1st July 2008, 09:52 | #3861 | Link | |
If you try selecting the AviSynth 32 bit Plugins directory with v0.2.6.1049 it will error and when you try to save the setting it fails.... |
1st July 2008, 13:04 | #3862 | Link |
Mr. Sandman
@devs: at this point, i'd say to move 0.3 into the stable folder in the autoupdate server.
also, next version would be 0.3.1, then 0.3.2, etc. a sort of features implemenation "path" to 0.4... so we can add stuff and quickly move every version (once "stabilized") to the stable folder. what do you think?
1st July 2008, 13:47 | #3863 | Link |
Mr. Sandman
New dev build at sourceforge: https://sourceforge.net/project/show...kage_id=244469
recent changes: Code:
0.3.0.1013 - (kurtnoise) cosmetics - Presets instead of Profiles. - (kurtnoise) removed .net framework checking for vista users during the loading. It should be fine now with all apps updated and frankly it's also to avoid to waste some time to upgrade each number indefinitely...;-) - (berrinam) Reset zones even when preview window doesn't open (fixes #2007133 - Error when loading "AutoEncode") - (kurtnoise) removed audio tracks selection from the D2V creator. 0.3.0.1012 - (sharktooth) fix for #2001332 ([0.3.0.1010] AviSynth script creator does not open) 0.3.0.1011 (includes the fixes and additions up to ver. 0.2.6.1050) - (berrinam) [ProfileExporter] Fixed bug where exporting 2 profiles each with associated files would fail (bug not reported) - (berrinam) Add ZonesWindow to VS2005 project file (patch by Sean McGovern) - (kurtnoise) [AviSynthAudioEncoder] better detection of several data streams (AC3, MP3, DTS, etc...) from the wav container. Mainly based on Tebasuna's code. - (kurtnoise) [LanguageSelectionContainer] added 'Fran�ais'. - (kurtnoise) 'computed' instead of 'used' in CommandlineVideoEncoder - (kurtnoise) [CommandlineVideoEncoder] better handling for several Encoding Modes. - (kurtnoise) updated a missing event for max key Frame interval in the Xvid Configuration Panel. Patch by Underground78. - (berrinam) Added zones back to main window (outside codec configs)
1st July 2008, 14:31 | #3864 | Link | |
Swallowed in the Sea
1st July 2008, 15:11 | #3865 | Link |
Mr. Sandman
dgindex is up to date.
about the other packages, ill see if i can update them later.
1st July 2008, 17:44 | #3866 | Link |
Mr. Sandman
@devs: divx is probably going the CLI way for the next divx avc codec.
should we consider implementing it (assuming they make a cli encoder?)
1st July 2008, 21:36 | #3868 | Link |
Mr. Sandman
@berrinam: could you please change the link in the first line of the megui guide thread from http://x264.nl in http://www.sourceforge.net/projects/megui ?
2nd July 2008, 03:39 | #3870 | Link | |
How about also doing the SVN shuffle now? |
2nd July 2008, 04:04 | #3871 | Link |
Mr. Sandman
rigth now there's a new bug in jobqueue.cs ... but im going to sleep (5AM) so i wont fix it right now.
feel free to do it if you want/have time. it should be easy to fix. after the bug is gone we can shuffle the svn and move 0.3.0 to stable in the autoupdate.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 2nd July 2008 at 04:06. |
2nd July 2008, 07:22 | #3873 | Link |
too bad...the one click encoder is broken now due to the remove of audio tracks selection from the d2v creator. :s
So, we need to go back by rebuilding this part or find an other solution asap... |
2nd July 2008, 08:45 | #3877 | Link |
As of svn rev590, I have moved everything out of /trunk and have moved the files into folders like /megui/trunk, /neroraw/trunk, etc. I have moved compile-all.bat and compile-all-msbuild.bat to /, but they almost certainly will not work located where they currently are. We will have to consider what we do with these; my thought is that there is no need for compile-all.bat files -- it should be enough if every subproject (megui, neroraw, ...) has its own compile(-msbuild).bat file.
The megui trunk should be buildable, once got from /megui/trunk. I will, soon, complete the reorganisation by moving the tags and branches to the appropriate places. |
2nd July 2008, 10:46 | #3878 | Link |
there is still a problem with the one click encoder : when we select the 1st or the 2nd audio tracks from the list, an error occurs at the end of the d2v creation...
I'll try it asap. |
development, megui, not a help thread |
