25th May 2006, 13:36 | #1021 | Link | ||
Half of bugs have caught, there was second half =))))
Use raw-aac in autoencode it`s bad idea - mp4box don`t understand raw-aac: Quote:
If in autoencode choose necessary bitrate - then "Files Size" - will be real size*1000: Bitrate put 1700kbit, size has calculated 40482mb =))) Quote:
25th May 2006, 13:46 | #1022 | Link | |
BluRay Maniac
25th May 2006, 15:18 | #1023 | Link |
Yes i use Nero aac - but after autoencode files with "aac" extension (actually mp4 but with "aac" extension =)))
And mp4box don`t understand these files (MP4Box - 20060519). Last edited by sp@rrow; 25th May 2006 at 15:22. |
25th May 2006, 18:08 | #1024 | Link | |
The Internet: where men are men, women are men, and children are FBI Agents |
25th May 2006, 19:04 | #1025 | Link | |
BluRay Maniac
@dimzon Can you manage to use only mp4 containers for all Nero, CT, FAAC, because is more flexible Thanks |
25th May 2006, 21:00 | #1026 | Link |
Guys, please take a look at this http://img345.imageshack.us/my.php?i...ppening8qj.jpg
First look at what error MeGUI is giving & then look in the background & please tell me why is this happening? Happend 3-4 times, everytime it gives the same error. Why can't it find it when it is right there.
i7-2600 | GA-B75-D3V | Tempest EVO | VX450 & XMS3 16GB | SanDisk Extreme 120GB | U2311H | MK520 | MSI GTX750 Ti Gaming | CM Hyper 212+ | APC 1KVA | Xonar DG | SoundSticks III | Win 7 x64 Last edited by Avish; 25th May 2006 at 21:02. |
25th May 2006, 21:05 | #1027 | Link |
Curious BetaTester
using 0.2.3.2153 24 May 2006
just tested the CT AAC and got an error, Job completed successfully and deletion of intermediate files is activated Starting job job1 at 20:59:34 calling setup failed with error Can't find encoder D:\Utils\AV\DVD\Me.GUI\tools/encaacplus\encaacplus.exe, please check settings! so had to change the path to: D:\Utils\AV\DVD\Me.GUI\tools\encaacplus\enc_aacPlus.exe and it found it ok
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
25th May 2006, 21:24 | #1028 | Link |
Brazilian Anime Ripper
I did some tests with neroencaac.exe in ABR mode. I can't mux when I do autoencode but I can do separate jobs to encode video (2passes) and other to mux audio (encoded previously with SNG 0.71) and video.
The final file is OK.
Capture cards: Compro VideoMate Gold+ (Philips SAA7134 based) (not active) Hauppauge PVR 150MCE (not active) ATI TV Wonder Elite (active) |
26th May 2006, 02:45 | #1029 | Link | |
Mr. Sandman
EDIT: to fix encaacplus.exe -> enc_aacPlus.exe you have to delete your settings.xml file and let megui recreate it... you obviously need to set the paths again. you can also uninstall megui, clean the folder and reinstall from a newer version package.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 26th May 2006 at 03:02. |
26th May 2006, 10:40 | #1030 | Link |
Guys, please help me out here!! I've put the "enc_aacplus.dll" in appropriate folder, that is "C:\Program Files\megui\tools\encaacplus" where "enc_aacPlus.exe" is also present, but still meGUI gives me error "Can't find enc_aacplus.dll!"
What is going wrong here? Have I put "enc_aacplus.dll" in wrong place? Here is the screenshot http://img345.imageshack.us/my.php?i...ppening8qj.jpg
i7-2600 | GA-B75-D3V | Tempest EVO | VX450 & XMS3 16GB | SanDisk Extreme 120GB | U2311H | MK520 | MSI GTX750 Ti Gaming | CM Hyper 212+ | APC 1KVA | Xonar DG | SoundSticks III | Win 7 x64 |
26th May 2006, 11:48 | #1031 | Link |
you could always do as sharktooth suggests - as i had the same prob with the \ and / and his solution worked for me (shame the bitrate calc still hoosed)
The Internet: where men are men, women are men, and children are FBI Agents Last edited by Carpo; 26th May 2006 at 11:59. |
26th May 2006, 13:07 | #1032 | Link | |
BeHappy/MeGUI developer
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
26th May 2006, 15:10 | #1033 | Link |
Mr. Woof
In 0.2.3.2155 when I create a job using x264 and neroaacenc (selecting MP4-AAC as the audio output) and use the autoencode button, it spits out a .aac file and not a .mp4 for the audio (even though it SEEMS to be muxing correctly now). If I create an audio job with the same settings and choose MP4-AAC as the output, it outputs a .mp4 file.
I'm still experiencing slow-downs in this version compared to previous ones. Let me know what I can provide that would help. EDIT: I take that back...the .aac file it outputs is not playable at all, and the muxed video rightly will not playback the audio. In fact, this is what MediaInfo 0.7.2.1 reports about the muxed file: Audio #0 Codec : MPEG-2 Audio Bit rate : 154 Kbps Channel(s) : 5 channels Sampling rate : 7 KHz Contrary to what it says about the single .aac file (encoded from DVD AC3 audio): Audio #0 Codec : AAC LC Bit rate : 75 Kbps Channel(s) : 2 channels Sampling rate : 48 KHz PlayTime : 1h 34mn Last edited by chipzoller; 26th May 2006 at 15:17. |
26th May 2006, 15:28 | #1034 | Link | |
26th May 2006, 15:29 | #1035 | Link |
What's in a name dude !
1.in megui, in x264 encoding, if i configure 2-pass-1st pass, i cannot enqueue it, as it says output is not mp4
2.if i chose a high bitrate, and do 2-pass automatic , then at 2nd pass it automatically lowers the bitrate, i see it in log. are these bugs anyone else seen? |
26th May 2006, 15:35 | #1036 | Link |
Mr. Sandman
both confirmed.
bug nr.2 seems megui doesnt always update the selected profile...
26th May 2006, 15:39 | #1037 | Link | |
Mr. Woof
The important thing right now is the issue with the audio. |
26th May 2006, 16:25 | #1038 | Link |
<The VFW Sheep of Death>
0.2.3.2155.
When I select a profile for x264 and hit config, it sometimes loads the wrong profile for editing, so I must manually select the profile again to edit it. Certainly not a fatal bug, but it can be annoying in a list of many profiles I've noticed this issue since .2153, maybe before.
Recommended all-in-one stop for x264/GCC needs on Windows: Komisar x264 builds! |
26th May 2006, 16:42 | #1039 | Link | |
0.2.3.2155
I have the same bug than sp@rrow with filesize and autoencode, my settings : - Create an AviSynth script, i edit it to remove audio=false - Set codec to x264, container mkv, profile AE-Standard - AviSynth script as Audio Input, codec ND AAC Q=0.34, container MP4-AAC - Autoencode with filesize = 140 MB Quote:
And in update window, controls are not resized with the window |
26th May 2006, 16:51 | #1040 | Link | |
