Old 24th July 2008, 03:45   #21  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by Sharktooth View Post
3 was chosen for DXVA or other HW compatible presets.
Unrestricted presets have more refs, expecially the anime one.
Isn't the limit 4, not 3, for 1080p 4.1?
Old 24th July 2008, 03:49   #22  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
dunno i threw a random number (3, but it could have been 4 as well) coz i lost the presets and i didnt remember if it was 3 or 4... or whatever. my memory is really short lately...
edit: the limit depends on the DPB size.
Old 24th July 2008, 05:07   #23  |  Link
smackbadger
Shouldn't PSP be under PortableDevice, since PSP=PlayStation Portable right?
smackbadger is offline   Reply With Quote
Old 24th July 2008, 10:37   #24  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Originally Posted by saint-francis View Post
I'm one of those people. I often (about once a week or so) use the HQ insane profile.
what is the real gain to use a such preset ?
Old 24th July 2008, 10:41   #25  |  Link
yesgrey
not recommended means the encoder can do much better with 2 passes but... if you need really FAST encoding an have bitrate limits, you can ignore the 'Not recommended'.
I think it would be a good idea including this as a note in the first post. It's better have all the relevant info there, and this question will arise more often... After a few thread pages the people will only look at the first post, nothing more...
Old 24th July 2008, 10:55   #26  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
yes, i added the info.
@smackbadger: yes, was already there... i just pasted the wrong name.
Old 24th July 2008, 11:22   #27  |  Link
canTsTop
canTsTop's Avatar
what is difference between DXVA and PS3-Xbox360 presets? isn't this the same thing?
canTsTop is offline   Reply With Quote
Old 24th July 2008, 11:50   #28  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
buffers.
Old 24th July 2008, 12:40   #29  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
Why not combine the 'portable devices' and 'standalone' categories into a 'hardware players' or similar category? The split between them is a little arbitrary.
check is offline   Reply With Quote
Old 24th July 2008, 13:12   #30  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
could be an idea. but id like to keep them separated.
Old 24th July 2008, 14:14   #31  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
EDIT: moved to the first post.
Old 24th July 2008, 14:53   #32  |  Link
kurt
sidekick
kurt's Avatar
edit: the limit depends on the resolution.
jap, it's 4 for 1920x1088, look here....
btw: thanks for all your efforts, these presets are much appreciated!
btw2: when driving with Popcorn Hour, I should stick with Standalone-PS3-Xbox360, right?
greets, kurt.
Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC
kurt is offline   Reply With Quote
Old 24th July 2008, 14:55   #33  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
i left 4 refs for HD even if some old DXVA video cards/drivers do not support 4. for the same reason i thought to take out b-pyramid but i didnt.
btw2: dunno... but if you find any info about the exact playback capabilities i can make a preset...
Old 24th July 2008, 15:17   #34  |  Link
saint-francis
too much lurking
saint-francis's Avatar
Using crf I have consistently noticed a 3-7 % reduction in size as compared to using a profile like HQ Slow. Using HQ Insane it only takes about 4-6 hours for me to encode the average DVD (depending on the .avs). I don't use such settings on HD content. I did once and it took over 24 hours.
saint-francis is offline   Reply With Quote
Old 24th July 2008, 15:19   #35  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Almost none, really. It's just for the ppl that want to "squeeze even the last drop of juice from the fruit", no matter how much time it takes.
Old 24th July 2008, 15:29   #36  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Presets updated. If you have V50 please download V51.
Old 24th July 2008, 15:53   #37  |  Link
TheRyuu
warpsharpened
All anime/toons of all presets groups have Psy-RDO DISABLED and a higher deblocking filter values.
I think anime should have 0:0 deblocking and toon 1:1 but that's just me. Good anime has detail you know.
The same can be said about possibly using psyRDO in anime to keep fine details (possibly gradients, or gradfun gradients, or even some noise).
Edit: Why is no-dct-decimate on with anime/toon. Shouldn't that be off?
TheRyuu is offline   Reply With Quote
Old 24th July 2008, 15:57   #38  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
1,1 is the same as the old AE presets. no one ever complained. 0,0 and 1,1 difference is almost unnoticeable.
Old 24th July 2008, 16:16   #39  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
another update. V52. Re-download. Now it's all in the first post.
Old 24th July 2008, 17:15   #40  |  Link
kurt
sidekick
kurt's Avatar
i left 3 refs for HD since some old DXVA video cards do not support 4.
PCH uses the same Sigma Chip as PS3 (8635) but is limited in RAM of course. I'll try to find out the max settings... lately I was driving with this commandline very well (720p encodes though):
--pass 2 --bitrate 4500 --stats ".stats" --level 4.1 --ref 3 --mixed-refs --bframes 3 --b-rdo --bime --weightb
--direct auto --nf --subme 6 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --ipratio 1.1 --pbratio 1.1
--vbv-bufsize 9000 --vbv-maxrate 24000 --qcomp 0.5 --me umh --merange 12 --threads auto
--thread-input --progress --no-psnr --no-ssim --output "output" "input"
any hints what to change (for maxing out)?
greets, kurt.
megui, x264 presets
