Old 4th September 2019, 19:18   #57301  |  Link
steakhutzeee
steakhutzeee's Avatar
should be fine. just check the filters list for lavfilter.
Tried to disable them and instead of them i see "MPC video/audio/splitter" in the active filter list.
If i enable LAV as preferred i see instead that LAV is present in the list. So it's working.
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 4th September 2019, 22:45   #57302  |  Link
ryrynz
ryrynz's Avatar
Originally Posted by Alamei View Post
Currently running a GTX 970.
Play with the queues and the output. Windowed vs full screen D3D 9 vs 11 and minimal queues.
Old 4th September 2019, 23:09   #57303  |  Link
clsid
My computer was just forced to update to Windows 10 v1903, and ever since that "upgrade", I've been experiencing a momentary stutter (and corresponding presentation glitches logged in MadVR debug) when any controls—seek bar, title bar, etc—pop up over the video in fullscreen non-exclusive mode.
Try the latest Windows update (kb4512941 v18362.329). They fixed a microstutter issue in Netflix app. Might this this issue as well.
Old 4th September 2019, 23:33   #57304  |  Link
SamuriHL
SamuriHL's Avatar
The madman is back. He stopped by the HDR thread on AVS to drop a new test build. He had a few comments in the release notes for that test build that are rather interesting. So good to see him developing madvr again!
Old 4th September 2019, 23:39   #57305  |  Link
ryrynz
ryrynz's Avatar
That actually looks to be related to the greater issue of DPC latency spikes people have been experiencing in 1903 for some time..
Old 5th September 2019, 00:03   #57306  |  Link
SamuriHL
SamuriHL's Avatar
That would be nice if they fixed that. I'm running the 19h2 builds right now so I don't know if they've added that fix or not. I suppose I could test it at some point and see if anything's fixed.
Old 5th September 2019, 00:49   #57307  |  Link
ryrynz
ryrynz's Avatar
This wasn't something everyone experienced so you might not see an issue anyway, no idea what caused it..
I'll skip 1903 on the HTPC since 19H2 is basically out now, a shame it has been met with so many small but annoying issues.. but about six months later we're golden.
Old 5th September 2019, 01:01   #57308  |  Link
SamuriHL
SamuriHL's Avatar
I was thinking it could be related to the micro-stuttering the RTX users like myself are seeing but maybe not. Would love to see that get fixed somehow.
Old 5th September 2019, 07:51   #57309  |  Link
ryrynz
ryrynz's Avatar
Nah. Something to do with how the driver interfaces to the Turing cards. Either madshi finds a work around or someone provides nvidia with a good report on how to fix it.
Old 5th September 2019, 16:56   #57310  |  Link
Alamei
That was actually one of my first strategies in attempting to troubleshoot. I tried swapping D3D modes, windowed overlay or not, enabling and disabling present frame for VSync, setting queues to minimum, setting queues to maximum, etc. Even toggling random settings that shouldn't have anything to do with the issue, like using separate device for presentation. Unfortunately, nothing had an impact. I was really hoping the queues might solve the problem, because the stutter looks almost like it's snapping back a couple of frames and then forward again each time you pop up controls. Does anyone else here have a Maxwell-based card on Win10 1903 (Build 18362.295)? I'd be very interested to know whether this bug is specific to something in my build, or whether it's a more generic issue.
EDIT: Correction to this statement. I had been testing so many combinations of settings that I think I must have left D3D11 enabled when I tested windowed overlay mode (which obviously negates the overlay option). I was testing another set of combinations and discovered that D3D9 windowed overlay mode does, in fact, resolve the issue. Does this suggest any particular source for the glitch?
It sounds like that update causes as many issues as it fixes, so I'm inclined to stick to my usual strategy of delaying the updates as long as possible until they can sort out some of the bugs.
Alamei is offline   Reply With Quote
Old 6th September 2019, 22:02   #57311  |  Link
toki
ok, I'm running out of ideas. help.fix.stutter. Graphics card on normal, stutter is in fewer intervals it seems when overclocked it stutters more.
toki is offline   Reply With Quote
Old 7th September 2019, 00:03   #57312  |  Link
ryrynz
ryrynz's Avatar
Do you have anything possibly interfering with it in the background? Try safe mode/ diagnostic start up. Also look at focus assist settings, haven't heard of issues with those recently though..
Old 7th September 2019, 02:17   #57313  |  Link
fedpul
Hi, in fact I get no video (just a black screen, audio not affected) with madvr after that update (KB4512941), uninstalling it and blocking the update solved the problem.
Have this behaviour been reported by others?
fedpul is offline   Reply With Quote
Old 7th September 2019, 03:36   #57314  |  Link
ryrynz
ryrynz's Avatar
No. You're the only one so far.
Old 7th September 2019, 04:58   #57315  |  Link
Magik Mark
Not sure if this has been raised. Does the studio driver of Nvidia performs better than the gamer driver?
I would appreciate if you could point me to the right thread if this has been discussed before. I can't seem find it
Sent from my iPhone using Tapatalk
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR
Magik Mark is offline   Reply With Quote
Old 7th September 2019, 10:28   #57316  |  Link
ryrynz
ryrynz's Avatar
It was brought up, Nev said they're the same thing. Don't bother with the studio one.
Old 7th September 2019, 18:38   #57317  |  Link
tp4tissue
tp4tissue's Avatar
Does it fix the banding problem from windows 1903 though.
because win 1903 on nvidia is basically unusable.
Ghetto | 2500k 5Ghz
Old 7th September 2019, 18:48   #57318  |  Link
the system wide banding was a problem for all including amd.
the not dithering with icm calibrations is not an issue when you are using madVR.
the banding issue could be fix for month not all but the one madVR user care about.
maybe even the audio issues! 1909/19h2 will be released "soon" time to forget 1903.
Old 7th September 2019, 22:35   #57319  |  Link
toki
Uninstalled and reinstalled the graphics driver. This did nothing, still stuttering. What is the trick about matching display framerates? I'm not even sure that's right what I'm trying to say. I'm unsure of what else to try, and then, I don't even know how to do that trick if that is even an option.
Old 8th September 2019, 08:30   #57320  |  Link
RXP
Been using MadVR for a while now on firstly a 1050ti and more recently a 1070. I now need to build/buy another machine for playback because I built another theatre - but it appears things got a lot more complex because Nvidia ended 3D frame packed support. From the driver thread I know that the newer cards can't be used with the older drivers that did support 3D frame packed.
Are there any alternatives if I don't want a used 1070? Does AMD support 3D frame packed playback? Or shall I just be resigned to using my Popcorn Hour VTEN has a 3D playblack?
I wish the Envy would be available soon - I'm pretty frustrated at having to jiggle so many drivers/software versions/windows update etc!
RXP is offline   Reply With Quote
