Old 19th March 2011, 08:55   #461  |  Link
nhope
partially-informed layman
I went back to YV12 but version 3.30 is giving me a new crash that I didn't get with 3.11, 3.20 or 3.25. MeGUI version 1989 crashes if I have "Open Preview after AviSynth script selection" checked. Error message is:
AppName: megui.exe	 AppVer: 1.0.1989.0	 ModName: unknown
ModVer: 0.0.0.0	 Offset: 05537432
My script is:
AviSource("d:\fs.avi")
ConvertToYV12(interlaced=true)
AssumeTFF
QTGMC( Preset="faster", FPSDivisor=2 )
I'm on Core 2 Duo, XP SP3, everything in ST mode.
I can let you have the full MeGUI error report if it helps.
nhope is offline
Old 19th March 2011, 09:01   #462  |  Link
jpsdr
Originally Posted by SubJunk View Post
SET's 2.6 wins
Just out of curiosity, have you tried the version here ?
jpsdr is offline
Old 19th March 2011, 14:01   #463  |  Link
Taurus
Taurus's Avatar
@nhope
I've just tried yor simple script with MeGui. Standard Dev installation. All updates.
QTGMC 3.30
Core 2 Duo, XP SP3
Avisyth 2.58 Standard
No MT
Input: Lagarith avi yv12 ok
Output: mkv x264 ok
Preview: ok
No crashes.
Tested with Lagarith 1320 and 1321.
Ver. 1323 is much faster but gives disturbed/corrupted frames on two machines.
Each WinXP 32bit SP3
Core2duo and AMD XP ?????
Taurus is offline
Old 19th March 2011, 14:17   #464  |  Link
nhope
I'm not quite sure what you mean by "Core2duo and AMD XP ????? "
nhope is offline
Old 19th March 2011, 14:19   #465  |  Link
-Vit-
nhope: You are correct that I forgot to add SSE3Tools as a requirement for YUY2 support. It's in the OP now, I will add it to the documentation for the next version.
On RemoveGrain versions:
- The 0.9 zip has SSE3Tools but doesn't have mode 20, which is used by QTGMC
- The 1.0 zips do have mode 20 (although no SSE3Tools), but there is a bug in some SSE3 versions. There are some fixed versions around, but there is no notable SSE3 code in there anyway so just stick with the SSE2 versions.
The YUY2 problem you got surprises me (error in mt_lutxy). That part of QTGMC looks correct and I tested your script with my own YUY2 material and it works fine. Could you perhaps post a small snippet of your source so I could test. I also get no problems in MeGui preview. Perhaps seeing the source might help with that too.
Thanks for the spreadsheet updates. I don't have any major changes planned at the moment, so maybe you'll get a break now... or maybe not...
-Vit- is offline
Old 19th March 2011, 14:30   #466  |  Link
Taurus
Taurus's Avatar
Two different machines
One Intel
Second AMD
Taurus is offline
Old 19th March 2011, 18:59   #467  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Update to 3.30, spanish translation´s doc. http://www.megaupload.com/?d=IB7YAZVV
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline
Old 19th March 2011, 19:08   #468  |  Link
nhope
I'm using Debugmode Frameserver to frameserve from Vegas Pro in YUY2, same as johnmeyer. As this improves his MT stability, I'm testing if we can keep YUY2 right through to MeGUI without converting to YV12. MediaInfo reports this on the frameserved signpost .avi file:
General
Complete name                    : D:\fs.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
File size                        : 2.36 KiB
Duration                         : 501ms
Overall bit rate                 : 38.5 Kbps
Video
Format                           : VFW
Codec ID                         : DFSC
Codec ID/Info                    : DebugMode FrameServer VFW
Duration                         : 501ms
Bit rate                         : 1 918 bps
Width                            : 1 440 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 4:3
Frame rate                       : 29.970 fps
Bits/(Pixel*Frame)               : 0.000
Stream size                      : 120 Bytes (5%)
Audio
Format                           : FrameServer
Codec ID                         : DFAC
Codec ID/Info                    : DebugMode SonicFoundry Vegas FrameServer ACM Codec
Duration                         : 500ms
Bit rate                         : 6 400 bps
Channel(s)                       : 2 channels
Sampling rate                    : 48.0 KHz
Stream size                      : 400 Bytes (17%)
Interleave, duration             : 10 ms (0.30 video frame)
Interleave, preload duration     : 500 ms
I opened the frameserved signpost .avi file in virtualdub and rendered uncompressed .avi but MediaInfo reports it as RGB. What VirtualDub codec/settings would allow me to encode it to a YUY2 file that would let you debug my error? Huffyuv? Something else?
Here is 4 seconds of HDV that gives my repeatable MeGUI preview crash with QTGMC 3.30, but not with 3.20 or 3.25. As it's anamorphic HDV I'm also resizing the width.
AssumeTFF
LanczosResize(1920,height)
I should note that I can open the MeGUI preview with "Reopen Video Preview" once the AviSynth script has loaded. It only crashes when I have MeGUI set to open the preview automatically after script selection.
One Intel
Second AMD
Who has the AMD machine? We both have Intel Core2Duo don't we? too
nhope is offline
Old 19th March 2011, 20:33   #469  |  Link
Taurus
Taurus's Avatar
Ah, damn language barriers..
I just wanted to say that I've tested your script on different machines.
Yes, one Core2Duo and one AMD.
Sorry for writing unclear...
I will test your snippet later on.
Stay tuned.
Taurus is offline
Old 19th March 2011, 20:56   #470  |  Link
-Vit-
Overdrive80: Thanks again, the OP is updated.
nhope: What exactly are you dragging into Megui to cause the crash? That script doesn't refer to the file you've uploaded. In any case the snippet you sent (it's 4:2:0) works perfectly. I can drag the m2t file directly into the Avisynth Script box and a preview comes up no problem. If I adjust your script to accept it as a source, I can drag that in too. QTGMC happily processes it. This is all on a fully patched dev version of MeGUI.
To get YUY2 out of VDub, you can use ffdshow/HuffyUV and set the Colorspace to YUY2 in ( Compression...>>Configure>>Encoder>>Generic )
-Vit- is offline
Old 19th March 2011, 21:13   #471  |  Link
Taurus
Taurus's Avatar
Yes, I can confirm it.
Loaded your file with an avisynth script which contains embedded QTGMC.
Indexed the *.m2t first, even converted to lagarith staying inYUV color space.
All three attempts were doing fine. Preview worked, no crashes.
Yes, and verified with a process viewer that all plugins were loaded correctly.
I'm out.
And as -Vit- mentioned:
Your script does't belong to the file you've uploaded
Taurus is offline
Old 19th March 2011, 21:58   #472  |  Link
SubJunk
Is that version of 2.6 multithreaded?
I tried his build of MVTools2 before and found it was slower than the official build (results here) so I don't have great confidence in his builds but maybe they have improved since then (last month).
Have you tried them?
SubJunk is offline
Old 19th March 2011, 22:07   #473  |  Link
nhope
-Vit-: "d:\fs.avi" is the avi signpost file from the Debugmode Frameserver which frameserves out of Vegas. So the HDV snippet I sent is sitting on the Vegas timeline and gets frameserved out as to AviSynth as RGB24 (or RGB32 or YUY2). Look 40% of the way down the guide in my signature to see screenshots.
So to get the frameserving out of the loop I tried accessing it direct with this script:
DirectShowSource("d:\somosomo-test.m2t")
AssumeTFF
With QTGMC 3.11, 3.20 and 3.25 I have no problem, but with 3.30 I still get the MeGUI preview crash. Sometimes it bombs straight out, sometimes it shows me the middle preview frame and then as soon as I click on another time point it crashes. I have MeGUI version 1989. It's the stable version but it's pretty recent and I can't find a newer development version. MeGUI and all the plugins were updated a few days ago. I also tried fast and very fast QTGMC presets and I get the same crash.
As for the YUY2 issue, I'll get onto that tomorrow. Thanks.
nhope is offline
Old 19th March 2011, 22:20   #474  |  Link
nhope
Taurus: Thanks for trying that out. What MeGUI version do you have?
By the way (until my tower is fixed) I'm using a Dell Precision M6300 laptop, Core 2 Duo T7800 @ 2600MHz, 4GB RAM, XP SP3
nhope is offline
Old 19th March 2011, 22:51   #475  |  Link
jmac698
http://avisynth.org/mediawiki/Extern...#Deinterlacing
http://avisynth.org/mediawiki/QTGMC
jmac698 is offline
Old 19th March 2011, 23:12   #476  |  Link
mr.duck
quack quack
First time avisynth user here.
I just got QTGMC working here to deinterlace standard definition TV in ffdshow. I used the preset "Super Fast" but it slows to a crawl and cannot get anywhere near 50 FPS. I have a Athlon X2 2.1GHz CPU. Is QTGMC not suitable for what I am trying to do?
Media Player Classic Home Cinema Icon Library: NORMAL VERSION / GLOWING VERSION
mr.duck is offline
Old 19th March 2011, 23:55   #477  |  Link
-Vit-
jmac698: Thanks for that.
nhope. Your perseverance has paid off. I reproduced your problem in the MeGUI preview and fixed the cause, there's a new version v3.31 in the OP. There's no need to update documentation or spreadsheets, it's only this bug-fix.
mr.duck: Are you trying to use QTGMC in realtime? It's not really designed for that, it's designed to make high quality results to encode into another file (i.e. to make an mp4 or mkv). However, if you have a decent machine and use the multi-threading tips in the documentation you can get realtime SD playback for the quicker settings. Not sure how well your machine would cope with that.
-Vit- is offline
Old 20th March 2011, 00:03   #478  |  Link
mr.duck
quack quack
Yes it's realtime.
I was searching for good avisynth deinterlacers that are better than yadif which comes with ffdshow. yadif doesn't need much CPU power at all and yet gives excellent results.
I couldn't really find any info on realtime avisynth deinterlacing. If anyone knows the best way to do it, I'm all ears...
mr.duck is offline
Old 20th March 2011, 01:20   #479  |  Link
Didée
If you judge Yadif's result as "exzellent", then what are you looking for, at all? Just use Yadif and enjoy its excellent desintegrat... erh, deinterlacing!
With some luck, this here might run for you in realtime, if you include blksize=16 into MAnalyse.
But frankly, a 2 GHz Dual Core is not well suited to perform MVTools-motion-compensated deinterlacing in realtime ....
Didée is offline
Old 20th March 2011, 01:53   #480  |  Link
mr.duck
quack quack
I tried software deinterlacing quite a while ago and found it to be quite poor compared to hardware deinterlacing. But installed a recent build of ffdshow and I couldn't believe how good yadif was. I could not tell it apart from hardware vector adaptive deinterlacing!
I will enjoy it's excellent result... but if I can get better than yadif then I will enjoy it even more
mr.duck is offline
