28th January 2018, 15:14 | #101 | Link |
@ocean
Thanks... so it appears they've used some of the reserved space to flag something related to HDR... now I have to figure out what the "4608" (0x1200) represents. This sure would be easier if I had the documentation. Oh well, we all have our crosses to bear I guess. Last edited by jdobbs; 28th January 2018 at 15:16. |
28th January 2018, 15:42 | #103 | Link | |
decimal 4608 hex 0x1200 binary 0001 0010 0000 0000 Last edited by jdobbs; 28th January 2018 at 15:44. |
28th January 2018, 15:53 | #104 | Link | |
You'd think "Ahh... new PIDs higher resolution PGS streams." -- but I thought I read in the White Paper I downloaded that the subtitles were still using 1080p PGS streams. I'll have to go back and make sure. Of course subtitles aren't the only thing a PGS stream can be used for... [Edit] Well... all the HDR streams I've looked at so far use the same settings of 0x1200 -- so at least I can set it to that value for testing. I would guess that one flag says "UHD" and the other says "HDR". But since there's already a format flag that gets set for 2160p and a stream coding type that calls out HEVC, the first one is certainly in question. It would help if I could find an original CLPI for a stream that isn't HDR. [Edit #2] Ok... I found one that was BT.709 and the new flag info was set to 0x0100. So I'm guessing only the first byte is really in play here. It appears that 0x12 flags BT.2020 and HDR and 0x01 flags BT.709. Still just guessing... but so far every one I've looked at is set to one of those two values. Last edited by jdobbs; 28th January 2018 at 17:30. |
28th January 2018, 19:18 | #105 | Link |
Exactly, I confirm original PGS "4768" 0x12A0 movie Rise of the Planet of the Apes CLPI, after TSMuxer and TSM2UHD PGS "4608" 0x1200:
Original "stream_PID": 4768, "stream_coding_type": "PGS", "language_code": "jpn", "reserved01": 0, "ISRC": { "country_code": "", "copyright_holder": "", "recording_year": "", "recording_number": "" after TSMuxer and TSM2UHD "stream_PID": 4608, "stream_coding_type": "PGS", "language_code": "jpn", "reserved01": 0, "ISRC": { "country_code": "00", "copyright_holder": "000", "recording_year": "00", "recording_number": "00000" edit: My apologize jdobbs, I had reversed the stream. Last edited by ocean; 28th January 2018 at 22:33. |
14th February 2018, 22:42 | #107 | Link |
Many thanks Jdobbs for your phenomenal job on Bd Rebuilder and TSM2UHD.
TSM2UHD works fine on a Sony UBP-X700 and the Xbox One S. I have the same problem than others > no HDR playing. I don't have the CLPI or playlist files because I use UHD MKV files rip recoded keeping HDR with ripbot264. Then remuxed with TsMuxer bluray structure and "converted" to UHD BD with TSM2UHD. It is possible to re-create the playlists files from a MKV or modifiy the file after remux ? When Bd Rebuilder will be "UHD HDR Ready" ? ps: sorry for my English - I'm French Last edited by manson.reznor; 14th February 2018 at 22:44. |
23rd February 2018, 10:45 | #110 | Link |
Life's clearer in 4K UHD
I've said it before... This forum could really do with a 'like' button
26th February 2018, 03:28 | #111 | Link |
v1.12
I've updated the first post of this thread with a new release (v1.12). Changes for this release:
- Added support for setting previously unknown flags that show HDR, BT.2020 and BT.709 in the CLPI file. - Minor and cosmetic changes. Last edited by jdobbs; 26th February 2018 at 18:41. |
28th February 2018, 16:48 | #117 | Link | |
wolflop |
