Old 24th January 2006, 00:48   #261  |  Link
berrinam
berrinam's Avatar
Originally Posted by Richard Berg
3) Have some jobs going. Dragdrop a d2v file and queue the index job. The d2v creator dialog will sit there, and the rest of MeGUI will be unresponsive, until you kill it. Waiting for the index job would probably work too, but that might be days away...
I can't reproduce this. You do realise that you have to close the d2v creator after you have created the job, right? (For some reason, the close checkbox isn't displayed there).
berrinam is offline
Old 24th January 2006, 00:59   #262  |  Link
Richard Berg
developer wannabe
Richard Berg's Avatar
I've never worked with d2v files before, and all of my MeGUI instances are running long jobs so I can't test in a state w/ empty queue. Is the Queue button never supposed to dismiss the dialog? If so, what's the intended scenario? Queuing the same idx job several times?
Richard Berg is offline
Old 24th January 2006, 01:23   #263  |  Link
berrinam
berrinam's Avatar
Opening the D2V creator through the menu gives you a checkbox which says 'and close', next to the Queue. When in dialog mode, this doesn't exist, which seems ot be the wrong behaviour. The reason there are all these variations is that there are 4 ways of opening the D2V creator window:
1. Menu (has the 'and close' checkbox)
2. Load an index job (closes when you press update. Has no 'and close' checkbox)
3. Select an mpeg2 file in the AviSynth Script Creator (I think this closes when you press queue)
4. Drag-n-drop (doesn't close and doesn't have the 'and close' checkbox. This is the bug)
berrinam is offline
Old 24th January 2006, 03:34   #264  |  Link
berrinam
berrinam's Avatar
Originally Posted by Doom9
I think so to. I think the breaking change has been introduced in 1.4.6 beta 3 (http://forum.doom9.org/showthread.ph...522#post764522) so if you could try to create your project again using an older beta (or just the latest stable version) and verify that it works there, that would be much appreciated.
I would imagine this would also cause problems with auto force film, as the fps is indicated slightly differently in the d2v file. Time to change the auto force film code, and boost the required DGMPGDec version to 1.4.6 beta 3 or later, then. What do you think?
berrinam is offline
Old 24th January 2006, 03:54   #265  |  Link
berrinam
berrinam's Avatar
Originally Posted by puffpio
Using megui 0.2.3.2033
When loading an avs file into the program, then going into the bitrate calculator, the video length, framerate, and framecount is incorrect
This occurs both when I loaded an avs script taht was @ 29.97fps and also at 23.97fps. In both cases the framerate the bitrate calculator displayed was 25fps, and the video length was short by a couple minutes.
It used to work correctly a couple versions ago...maybe I need to delete some configuration files?
Can you test this in 0.2.3.2041 when it is released? I _think_ I fixed it there, but your testing again would be appreciated.
berrinam is offline
Old 24th January 2006, 06:30   #266  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
I only use the official finals. I don't want to encounter double the bugs lol. but if you up it I guess I'll have no choice.
ChronoCross is offline
Old 24th January 2006, 07:05   #267  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
DG has stated that he doesn't believe in differentiating between a beta and final version, he just increments the number when he feels enough features have gone in to warrant it. Thus some of his are permanent betas.
Just to make sure it didn't get overlooked:
The current --filter syntax is incorrect. MeGUI outputs something like -2,3, but the proper syntax is -2:3, and given -2,3 x264 will always reuse the first argument, thus -2,3, -2,-6, and -2,0 are all equivalent to -2:-2.
foxyshadis is offline
Old 24th January 2006, 11:42   #268  |  Link
L4z4rus
L4z4rus's Avatar
Hi, I've just done a CVS update, but I get the following error when trying to compile? (I haven't had any problems in the past) Last working version I compiled was 0.2.3.2037 yesterday:
Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42
for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727
Copyright (C) Microsoft Corporation 2001-2005. All rights reserved.
AviSynthAudioEncoder.cs(635,7): error CS1024: Preprocessor directive expected
AviSynthAudioEncoder.cs(647,7): error CS1024: Preprocessor directive expected
Form1.cs(3282,10): warning CS1030: #warning: 'dimzon'
neroraw\neroraw.cs(60,27): error CS0017: Program
        'c:\meGUI\MeGUI-src.CVS\megui.exe' has more than one entry point
        defined: 'MeGUI.NeroRawAacEncoder.Main(string[])'
Form1.cs(2702,15): error CS0017: Program 'c:\meGUI\MeGUI-src.CVS\megui.exe' has
        more than one entry point defined: 'MeGUI.MeGUI.Main()'
Press any key to continue . . .
L4z4rus is offline
Old 24th January 2006, 12:04   #269  |  Link
The Link
The Link's Avatar
@L4z4rus: Just remove the neroraw folder and try again or make a new cvs checkout since Dimzon seems to have fixed this compilation bug.
When birds burp, it must taste like bugs! (Calvin&Hobbes)
The Link is offline
Old 24th January 2006, 12:26   #270  |  Link
L4z4rus
L4z4rus's Avatar
@The Link:
Thanks, still no luck - tried removing neroraw, no success, & made a new cvs checkout, still getting the same error log....
Update: worked out the problem, I'd checked all the files in the error had updated except for compile.bat, I'll try & update again in a bit as its still currently giving me an older version.
L4z4rus is offline
Old 24th January 2006, 12:28   #271  |  Link
The Link
The Link's Avatar
Strange ... when I removed the neroraw folder compiling worked here. Dimzon said that he commited the fix (http://forum.doom9.org/showthread.ph...118#post774118) but probably it takes some time till all servers are synchronized (or whatever).
The Link is offline
Old 24th January 2006, 12:39   #272  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
anonimous cvs has up to 6hrs lag
dimzon is offline
Old 24th January 2006, 13:27   #273  |  Link
L4z4rus
L4z4rus's Avatar
I'll remember to allow for the CVS delay in the future...
...Bugger....now i've managed to update to latest CVS changes I get a new error (compile.bat rev1.5; AviSynthAudioEncoder.cs rev1.3; AvisynthWrapper.cs rev1.1):
AvisynthWrapper.cs(360,7): warning CS0162: Unreachable code detected
AvisynthWrapper.cs(363,7): warning CS0162: Unreachable code detected
AvisynthWrapper.cs(366,7): warning CS0162: Unreachable code detected
AvisynthWrapper.cs(369,7): warning CS0162: Unreachable code detected
AvisynthWrapper.cs(372,7): warning CS0162: Unreachable code detected
AvisynthWrapper.cs(375,7): warning CS0162: Unreachable code detected
AviSynthAudioEncoder.cs(695,13): warning CS0618:
        'System.Threading.Thread.Suspend()' is obsolete: 'Thread.Suspend has
        been deprecated.  Please use other classes in System.Threading, such as
        Monitor, Mutex, Event, and Semaphore, to synchronize Threads or protect
        resources.  http://go.microsoft.com/fwlink/?linkid=14202'
AviSynthAudioEncoder.cs(702,13): warning CS0618:
        'System.Threading.Thread.Resume()' is obsolete: 'Thread.Resume has been
warning CS1607: Assembly generation -- The version '0.0.1.*' specified for the
        'file version' is not in the normal 'major.minor.build.revision' format
L4z4rus is offline
Old 24th January 2006, 13:31   #274  |  Link
dimzon
dimzon's Avatar
there are no error word @ output, there are only warning isn't it So don't worry about this warnings.
dimzon is offline
Old 24th January 2006, 13:52   #275  |  Link
L4z4rus
L4z4rus's Avatar
@Dimzon
Thanks - I'm having an idiot day today , i've just spotted the binaries in my CVS folder
L4z4rus is offline
Old 24th January 2006, 18:45   #276  |  Link
dumbas..
Its all in the name....
Megui mp4 output error
1. Checked for thread reports non found so forgive if repeated or in wrong thread.
Objective:
Test Megui and staxrip for most suitable gui for EPISODE DVD use.
Player Media Player classic 6.4.8.7
Fdshow ver 29 November
x264 set to use libravic
Both gui's using same vob sample
Stax rip:
output > playable >all ok
Megui
created aac audio frorm vob clip in mp4 container > playable
created video from vob to mp4 >playable
BUT when I mux above > error reported See END OF LOG
log:
Starting job job2 at 17:14:35
Job is a dgindex job. dgindex commandline:
"C:\MY PROGRAMS\VIDEO\StaxRip\Applications\DGIndex\DGIndex.exe" -AIF=[C:\Documents and Settings\Brian\My Documents\DVD\VTS_07_1.VOB] -OF=[C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\dgindex] -exit -OM=2
successfully set up dgindex
Processing ended at 17:14:36
Log for job job2
Starting job job1 at 17:18:35
Job is an audio job. Commandline:
-core( -input "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\dgindex T01 3_2ch 448Kbps DELAY 0ms.ac3" -output "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui audio.mp4" -logfile "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui audio.besweet.log" ) -azid( -s stereo -c normal -L -3db ) -dimzon( -dllname bse_FAAC.dll -q 100 ) -ota( -g max )
successfully started encoding
Processing ended at 17:18:40
Log for job job1
BeSweet v1.5b30 by DSPguru.
[00:00:00:000] Initializing...
[00:00:00:000] -- Initializing...
[00:00:34:016] |
[00:00:34:016] Finalizing...
[00:00:34:016] Conversion Completed !
Visit DSPguru's Homepage at :
http://DSPguru.doom9.net/
Starting job job2-1 at 17:18:40
Job is a video job. encoder commandline:
--pass 1 --bitrate 1161 --stats "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\avisynth.stats" --bframes 2 --b-pyramid --nf --subme 1 --analyse none --me dia --progress --no-psnr --output NUL "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\avisynth.avs"
Processing ended at 17:19:03
Log for job job2-1
avis [info]: 640x272 @ 25.00 fps (851 frames)
x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2 3DNow!
x264 [info]: slice I:6 Avg QP:17.33 size: 10569
x264 [info]: slice P:552 Avg QP:19.08 size: 6761
x264 [info]: slice B:293 Avg QP:23.26 size: 2729
x264 [info]: mb I I16..4: 66.0% 0.0% 34.0%
x264 [info]: mb P I16..4: 41.6% 0.0% 0.0% P16..4: 43.7% 0.0% 0.0% 0.0% 0.0% skip:14.7%
x264 [info]: mb B I16..4: 2.3% 0.0% 0.0% B16..8: 29.8% 0.0% 0.0% direct:14.3% skip:53.5%
x264 [info]: final ratefactor: 20.68
x264 [info]: kb/s:1079.9
Actual bitrate after encoding without container overhead: 1080.13
job job2-1 has been processed. This job is linked to the next job: job2-2
Starting job job2-2 at 17:19:03
--pass 2 --bitrate 1161 --stats "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\avisynth.stats" --bframes 2 --b-pyramid --bime --weightb --nf --trellis 1 --analyse p8x8,b8x8,i4x4,p4x4 --progress --no-psnr --output "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui video.mp4" "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\avisynth.avs"
Processing ended at 17:19:56
Log for job job2-2
mp4 [info]: initial delay 2 (scale 25)
x264 [info]: slice I:6 Avg QP:17.17 size: 7830
x264 [info]: slice P:552 Avg QP:18.73 size: 6778
x264 [info]: slice B:293 Avg QP:22.40 size: 3842
x264 [info]: mb I I16..4: 68.5% 0.0% 31.5%
x264 [info]: mb P I16..4: 30.3% 0.0% 15.8% P16..4: 20.4% 10.0% 5.3% 1.3% 0.9% skip:15.9%
x264 [info]: mb B I16..4: 2.6% 0.0% 2.0% B16..8: 31.4% 2.9% 7.1% direct: 9.0% skip:45.0%
x264 [info]: kb/s:1155.0
Actual bitrate after encoding without container overhead: 1155.16
desired video bitrate of this job: 1161 kbit/s - obtained video bitrate: 1157.18942420682 kbit/s
Starting job job3 at 17:21:19
Job is a mux job. Commandline:
-add "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui video.mp4" -add "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui audio.mp4":lang=eng -new "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui video and audio muxed.mp4"
successfully set up muxer
Processing ended at 17:21:19
Log for job job3
IsoMedia import - track ID 1 - Video (size 640 x 272)
Unknown input file type
Error importing C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui audio.mp4:lang=eng: Feature Not Supported
(Feature Not Supported)
As a test I muxed the .264 and aac output from staxrip through the Megui muxer to MP4 Result >PLAYABLE
THEREFORE megui muxing works (but with Staxrip output files)
Confused NEW user needs tea and sympathy
I MUST be doing something daft here so be gentle!
I would like to use Megui 'cause it will queue episodic DVD conversion.
dumbas.. is offline
Old 24th January 2006, 19:23   #277  |  Link
Richard Berg
developer wannabe
Do you have the latest version of mp4box?
Old 25th January 2006, 00:01   #278  |  Link
ChronoCross
CVS works great. Thanks guys.
Old 25th January 2006, 00:25   #279  |  Link
dumbas..
@Richard Berg
Thanks
Well I have the version dated 8/11/2005
Not sure how to acertain the version number
I tried the latest release from
http://www.aziendeassociate.it/cd//gpac/dev/MP4Box.7z
dated 03 January 2006
It crashes out with a windows error
AppName: mp4box.exe AppVer: 0.0.0.0 ModName: mp4box.exe
ModVer: 0.0.0.0 Offset: 0005c867
The MeGui log is none the wiser:
Muxjob ended and deletion of intermediate files is activated
Starting job job2 at 23:16:29
-add "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui video.mp4" -add "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui audio.mp4":lang=eng -new "C:\Documents and Settings\Brian\My Documents\DVD\MEgui Output\megui Mux.mp4"
Processing ended at 23:16:40
Log for job job2
So I'm a bit stuck. Neither want to work!
dumbas.. is offline
Old 25th January 2006, 01:03   #280  |  Link
ChronoCross
Well I can confirm that there is a problem with the latest cvs in terms of mp4box. it doesn't seem to be a meGUI problem but rather with the compiling itself. I just compiled it and it gives the same crash error.
I'm going to try and troubleshoot it.
I still can't compile it to correctly work but here's a working version dated 1/19/06 from kurtnoise.
http://kurtnoise.free.fr/mp4tools/
