Old 8th August 2016, 16:59   #21  |  Link
shekh
This is göynük canyon, turkey.
For skew I have some ideas in todo list. It is quite easy to match frames to each other using 2 sets of parameters instead of 1 (same as deshaker).
Then it is quite easy to try full compensation matching all frames to single reference frame, this is suitable for shots without motion. This should certainly work, but I am not sure RS is an issue at all with such shots.
The trouble is to build a path when camera moves. I certainly cannot just accumulate differences stacking one frame after another: this works for no-skew mode but with skew included the growing error tears frame apart.
I tried deshaker approach without success (either I did it wrong or did not understand the result), also tried filtered average as immediate reference (same here).
Another idea is to collect frames with lowest skew and use them as references.
First I need better motion data. For this I started to make analyzer
Second problem is to understand what happens. This is hard with real footage. I dont see something simple like skewed pillar, instead the shot just looks "jelly" but I cant tell for each frame where it is wrong.
To some extent I train the math on synthetic RS-skewed shots. This way I can have perfect result to compare with. But I need to go deeper and prepare realistic synthetic shot with motion and shaking similar to reality, and this is damn long task to prepare
For wobble I have no ideas. I suppose it requires different level of enginery (structure from motion etc).
I chose as milestone some piece of footage which has really bad shake but still no wobble.
Btw maybe by the time I finish that, they come up with practical global shutter sensor?
VirtualDub2
Old 25th March 2017, 16:50   #22  |  Link
djonline
shekh, b2kguga. I was used Synthyes too, it works fine on CCD camera (my example https://www.youtube.com/watch?v=wsrs28aUAKw and https://www.youtube.com/watch?v=bxQ8AkyK70k and https://www.youtube.com/watch?v=NTYdAVV71p8) , but it completely unusable on consumer CMOS camera due Rolling Shutter. There is no way to fully eleminate them, so better result for CMOS is to use Warp Stabilizer in Adobe Premiere.
I dont 'like shaked edges in this example of Canyone, it is not usable for me. But I still use deshaker for little shaked video to eleminate small shake, coz Warp is still very slow.
djonline is offline   Reply With Quote
Old 9th September 2019, 11:22   #23  |  Link
nji
Hi shekh.
I posted I question to your plugin in another (wrong) thread
https://forum.doom9.org/showthread.p...79#post1884379
Greetings.
nji is offline   Reply With Quote
Old 10th September 2019, 12:59   #24  |  Link
shekh
Originally Posted by nji View Post
Hi shekh.
I would like to ask if there is an up-to-date version of your plugin.
(Only the plugin and the needed files for ini etc. for use in VDub2)
I use DeShaker for a long time, but had to make the experience
that with large FOV it produces "wobbling" results (due to the
lack of taking perspective into account) that make the result
worse than the shaking version.
In Deshaker - as a first step - a simple option for FOV
(wide-angle, normal, tele) would be fantastic.
But ... sadly ... DeShaker isn't improved anymore.
As far as I understand the matter, BEFORE phase 1 in DeShaker
there would have to be the perspective correction (panotools etc.?)
and after that to calculate the motion vectors etc.
But maybe your plugin works well enough already?
Greetings! :-)
actually the published version is the last one. Any further improvement is in awful "maybe resume later" state.
That said, the last version can do something, I believe, better than deshaker wrt perspective and distortion.
If you really want to use it as is but don't understand the GUI, I can guide you Post your sample.
VirtualDub2
Old 11th September 2019, 11:38   #25  |  Link
nji
Hi shekh.
Thank you for your response and your offer for help.
I'll try on my own first.
And if nothing more helps ... I could read your posted instruction ;-)
Only one thing about the "published version" you mentioned.
It is a collection of a complete (and old) VD version and some other things.
Would it be possible for you to do only the needed files for your tool/ filter in one package/ zip, so that one can easily integrate it into an existing VD2?
That would be nice.
BTW: Strange that there is so few interest in that wonderful quality improvement of deshaking (And ever more the lens correction). As most shaky videos will be taken on a middle FOV, and not FOV=0 (= standard DeShaker without perspective accounting).
Old 14th September 2019, 10:39   #26  |  Link
nji
Please don't forget that most videos VD manipulates are from the past (at least for me it's the case). And all they are taken by "previous" optics/ sensor types.
Old 14th September 2019, 17:55   #27  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
I'm curious to know who's processing videos from the future.
wonkey_monkey is offline   Reply With Quote
Old 8th January 2020, 11:54   #28  |  Link
nji
I recently tried (had to ) your plugin on a wide angle movie.
I stripped the nescessary files to the minimum (see attachment).
Is that complete?
Does your alg do "3D calculation", or "simply" performs DeShaker's log?
Does the rolling shutter/ "skew" work?
Old 8th January 2020, 19:50   #29  |  Link
shekh
Is that complete?
Please note that this project is somewhat buried.
Can't see attachment. What you planned to show?
I saw your posts about it in other places, so I try to summarize replies
The "transform" rebuilds true projection to different direction and with different lens (but from same focal point).
By true projection I mean, if you had actual real life shot of the same scene it would match exactly.
For this to work it needs accurate lens description with FOV and distortion curve.
In this way it does true 3d calculation. Did you mean something else?
(also the amount of rotation for all axes is expressed in units of rotation not pixels)
Deshaker log was used as a guide to derive motion but not as direct instruction to move pixels.
Rolling shutter: no, I don't think it worked
VirtualDub2
Old 8th January 2020, 20:59   #30  |  Link
nji
Hi shekh!
Actually I don't understand why you don't see
why nobody can see the attachment at the moment.
Being not logged-in it says (for everbody I guess):
"Attachments Pending Approval".
The case I'm interested in is that I don't have detailed
information about the lens the movie has been taken with.
(Except a vague value of FOV).
And even if I would know, first there would have to build
a description as you wrote.
If I understand it right (do I?) without that information
your plugin is useless for all its functionality?
Next: I do not understand how Deshaker's log could be
of any use for your plugin. As its analysis was done
without knowing the specific lens characteristics.
"... as a guide ..." ???
Rolling shutter ("skew") doesn't work?
But there is an active check-box for it ...
Old 8th January 2020, 21:40   #31  |  Link
shekh
The goal of this plugin was use with known camera which you can calibrate and test.
Some program may help you to extract lens params from movie. Don't know much on this.
The principle how deshaker log was used here: suppose deshaker recorded 100px move to the left. By comparing pixels and how they are projected from world you can translate this into radians.
Together this is not accurate enough but is 'move in right direction'.
VirtualDub2
Old 9th January 2020, 01:18   #32  |  Link
nji
So, is there a way to "feed" your plugin just with the FOV value for a movie?
With "neutral values" for the other distortion.
And if ... how?
Old 9th January 2020, 14:10   #33  |  Link
shekh
try to add your new profile like below
[lens]
  name = "my test"
  hfov = 90
VirtualDub2
Old 9th January 2020, 17:55   #34  |  Link
nji
... suppose deshaker recorded 100px move to the left. By comparing pixels and how they are projected from world you can translate this into radians.
You calculate which kind of angle movement (wrt to FOV)
would cause a Deshaker's 2D movement.
Then you take that angle movement and transform it back to 2D.
Do I get it right?
How does this compare to Avisynth Deshaker3D approach?
And how does it compare to Deshaker solely?
Identical for FOV = 0; and better results than Deshaker with larger FOV?
Old 9th January 2020, 20:59   #35  |  Link
shekh
nji
It is really boring to explain application of deshaker log because there is nothing to say, it is just basic trig and the method is also just a proof of concept (better log is needed).
Deshaker3D is bare minimum algorithm which is also included in lens transform (minimum math is so basic you can't avoid it).
Looks like I made this for you to help understand the place of FOV (old video): https://www.youtube.com/watch?v=JpKHxfC28mQ
VirtualDub2
Old 9th January 2020, 22:15   #36  |  Link
nji
Sorry having asked.
Old 10th January 2020, 00:45   #37  |  Link
nji
Is there a way to let not only the borders "repair" but also dubbing-ons (like logos etc.)?
Old 10th January 2020, 01:00   #38  |  Link
shekh
"repair" just fills based on alpha channel, so you need some way to "erase" alpha where you need. Something like push logo to alpha channel. I don't have such filter but it is really simple. Do you have a use-case?
Btw, I believe delogo filters solve this better so what is your intent?
VirtualDub2
Old 10th January 2020, 09:42   #39  |  Link
nji
My intent is simply to prevent a dubbed-on date jumping around
when the movie is deshaken.
In Deshaker you can mark arbitrary areas by a special color
which is recognized by Deshaker and repaired.
But - and this is important - Deshaker does much better than
just delogo. As it takes neighboured frames for the filling
of the areas.
EDIT:
I suspected that repair would do something similar.
But that was wrong thinking, as repair gets only the alpha from lens transform.
Conclusion:
Do delogo before lens transform.
Old 10th January 2020, 12:08   #40  |  Link
shekh
Ok, I assumed such workflow but it is not ready.
VirtualDub2
