Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Thread Tools Display Modes
Old 27th March 2005, 03:46   #1  |  Link
D3s7
ScenAid
D3s7's Avatar
Scenaid 1.5 (build 45)
Scenaid 1.5 b45 now available for download
Fixes/Changes:
More BoV Fixes / Changes
Fix for audio files w/ odd filenames
Audio now dummied by delaycut instead of BeSplit
Pal Dummy files recreated for proper PAL AR/File size (I hope)
Dummy creation is now unique to PGC / Cell - should completely get rid of all the issues w/ palette errors
Fixes to bitrate calc routine not to error if file isn't found
Improvments to the scene allocation routines which were causing .4sec errors in Scenarist
Changes / Additions for proper datafile generation for BatchEncoder
New features:
Asset removal now works - limited to removal of video and all assets associated with - removed assets will be dummied per scene
Bitrate generation now works (Multi-Main movies do not curreently work) - please compare the bitrate you get from Scenaid to the one produced by Doitfast4u and/or RA - so far they seem fairly accurate
Errors requiring user attention are now logged to a seperate logscreen
WAV / PCM Audio is now supported
ScenAid
May just replace the dog as man's best friend
http://www.scenaid.com
D3s7 is offline
Old 27th March 2005, 07:41   #2  |  Link
jarthel
plebian
forgive me for my ignorance, but I looked at the fixes and does this include the fix where a "forced sst" file created and there are no .bmp associated with it?
Thanks
jarthel is offline
Old 27th March 2005, 09:15   #3  |  Link
buzzqw
HDConvertToX author
i run in a problem while converting sub/idx into sst file format as you can see in my discussion with Mpucoder.
http://forum.doom9.org/showthread.ph...threadid=90693
is this problem relevan to to vsconv or to muxman ?
Mpucoder say that is a common error. I don't know.
So: will vsconv update to fix this glitch ?
Thanks
BHH
P.S. : i posted in this section because i use your version of vsrip/vconv, fell free to move to another forum' section.
buzzqw is offline
Old 27th March 2005, 18:23   #4  |  Link
nicolati
Thanks a lot for your work!!!
Bye
nicolati
nicolati is offline
Old 27th March 2005, 19:48   #5  |  Link
D3s7
ScenAid
D3s7's Avatar
Thanks
I believe I already did take care of that but if not I certainly will
ScenAid
D3s7 is offline
Old 27th March 2005, 20:56   #6  |  Link
buzzqw
HDConvertToX author
i just tryed vsconv bundled with Scenaid 1.5 (build 45) and i get the same error
st_format 2
Display_Start non_forced
TV_Type PAL
Tape_Type NON_DROP
Pixel_Area (0 573)
Directory D:\dvdmagic
Subtitle 1
Display_Area (0 2 719 574)
Contrast (15 15 15 0)
PA (0 0 255 === )
E1 (255 0 0 === )
E2 (0 0 0 === )
BG (255 255 255 === )
thanks D3s7
BHH
buzzqw is offline
Old 27th March 2005, 21:41   #7  |  Link
D3s7
ScenAid
D3s7's Avatar
Try this one
ScenAid
D3s7 is offline
Old 27th March 2005, 21:53   #8  |  Link
buzzqw
HDConvertToX author
Kudos to you D3s7 !!!
now creation of sst file is perfect !!!
PA (0 0 255 = = = )
E1 (255 0 0 = = = )
E2 (0 0 0 = = = )
BG (255 255 255 = = = )
now i had just to copy subs color from ifo to ifo !! (but this is another problems )
i had succesfully muxed sst with muxman 0.12e !!
Thanks again
BHH
buzzqw is offline
Old 27th March 2005, 22:00   #9  |  Link
buzzqw
HDConvertToX author
other related question
In sst file i suppose is possible to specify subs color, isn't it ?
well, could be possible to add a parameter to pass at vsconv for copy color from another ifo ?
BHH
buzzqw is offline
Old 28th March 2005, 04:00   #10  |  Link
D3s7
ScenAid
D3s7's Avatar
vsconv doesn't look at ifo's atall... purely the .idx file you point it to....
however you can always modify the palette info in the .idx
ScenAid
D3s7 is offline
Old 28th March 2005, 08:25   #11  |  Link
buzzqw
HDConvertToX author
ok, sorry for being blatant
Thanks
BHH
buzzqw is offline
Old 28th March 2005, 13:28   #12  |  Link
jarthel
plebian
Thanks
reply would be nice. thanks
jarthel is offline
Old 28th March 2005, 15:19   #13  |  Link
D3s7
ScenAid
D3s7's Avatar
If you didn't see it in the change log then it wasn't changed....
I tested empty subs and couldn't duplicate your issue so there wasn't anything to fix from my side
Next time if you have a problem, report it before you delete the project then maybe we'll have something to work off of
ScenAid
D3s7 is offline
Old 28th March 2005, 16:59   #14  |  Link
D3s7
ScenAid
D3s7's Avatar
I forgot to mention this build also adds support for PCM/WAV files.
I'll note it in the top post as well
ScenAid
D3s7 is offline
Old 29th March 2005, 22:49   #15  |  Link
davemorell
Subtitle color table
Hi there!
First of all thank you for your great work
It looks like something messed up with the subtitle color table in this b45 version (earlier versions worked fine, 1.00, b17, b20). In the compiled (with Scenarist 3.0) movie the color table completly changed. I can handle this, but I think you may be interested...
Bye!
davemorell is offline
Old 30th March 2005, 02:43   #16  |  Link
D3s7
ScenAid
D3s7's Avatar
more then likely there was different palettes used in that title... there should have been a note about that in the error log window....
when that's the case, the scenarist default palette is used across the VTS set, in which case the palette info should NOT be copied over for that VTS during the ifoupdate stage..
I'm working w/ trahald to have this be auto detected in batchupdateifo
ScenAid
D3s7 is offline
Old 30th March 2005, 11:03   #17  |  Link
jarthel
plebian
encountered this with build 45
Info Creating DVD Video files
Error Cell "VTS4_Title1_PGC1_PG26_C1" and Cell "VTS4_Title1_PGC1_PG1_C1" in PGC "VTS4_Title1_PGC1" use different color palettes. Please use one color palette for all tracks in the same PGC.
Error PreCheck From DB failed.
Error DVD Video files could not be created
I opened simulation window and instead of yellow text on black outline, the subtitle is colored purple text on blue outline.
I changed the subtitle color using "Tools -> Change Color". I opened simulation window to verify change and it's correctly displaying the subtitle colors.
Proceed to build the DVD and I again encountered the error stated above.
If you need some files to debug, please tell me what files and I'll provide them.
Thanks
jarthel is offline
Old 30th March 2005, 11:56   #18  |  Link
Sir Didymus
Thanks
Me got exactely the same error as jarthel...
Three palettes were present (looking in the track editor), one was the scenarist default, one for PGC1, and one for PGC2.
Just one (the first) of the subtitles for PGC1, in the track editor window, was linked to the default palette, instead to the PGC1 palette. In my situation, manually making the right attribution made the whole title correctly compiled...
Cheers,
SD
Sir Didymus is offline
Old 30th March 2005, 16:54   #19  |  Link
D3s7
ScenAid
D3s7's Avatar
I found the issue causing that.... apparently i forgot to update the routine that fixes the dummy cell palette.
It has been corrected and a new build will be out soon
ScenAid
D3s7 is offline
Old 5th April 2005, 08:43   #20  |  Link
davemorell
BOV thing
I try to reauthor the movie Big Fish (R2, PAL, contain BOVs). I tried two ways, but Scenarist (3.0.0) always crashed without any word.
1. case: I let ScenAid (1.5 b45) to work with BOVs. Then I tried to import the script into Scenarist, but it crashed during the import process.
2. case: I disabled the BOV support in ScenAid. Now Scenarist imported the script without an error/warning message. (With or without some litle modification) when I wanted to compile the DVD it crashed instantly.
I can reproduce this cases and I can send you some files if you need them for examination.
Bye!
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
