Old 19th August 2017, 17:34   #901  |  Link
sneaker_ger
With MPC-HC's internal subtitle renderer start the movie, then "Play">"Subtitle Track">"Default Style". You can set default style in options. (I don't remember if possible with xy-vsfilter.)
Old 19th August 2017, 21:28   #902  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
"Force Default" in the main tab.
It won't help if they are using style override tags (\c), sadly.
vivan is offline   Reply With Quote
Old 29th December 2017, 07:11   #903  |  Link
gfxnow
Is there an alternate for this considering that this has been abandoned?
gfxnow is offline   Reply With Quote
Old 29th December 2017, 18:44   #904  |  Link
Ryushin
Ryushin's Avatar
I'm trying to find a solution that will fix vsfilter's issue with 10 bit color. Will xy-VSFilter handle 10 bit color without having to dither down to 8 bit color? Shame that this software has been abandoned.
Ryushin is offline   Reply With Quote
Old 29th December 2017, 19:20   #905  |  Link
Skibicki
Skibicki's Avatar
I'm not sure about 10-bit but you can try AssFilterMod. It can use EVR Custom Presenter and other renderers, not EVR.
https://github.com/Blitzker/assfiltermod
https://forum.doom9.org/showthread.php?t=173573
Win 8.1 -- Core 2 Duo E7300 & Intel Q43 GMA 4500
Skibicki is offline   Reply With Quote
Old 30th December 2017, 14:52   #906  |  Link
Ryushin
Ryushin's Avatar
I'll look into those. Forgot to mention that I need it to work with avisynth scripts to render vobsub/pgs subtitles directly into the video.
Old 30th December 2017, 19:34   #907  |  Link
sneaker_ger
Render the subtitles over alpha, then overlay them onto 10 bit video. Shouldn't be too hard.
Old 30th December 2017, 21:27   #908  |  Link
Ryushin
Ryushin's Avatar
Actually, it looks like xy-vsfilter worked perfectly for me. I plugged it into the Ripbot264 avs script and it rendered the subtitles for a 4K UHD Disc.
Old 22nd January 2018, 22:24   #909  |  Link
Ryushin
Ryushin's Avatar
Well, it looks like I was mistaken. xy-vsfilter did not work after all. I can't seem to find the options for xy-vsfilter for running inside a avs script. Though I have not read all 42 pages of this forum. Is there any other source of documentation I can read?
Old 22nd January 2018, 22:30   #910  |  Link
sneaker_ger
https://avisynth.org.ru/docs/english...s/vsfilter.htm + MaskSub() to render over/with alpha
Old 26th February 2018, 10:02   #911  |  Link
pinterf
Preliminary: recently modded xy-vsfilter to work natively with YUV420P10 and YUV420P16.
Question: did someone use this filter (3.0.0.306) successfully in a multithreaded way (E.g. Avisynth+ MT_MULTI_INSTANCE)?
It's freezing for me and I can neither see the protecting mechanism in the source.
pinterf is offline   Reply With Quote
Old 26th February 2018, 10:20   #912  |  Link
madshi
Which recently modded version are you referring to?
Old 26th February 2018, 10:39   #913  |  Link
pinterf
Two days ago I was playing with the existing source, replaced avisynth header to a current avs+ one, fixed some things to compile under VS2017 and put the 10/16 bit support in it for AVS+. Not published, will put on my git.
Old 26th February 2018, 10:50   #914  |  Link
madshi
Ah, I see!
Old 1st April 2018, 22:16   #915  |  Link
amayra
Quality Checker
amayra's Avatar
where can i get that ?
I love Doom9
amayra is offline   Reply With Quote
Old 2nd April 2018, 11:42   #916  |  Link
pinterf
I will do a small clean up and put it to git when I have time. Or PM for test build.
Old 5th April 2018, 02:09   #917  |  Link
iakoboss7
iakoboss7's Avatar
cant you post it here?
iakoboss7 is offline   Reply With Quote
Old 5th April 2018, 19:11   #918  |  Link
pinterf
O.k., here comes my mod. If it works for you, enjoy.
Download xy-VSFilter 3.0.0.400
- Origin of mod source: https://github.com/Cyberbeing/xy-VSFilter/releases/tag/3.0.0.306
- This project: https://github.com/pinterf/xy-VSFilter/
- Forum: https://forum.doom9.org/showthread.php?t=168282
- Rebuilt with Visual Studio 2017
- Avisynth+ headers
- Native support for YUV420P10 and YUV420P16 formats in Avisynth filter TextSub
  Internal conversion to and from P010 and P016 with SSE2 support
- Still doesn't work in any MT mode (I think): automatically registers itself as MT_SERIALIZED to prevent troubles
- Avisynth filter MaskSub: new pixel_type (default: "RGB32") parameter. Can be set to "YUV420P10" or "YUV420P16"
- Versioning: 3.0.0 prefix is kept, build number goes from 400 and up for my mod, set manually in src/filters/transform/vsfilter/version_in.h
- All credits to the previous authors.
Old 10th April 2018, 15:49   #919  |  Link
iakoboss7
iakoboss7's Avatar
thank you for your work, any chance you can integrate that into "XySubFilter Beta3" ( 3.1.0.746 ) that is the latest version?
Old 10th April 2018, 23:54   #920  |  Link
most of the changes are basic for xy subfilter because it don't render the subs on the frame the renderer is doing that.
