Old 1st December 2008, 23:49   #101  |  Link
As long as it is on topic you don't need my permission.
I hope this is really a rip from a DVD you own and not some piece of corrupted garbage you downloaded somewhere. What is the title and region of the DVD?
Guest is offline
Old 1st December 2008, 23:58   #102  |  Link
rica
Thanks, i'll try to do my best
rica is offline
Old 2nd December 2008, 00:00   #103  |  Link
What is the title and region of the DVD that you took MC.ts from?
Guest is offline
Old 2nd December 2008, 00:02   #104  |  Link
CruNcher
CruNcher's Avatar
DVD with VC1 and inside of .ts ? i would say rather Blu-Ray was the Source or maybe a transcode from something into VC1 and .ts maybe to play it back on the Xbox 360 or Ps3, the sporadic artifacts in the DGVC1Dec output could be transfer errors i guess (or failed decryption).
It is about Time
CruNcher is offline
Old 2nd December 2008, 00:09   #105  |  Link
rica
Mariah Carey; The Advantures Of Mimi. Region 1.
BTW i've been uploading a raw vc1 cut directly by eac3to (160MB); i'll add it here when finished.(roughly half an hour is left)
rica is offline
Old 2nd December 2008, 00:12   #106  |  Link
CruNcher
CruNcher's Avatar
How did you cut that sample which software did you used ?
i mean how came MC.ts into existence as 56 mb sample, as it seems (the creator) didn't cut @ a i frame
It is about Time
CruNcher is offline
Old 2nd December 2008, 00:17   #107  |  Link
rica
Original vc1 was extracted by eac3to and recut and remuxed to ts by TSMuxer.
Edit: btw i gave it a go with the original vc1; nothing has changed.
You will get a new eac3to cut as soon as possible.
rica is offline
Old 2nd December 2008, 00:19   #108  |  Link
@rica
Give me a fragment of the unprocessed source (m2ts). I will demux it myself. Thank you.
Guest is offline
Old 2nd December 2008, 00:20   #109  |  Link
CruNcher
CruNcher's Avatar
and the sample from the final .ts you also made with TSMuxer ?
It is about Time
CruNcher is offline
Old 2nd December 2008, 00:25   #110  |  Link
rica
@rica
OK, but what method do you suggest to cut this m2ts?
1) Cut and remux directly to m2ts by tsmuxer or tsremux.
2) Demux with eac3to and cut/remux to m2ts by tsmuxer.
3) Or?
rica is offline
Old 2nd December 2008, 00:26   #111  |  Link
rica
Yes. It was tsmuxer.
rica is offline
Old 2nd December 2008, 00:43   #112  |  Link
CruNcher
CruNcher's Avatar
try todo as less as possible with as few as possible different developer tools, also try to maintain the .m2ts and not remux into .ts
1) seems better 2 are to much steps something could go wrong (and neuron is not here to debug your production chain) not sure which of both takes the bitstream into account while cutting (tsremux,tsmuxer) i guess both don't and cut straight @ the point user requests it (initially that isn't bad as a good splitter->decoder combination should jump to the next i-frame). DGVC1Dec does it as you see but other combination's don't like this created .ts much and crash while trying to decode everything
It is about Time
CruNcher is offline
Old 2nd December 2008, 00:56   #113  |  Link
@rica
Cut the source m2ts directly. One option is DGSplit.
Or you can load the source m2ts in DGVC1IndexNV, set a range, do Save project and demux video. Then upload the demuxed vc1.
I prefer the first option.
Guest is offline
Old 2nd December 2008, 01:14   #114  |  Link
@rica
I'd still like the sample, but Nvidia thinks they probably have a bug in the calculation of deblocking filter coefficients and hope to give me a fix very soon.
Guest is offline
Old 2nd December 2008, 01:16   #115  |  Link
rica
This is a cut with TSMuxer:
http://www.mediafire.com/?sharekey=6...4ba96cbfe5b446
Cut with DGSplit is coming soon which is made on the fly...
rica is offline
Old 2nd December 2008, 01:17   #116  |  Link
rica
@rica
Good news, thanks.
rica is offline
Old 2nd December 2008, 01:39   #117  |  Link
CruNcher
CruNcher's Avatar
AppName: mplayerc.exe AppVer: 1.1.906.0 ModName: wmvdecod.dll
ModVer: 11.0.5721.5145 Offset: 000361ad
also this one crashes immediately (i slowly wonder if it is a Haali Splitter bug) why should Microsoft not support their own stream ?
It is about Time
CruNcher is offline
Old 2nd December 2008, 01:45   #118  |  Link
Um, I didn't ask for that.
Guest is offline
Old 2nd December 2008, 01:45   #119  |  Link
rica
Give it a go with MPC-HC. Default decoder is WMVideo decoder DMO and renderer is EVR Custom.
rica is offline
Old 2nd December 2008, 01:47   #120  |  Link
All this other player stuff is OT. Please stop it.
Guest is offline
