3rd February 2012, 16:51 | #241 | Link | |
Posts: n/a
For the CLI it'll maintain the current behavior. It'll offset your startcut value or if no startcut value is specified it'll end up being your startcut value. For the GUI, it'll be populated as a cut value. I'm also going to change the GUI so that negative delay isn't accepted. If you want a negative delay, just modify your start cut value in the GUI since that's what it was doing behind the scenes, anyway. |
3rd February 2012, 16:57 | #243 | Link |
Posts: n/a
Okay. Maintaining the behavior for the CLI is good so for automated tools like yours that you don't get any added complexity. If you always just specify "-auto" it'll do the work for you so you don't have to specify the -startdelay and it'll work the exact same as if you had (obviously barring any bugs ).
4th February 2012, 03:04 | #244 | Link | |
naturally you're right.. a negative delay it's only a cut at the start... but also the positive delay it's an insert of silence at the start... so why remove only the negative? In my case i have a lot of times both cut and a negative delay... it's a lot easier insert both values without to have to calc it manually... Last edited by phate89; 4th February 2012 at 03:10. |
27th February 2012, 12:38 | #245 | Link |
@amtm: assuming you are the maintainer of http://download.opensuse.org/reposit...xUbuntu_10.04/ could you update is to a more current version ? thanks.
27th February 2012, 17:16 | #246 | Link |
Hello,
Had you thinked about the command line switchs to allow multiple adds and cuts in the middle of stream? (I think you want to implement this). I am doing something similar for subtitles and because the use is paralel (cut in audio, cut in subs...) maybe I can clone the sintax to simplify the use. Thanks. |
10th March 2012, 20:49 | #247 | Link |
Hello,
I thinked delaycut supported mp2 and mp3 files, but maybe I am wrong because this formats are not in the list of available formats (and I can not open them). But I think in older versions I used delaycut to fix mp3 files. If delaycut doesn't suport this files, is there any program to do with mp3 what delaycut does with ac3? Thanks. |
12th March 2012, 16:41 | #249 | Link | |
18th March 2012, 22:00 | #250 | Link |
Posts: n/a
Sorry, I've been away for a while due to a variety of reasons, but I'm still working on it but it probably won't be for another 2 weeks before getting a new version due to some travelling I've got to do.
Yes, it supports mp3. I'll change the open file filters as I just copied the way the original program did it which only did *.mpa and you had to do "all files" to get the mp3. It's nothing but a carry over that can be changed. |
20th April 2012, 12:30 | #251 | Link | |
+ delayac3.cpp misses: #include "math.h" + some thing it wrong with delaycut.pro, using: Code:
QT += core gui CONFIG += qt \ console TARGET = delaycut !win32 { target.path = /usr/bin INSTALLS += target } TEMPLATE = app SOURCES += main.cpp\ delaycut.cpp \ delayac3.cpp \ dragdroplineedit.cpp HEADERS += delaycut.h \ sil48.h \ delayac3.h \ types.h \ dragdroplineedit.h FORMS += \ delaycut.ui RESOURCES += \ delaycut.qrc RC_FILE = delaycut.rc Cu Selur Last edited by Selur; 12th July 2012 at 15:57. Reason: Please, use quote instead code for long lines |
24th June 2012, 11:12 | #252 | Link |
sorry, but how to compile delaycut in ubuntu ?
i check the README but i cant see the instruction i use Code:
git clone git://github.com/athomasm/delaycut.git cd delaycut qmake make Code:
g++ -m64 -Wl,-O1 -o delaycut -L/usr/lib/x86_64-linux-gnu -lQtGui -lQtCore -lpthread /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld returned 1 exit status make: *** [delaycut] Error 1 |
12th July 2012, 15:52 | #254 | Link |
@Selur
sorry for my question but how do i make this changes? i did not have the file delaycut3.cpp qmake give not response and make give me the same error @hlmasterchief93 **Edit*** delaycut3.cpp== delayac3.cpp Last edited by Snakekick; 12th July 2012 at 15:58. |
12th July 2012, 15:57 | #255 | Link | |
I see I made a typo delaycut3.cpp should be delayac3.cpp |
12th February 2013, 00:48 | #256 | Link |
Anime addict
Hi guys, I want remove a segment of ac3 file. I put a example:
First part: 0ms-5000ms Secong part: 6000ms-end Of this way, I would remove 999ms intermediate. ¿How I should configure delaycut for it?
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
16th February 2013, 00:50 | #257 | Link | |
47.952fps@71.928Hz
Which is perfect for trimming the beginning and/or the end of a compliant Matroska file. Mux the AC3 into an MKA (Matroska Audio) using mmg and apply the splits you want. Documentation on the -split function here. http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge.html#mkvmerge.description.split You can later demux the AC3 using MKVtoolnix with MKVExtractGUI or other tool.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
16th February 2013, 12:40 | #258 | Link |
@Sparktank
The easy way is use, like a say to Overdrive80 in other post, eac3to: eac3to input.ac3 output.ac3 -edit=0:00:05.000,-1000ms (remove 992ms without recode) With DelayCut we can Cut first part 0 to 5000ms, obtain the second part with a -6000ms Delay and after join the 2 parts.
16th February 2013, 16:24 | #259 | Link | |
How about inserting silence? Would a + sign work for both cases? Can multiple edits be performed by a single command line? Many thanks and best regards. Last edited by mariner; 16th February 2013 at 17:13. |
16th February 2013, 17:15 | #260 | Link |
To insert 1000ms of silence:
eac3to input.ac3 output.ac3 -edit=0:00:05.000,1000ms -silence (with values less than 1000ms the default for eac3to is loop the previous frames)
