Old 11th August 2006, 00:19   #421  |  Link
carlo_0000
hy i don't know if i must post here but i have a strange problem on 1 hdtv mpeg2 what i try to convert to x264
using last megui with x264 in (mp4)
the source is a mpeg2 hd 1920*1088 from euro1080 channel (record in 2003)
the mpeg is 4.17 long
extract the audio it's olso 4.17 long
but when the video is converted to mp4
: the video is only 3.37 long
so i m not able to add the audio stream in my mkv what is 4.17 long
i convert over's hdmpeg to x264 without this problem
carlo_0000 is offline   Reply With Quote
Old 11th August 2006, 00:21   #422  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
does megui produce any error logs? More information please.
ChronoCross is offline   Reply With Quote
Old 11th August 2006, 00:30   #423  |  Link
carlo_0000
no there was no error
oups no was with virtualdub
just finish a segond 1 with megui same problem video is shorter than the audio stream
but i think i found the problem
i openned in virtualdub the mpeg2 has 1920x1088 @ 25fps
end the mkv has 23.972fps
why it s not the same ? or is not that the problem?
edit: or maybe is this a error ?
Log for job job9-1
avis [info]: 848x464 @ 23.98 fps (5143 frames)
x264 [warning]: VBV maxrate specified, but no bufsize.
x264 [info]: using cpu capabilities MMX MMXEXT SSE 3DNow!
x264 [info]: slice I:40 Avg QP:18.02 size: 34667
x264 [info]: slice P:2864 Avg QP:19.60 size: 11813
x264 [info]: slice B:2239 Avg QP:21.70 size: 3883
x264 [info]: mb I I16..4: 34.2% 42.7% 23.2%
x264 [info]: mb P I16..4: 9.8% 8.9% 2.3% P16..4: 34.0% 16.1% 3.7% 0.6% 0.3% skip:24.4%
x264 [info]: mb B I16..4: 0.5% 0.4% 0.1% B16..8: 47.5% 1.6% 3.9% direct: 1.3% skip:44.8%
x264 [info]: 8x8 transform intra:42.1% inter:43.6%
x264 [info]: kb/s:1637.8
encoded 5143 frames, 0.71 fps, 1637.84 kb/
edit: i don't thinks that is the problem, i see 1 other video what was 29fps mpeg ntsc to 23.9fps x264 end the video is correct
but why meGui conver 25fps to 23.9 ?
Old 11th August 2006, 03:15   #424  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
the problem is being discussed here: http://forum.doom9.org/showthread.php?t=114365
workaround: revert to DGIndex 1.4.7
Old 11th August 2006, 03:59   #425  |  Link
carlo_0000
ok thanks
i try to instal the previous version
i have an other question:
why is mine p4 2ghz a lot slower with encoding to x264 than mine duron 1.8ghz ? +- 30% slower
Old 11th August 2006, 22:51   #426  |  Link
lexor
I have a question regarding that dgindex issue, it's only for PAL right? so if I work with NTSC I don't have to downgrade?
Also is there any setting (or xml file) where I can force mkv to be a default container? I would never use mp4 or avi for anything I do, and changing it every time starting to get on my nerves.
Geforce GTX 260
Windows 7, 64bit, Core i7
MPC-HC, Foobar2000
lexor is offline   Reply With Quote
Old 12th August 2006, 19:50   #427  |  Link
Doom9
clueless n00b
There's no need to downgrade dgindex.. just get the latest megui version.. I fixed the bug yesterday.
Doom9 is offline   Reply With Quote
Old 13th August 2006, 13:05   #428  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
i know, infact now you can just let megui auto-update and everything will work.
Old 13th August 2006, 16:37   #429  |  Link
lexor
umm... anthing regarding my second question?
Geforce GTX 260
MPC-HC, Foobar2000
Old 13th August 2006, 16:45   #430  |  Link
Doom9
clueless n00b
no, defaults for the autoencode will come at some point but they're not there right now.
Old 15th August 2006, 10:58   #431  |  Link
ricardo.santos
ricardo.santos's Avatar
Hi everyone.
Ive been wanting to test Megui output using xvid and x264 for a while but everytime i tried it shows error messages
Since i have other programs that do that those error messages never bothered me.
With the growth of Megui "fan database" i decided once again to test it but the error messages poppd up again
one of them said "color matrix" when tryng to open preview window to crop video
heres another one
ricardo.santos is offline   Reply With Quote
Old 15th August 2006, 12:09   #432  |  Link
Doom9
clueless n00b
Can you please describe the steps you took after launching megui?
Old 15th August 2006, 16:41   #433  |  Link
ricardo.santos
1- Tools>>>D2V CREATOR>>>Queue>>>Start
2-Tools>>>Avisynth script creator>>>Load d2v>>>AutoCrop>>>>error message>>>>press ok
Line 2 on script:
ColorMatrix(hints=true)
3-load avisynth script>>>load audio track>>>configure audio>>>>configure xvid>>>automated 2pass>>>enque>>>>Fatal Error message
Old 15th August 2006, 17:12   #434  |  Link
ricardo.santos
i removed the 2nd line of the script and it worked.
Going to try it using x264(the reason why i want to use Megui), will let you know how it goes
Old 15th August 2006, 19:46   #435  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Did you run the updater first? That'll add colormatrix to avisynth - obviously if it isn't there it won't work. Assuming your avisynth path is correct.
Old 15th August 2006, 20:15   #436  |  Link
chadamir
whenever I try to run therogram I get the error "application failed to initialize properly (0xc0000005). Clcik on ok to terminate the application."
I have the .net installed. and everything is up to date.
chadamir is offline   Reply With Quote
Old 15th August 2006, 20:17   #437  |  Link
Doom9
clueless n00b
@ricardo.santos: now do you still get that error or is everything working out? You can't quite count the second error if you get one before..
Old 15th August 2006, 21:03   #438  |  Link
chipzoller
Mr. Woof
chipzoller's Avatar
I'm not sure if this is a bug or if I'm just stupid...
If I have a job processing in megui (x264 2 pass-auto) and add another with a script that contains: vobsub("subs.idx"), megui crashes and I see nothing in the log. Or rather to be more precise, megui hangs (but displays the burn-in subs in the preview window) when adding the job to the queue. Inside the .idx file I turned ON forced subs for a given sub channel. I realize I haven't given much hard fact here, but if this sounds like a familiar problem I'll investigate further.
chipzoller is offline   Reply With Quote
Old 15th August 2006, 22:26   #439  |  Link
Doom9
clueless n00b
I take it as soon as you remove the subs it works like a charm, correct? And I also take it that the script's colorspace is not YV12 once you've added the subs. x264's input needs to be YV12
Old 15th August 2006, 22:57   #440  |  Link
chipzoller
Mr. Woof
chipzoller's Avatar
Correct.
The issue here is with megui as it hangs before calling x264.exe.
megui
