19th March 2012, 03:26 | #19101 | Link | ||||
Firefox User
19th March 2012, 18:05 | #19102 | Link | |
http://forum.doom9.org/showthread.ph...76#post1552176 |
20th March 2012, 13:19 | #19104 | Link |
MPC-HC Helper xD
I'll do my best to advocate for an release in next 2-3 weeks. Ivy Bridge is going to be ready afaik and we have fix applied already in trunk, so we must have release on time. Else Ivy users will have problems.
20th March 2012, 22:54 | #19105 | Link |
MPC-HC Developer
When subresync bar is enabled time is showed with more precise and that's good, but after rev3302 Status bar and OSD shows wrong time. For example if we jump to 02:45.550 status bar will show 02:46.550 of course it is fine when millisecond are below 500 and jump to 00:02:46.499 is indeed 00:02:46.499
BTW. Would it be possible to scroll down to current line in subresync automatically? EDIT I see now that it is not rev 3302, but it was first time when problem shows up. Last edited by kasper93; 21st March 2012 at 01:38. |
21st March 2012, 08:21 | #19106 | Link |
1.6.1.4164 (Windows XP SP3)
https://sourceforge.net/apps/trac/mpc-hc/ticket/2090 MediaInfo font got a bit too small. Should be at least 1 size bigger for better readability. https://sourceforge.net/apps/trac/mpc-hc/ticket/2089 The MediaInfo dialog should get resized automatically so that no horizontal scrollbar is needed. Would be much better to read this way. Maybe the maximum horizontal size should be limited to 630px tho (to avoid too large windows on 640x480 screens). |
21st March 2012, 19:14 | #19109 | Link | |
MPC-BE DEV
For starters, you should solve your problems on your computer. I'm watching your correspondence on forums.virtualdub.org, there you are also trying to impose their problems developers Virtualdub. On a properly configured PC tab with "MediaInfo" looks like this: Windows 7 Windows Xp SP3 P.S if I could be in your computer, then I would be able to solve your problem in 10 minutes.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. Last edited by alexins; 21st March 2012 at 19:27. |
21st March 2012, 21:50 | #19110 | Link | |
MPC-HC Helper xD
22nd March 2012, 08:09 | #19112 | Link |
@ Dstruct:
Looks like you have only the "Courier" bitmap font available. Are there possibly issues rendering TrueType / OpenType fonts, or missing alternatives (a stripped fonts collection)? |
22nd March 2012, 10:23 | #19114 | Link |
Then maybe you can do something about it http://sourceforge.net/apps/trac/mpc-hc/ticket/1598
P.S. just out of curiosity, maybe you know, which of the devs are so adamant against adding such an optional, not enable by default, GUI option ? since nothing has been done although everything has been provided
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 22nd March 2012 at 10:28. |
22nd March 2012, 10:39 | #19115 | Link |
MPC-HC Helper xD
You do know that only Aleksoid and v0lt are doing bigger scale commits and if they haven't merged BE mod yet ... means either they're not interested in doing that or they don't feel it's ready to be merged or maybe they don't use it so they won't bother adding features stuff they won't be even using. Rest of the bunch is more or less MIA.
22nd March 2012, 11:16 | #19116 | Link | |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
22nd March 2012, 11:22 | #19117 | Link |
I think i found out what caused the black screens with DXVA and certain Decoder i though have no idea yet why ffdshow triggers this in MPC-HC if set in a certain Prefer order but im sure it is the cause and it's not because uncompressed rendering is active and it takes over it that's disabled but anyways its causing a black screen if i block it instead of prefer it's ok though it doesn't show up in the graph @ all that's the very strange thing about it it seems the graph build up normally but with ffdshow preferred in the order the Decoder even loaded before (in this case Cyberlinks VC-1 DXVA) fails with a black screen.
The most funny thing about it in the order Cyberlinks Decoder is even above ffdshow (preferred before ffdshow is preferred) but anyways ffdshow causes this black screen result if i block it no black screen anymore though the used Chain remains the same for both (prefer/block), though the splitter is bellow both as preferred.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 22nd March 2012 at 11:42. |
22nd March 2012, 11:40 | #19119 | Link | |
MPC-HC Helper xD
So until there's some developer that is willing to work on merging of an BE mod and do what XhmikosR said on #1598, merger is out of the question. |
