1st January 2005, 04:50 | #101 | Link |
Country Member
DVD Decrypter gets rid of all the CSS, Macrovision and PUOPs etc.
The RE2 thing has to do with protected sectors and unreferenced material. This also affects Shaun of the Dead. VobBlanker can get rid of the running man etc, because it is unreferenced material and by default, VobBlanker rather neatly ignores it. (@jsoto - please never change this!!!!). Once decrypted in DVD Decrypter using the PSL file, run the whole disk with VobBlanker and all the unreffed will be gone. No problems compressing and burning after that. Regards and HNY
Les Only use genuine Verbatim or Taiyo Yuden media. Last edited by blutach; 1st January 2005 at 04:54. |
1st January 2005, 17:34 | #102 | Link | |
member
so can vobblanker make dinner for me too?(i'm convinced that photoshop can make breakfast. just need dinner)
some guides |
1st January 2005, 17:58 | #103 | Link | |
4th January 2005, 04:43 | #104 | Link |
PGC Navigator in Training
@jsoto
In the Cell List dialog, you have this button. Say I extracted one PGC to a temp folder. I got VTS_01_001.VOB to VTS_01_018.VOB. I want to extract another PGC to this folder too and append my files so my next starting VOB should be VTS_01_019.VOB. It won't let me do it. I've renamed the file in save dialog but it's dead set to save it as VTS_01_001.VOB and then ask me to overwrite.
2COOL |
7th January 2005, 21:14 | #105 | Link |
Just a Member
OK. Seems not difficult. I take it into account for the next version
jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
8th January 2005, 10:15 | #108 | Link | |
Just a Member
jsoto BTW: No much blue there, eh?
10th January 2005, 13:25 | #110 | Link |
Country Member
@jsoto
Can you please explain what the "fix elapsed time replacing cells" is all about. I have read the help file, but am still a bit confused. Should I have it ticked (the help file indicates "it's not really needed") when I cut a PGC? Regards
Les Only use genuine Verbatim or Taiyo Yuden media. Last edited by blutach; 10th January 2005 at 13:32. |
10th January 2005, 16:11 | #111 | Link |
Just a Member
No, you do not need to tick it when cutting PGCs. It only affects when replacing cells (not PGCs, only individual cells)
I'll try to explain what it means.. AFAIK, a cell must start with Elapsed time counter cleared (zero) in its first Nav pack (first VOBU of the cell). But if you manually cut a cell to start in a VOBU in the middle, you will have a cell with this counter not cleared in its first VOBU. And, if you want to use this cell to replace an existing cell in a PGC, VobBlanker will reset the counter in the first VOBU and will "adjust" this counter(substracting the value taken from the first VOBU) in all VOBUs of the whole cell. When cutting PGCs, this action is automatically done if needed (when the first part of the cell is deleted), and you cannot disable it in the GUI. Cell Elapsed time is offset 0x0045 and 0x0413 in the Nav Pack. You can see it with VobEdit. jsoto
13th January 2005, 11:55 | #112 | Link |
reMember
In the process of adding custom subtitles to a disc where I want to keep the menu etc., I'm about to use the PGC "Replace" function in VobBlanker.
In the VobBlanker help file it says about the replacement PGC that "cell times (and, as consequence, the chapters) should be the same than the original". Are the cell times for the new PGC imported into the disc along with the new PGC when using the replace function, or are the cell times (and audio delay) from the old PGC kept? In other words: When I create the new PGC with IfoEdit's DVD author function, is it important that I load the cell times and set the audio delay as it was in the original PGC? |
13th January 2005, 13:34 | #113 | Link | |
Just a Member
A) Use the original Celltimes.txt file (extracted with IFOEdit or pgcDemux) B) Use the original audio delay. You can correct it in the authoring phase (recommended) or you can correct it in the audio file (adding/cutting audio frames with delaycut, i.e.) and authoring with 0 msec delay. C) Use the same streams order. If you only want the audio in index 0x82, you have to mux two audios (they can be a very small silence file) to fill 0x80 and 0x81 and put your audio in the third position (0x82). The same apply for subpictures. Small silence audio files can be generated with "silence.exe" and a pseudo-empty sub can be generated with DVDSuptools. jsoto
13th January 2005, 16:30 | #114 | Link |
reMember
Ahh, so in the replacement process VobBlanker takes the info from the newly authored PGC and puts it into the original structure, which also holds the same kind of info, and thus it has to match in order to work? Right?
Hmmm, I then may have a problem with my current project: I have a disc with menus and extras that I want to keep when adding custom subs. BUT the original disc doesn't have any subs. So when I mux/author, I have to add a sub stream that wasn't there before...? |
13th January 2005, 17:34 | #115 | Link | ||
Just a Member
jsoto EDIT: The Replace feature has been designed based on the idea of replacing a PGC with the same one recoded (compressed) with CCE.
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ Last edited by jsoto; 13th January 2005 at 17:37. |
13th January 2005, 18:10 | #116 | Link | |
I wonder also if this Replace Feature could be used for reinserting audio and video streams after an Inverse Telecine processing of the original stream... It should work also in case frame count of original and reauthored streams do not match, right ? ... |
13th January 2005, 18:40 | #117 | Link | |
Just a Member
jsoto
13th January 2005, 20:02 | #118 | Link | ||
reMember
13th January 2005, 20:24 | #119 | Link | |
Cheers, SD |
14th January 2005, 07:03 | #120 | Link |
@jsoto
I just did Troy with the default R Change post to precomm (Safely). Code:
BEFORE VTST 1 , 4 TTN 4 (0:07) Title 4 - Chapters: 1, Programs: 1, Cells: 1 ********** pre commands: [00 A1 00 06 00 01 00 10] 1 if ( gprm(6) == 1 ) then { Goto line 16 } . . [71 00 00 07 00 00 00 00] 28 Set gprm(7) =(mov) 0 ********** post commands: [71 00 00 07 00 00 00 00] 1 Set gprm(7) =(mov) 0 [61 00 00 08 00 80 00 00] 2 Set gprm(8) =(mov) sprm(0:Preferred menu language) [00 A1 00 08 66 72 00 05] 3 if ( gprm(8) == 26226 ("fr") ) then { Goto line 5 } [30 05 00 01 00 01 00 00] 4 (JumpVTS_PTT) Jump to TTN 1, Chapter 1 [30 05 00 01 00 05 00 00] 5 (JumpVTS_PTT) Jump to TTN 5, Chapter 1 ********** cell commands: AFTER ********** pre commands: [00 A1 00 06 00 01 00 10] 1 if ( gprm(6) == 1 ) then { Goto line 16 } . . [71 00 00 07 00 00 00 00] 28 Set gprm(7) =(mov) 0 [71 00 00 07 00 00 00 00] 29 Set gprm(7) =(mov) 0 [61 00 00 08 00 80 00 00] 30 Set gprm(8) =(mov) sprm(0:Preferred menu language) [00 A1 00 08 66 72 00 05] 31 if ( gprm(8) == 26226 ("fr") ) then { Goto line 5 } [30 05 00 01 00 01 00 00] 32 (JumpVTS_PTT) Jump to TTN 1, Chapter 1 [30 05 00 01 00 05 00 00] 33 (JumpVTS_PTT) Jump to TTN 5, Chapter 1 ********** post commands: ********** cell commands: Code:
[00 A1 00 08 66 72 00 21] 31 if ( gprm(8) == 26226 ("fr") ) then { Goto line 33 }
2COOL Last edited by 2COOL; 14th January 2005 at 07:06. |
