
I wasn't doubting you. No intention was meant that way. Doing some tests. Thanks a lot for the reply.
Ah, sheeeot....hahaha, I forgot about the sizes...I haven't used the custom sizing for a bit. Since episodes are about 42 minutes, the file size has to be taken into account. Laughing at myself!! Got it.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 14th September 2012 at 05:00. Reason: Noticed what I missed. |
14th September 2012, 16:49 | #15738 | Link | ||
Latest version still produces 4:3 output from PAL DVDs. Audio is in sync.
14th September 2012, 17:37 | #15739 | Link |
[17:14:40] Importing DVD: COUGARS_INC - Collecting audio/video/subtitle streams... - Converting subtitles to BD format... - Creating BD from audio/video/subtitles... [17:18:59] DVD import completed successfully. ---------------------- [09/14/12] BD Rebuilder v0.42.03 (beta) [18:26:01] Source: COUGARS_INC - Input BD size: 0,00 GB - Approximate total content: [01:18:38.912] - Target BD size: 22,95 GB - Windows Version: 6.0 [6002] - MOVIE and MENUS mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DGDecNV [2-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - [18:26:01] DoEncoding() 00011 1502 [18:26:05] - Failed to complete. ---------------------- Code:
---------------------- [09/14/12] BD Rebuilder v0.42.03 (beta) [18:26:20] Source: COUGARS_INC - Input BD size: 4,22 GB - Approximate total content: [01:18:38.912] - Target BD size: 22,95 GB - Windows Version: 6.0 [6002] - MOVIE and MENUS mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: X264/LAVF [2-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:26:20] PHASE ONE, Encoding - [18:26:20] Processing: VID_00000 (1 of 1) - [18:26:20] Extracting A/V streams [VID_00000] - [18:27:28] Reencoding video [VID_00000] - [18:27:28] Keeping original video (no reencode) - [18:27:28] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - [18:27:28] Multiplexing M2TS [18:30:21]PHASE ONE complete [18:30:21]PHASE TWO - Rebuild Started - [18:30:21] Rebuilding BD file Structure [18:30:21] - Encode and Rebuild complete [18:30:21] Writing BD structure to ISO file - ImgBurn completed successfully - COUGARS_INC folder removed. - WORKFILES folder removed. [18:32:49] JOB: COUGARS_INC finished. Code:
[Options] MODE=1 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 AUDIO_TO_KEEP=dut;eng;nld;und; SUBS_TO_KEEP=dut;eng;nld;und; SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 FULL_AVCHD=0 REMOVE_OUTPUT=1 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 PRIORITY_CLASS=1 TARGET_SIZE=23500 AUTO_BURN=2 IMGBURN_TARGET_DEVICE=e: QUICK_EXTRAS=1 MINIMIZE_TO_TRAY=1 OPEN_GOP=0 MOVIE_ONLY_LOOP=1 USE_FILTERS=0 USE_LAVF=1 VERBOSE_STATUS=1 BDMV_CERT_ONLY=1 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 SD_TO_1080=0 CONVERT_WIDE=0 AUTO_BLANK=0 UNMASK_CHAPTER=1 ENABLE_TEST=1 ENABLE_BLANKING=1 BLANK_THRESHOLD=60 DTSX_ENABLE=1 MULTIPROCESS=1 VERSION=0.42.0.3 COMPLETION_BEEP=1 BEEP_SOUNDFILE=C:\Program Files (x86)\ImgBurn\Sounds\Success.wav DGDECNV=0 IMPORT_FOLDER=D:\TEMP [Paths] WORKING_PATH=C:\TEMP\ SOURCE_PATH=D:\TEMP\IMPORTS\COUGARS_INC\ DGIndexNV=C:\Program Files (x86)\BD_Rebuilder\dgdecnv\DGIndexNV.exe DGDecNV=C:\Program Files (x86)\BD_Rebuilder\dgdecnv\DGDecodeNV.dll [Status] LABEL=COUGARS_INC VERSION=v0.42.03 (beta) SOURCE_SIZE=4527117420 SOURCE_VIDEO_SIZE=4527034368 TARGET_SIZE=24641536000 REDUCTION=5.44317779475714 RESIZE_1080=0 AUDIO_TO_KEEP=dut;eng;nld;und; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=dut;eng;nld;und; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=-1 INSTANCES=2 DGDECNV=0 QUICK=1 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00000] USE_ORIGINAL=1 AUDIO=11 PGS=1 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24641452948 NSTART=27000000 NEND=239351040 NSIZE=4527034368 FLINK=0 MLINK=0 Last edited by Ch3vr0n; 14th September 2012 at 18:46. |
14th September 2012, 20:32 | #15740 | Link |
When converting a DVD to Blu-ray is there any way to stop it from converting all the subtitles and only convert the ones you want to keep? Some of my DVD's have 15+ subtitle tracks which takes around 8 minutes to convert when I only want to keep 1 of them
