Old 10th March 2009, 14:17   #1101  |  Link
meatwad
meatwad's Avatar
I wrote you a lengthy email you can ignore. Just skim to the bottom and you'll find the new id. Thanks again.
meatwad is offline
Old 10th March 2009, 14:27   #1102  |  Link
meatwad
meatwad's Avatar
Hypothetically, what if you have more than one network controller in your system. I just installed an old Skystar2 that created 2 new local networks. Could that be what caused it?
meatwad is offline
Old 10th March 2009, 14:41   #1103  |  Link
Yes, if you change the MAC address of your first active network adapter the machine ID will change. Usually, the MAC is stable, but some people have a wireless card they switch on and off. In those cases, they send me the IDs with it on and off and I give them a license file that supports both.
Guest is offline
Old 10th March 2009, 15:14   #1104  |  Link
meatwad
meatwad's Avatar
Thanks. That got it working. Now if it ever barks 'invalid license file' at me again I'll know to check my network settings to see if there's been a change.
meatwad is offline
Old 10th March 2009, 15:56   #1105  |  Link
xopowo
[QUOTE=Clumpco;1259652]A problem (maybe) with 1.0.13.
The audio file has "DELAY -47721878ms"
The same .ts with ver 1.0.12 had "DELAY -20ms"
Wassup?
QUOTE]
I concur with this. I'm getting the same arbitrary delays. Seems like something with 1.0.1.3.
xopowo is offline
Old 10th March 2009, 16:22   #1106  |  Link
Clumpco
Clumpco's Avatar
@meatwad
@Clumpco
Your link is not working. Please fix it so I can investigate the problem. Thank you.
Link fixed, apologies.
Also so far with 1.0.13/1.0.4 I have BSOD (IRQ_NOT_LESS...) or just hanging during the x264 second pass.
I have rolled back to 1.0.11/1.0.3 to see if it is any better.
If not, then I'll have to start running memtest etc.
UPDATE - Encoded fine with 1.0.11/1.0.3
Clumpco is offline
Old 10th March 2009, 18:37   #1107  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Wassup?
same "issue" here too.
v1.0.13 : delay = -763550166 ms
v1.0.12 : delay = -424 ms
Kurtnoise is offline
Old 10th March 2009, 19:22   #1108  |  Link
Clumpco
Clumpco's Avatar
Slightly OT question... but of interest to all us CUDA users.
If I am really having heat problems again, then can someone recommend some software to monitor my GPU temp (Nvidia 9600 GT Matrix)?
It needs to be sober, tiny footprint, non-invasive.
TIA
Clumpco is offline
Old 10th March 2009, 19:29   #1109  |  Link
Kurtnoise
Kurtnoise's Avatar
Gpu-z
Old 10th March 2009, 20:09   #1110  |  Link
Sharc
9. Fixed an M2TS parsing bug that caused corruption for some streams.
@Sharc
Please advise if this fixes your issue. If you confirm it, I'll update the other tools.
Problem solved. Thank you.
Sharc is offline
Old 10th March 2009, 20:21   #1111  |  Link
meatwad
meatwad's Avatar
I experienced a similar audio delay issue when I used DGMPGDecNV if I used VideoRedo to correct the original .ts/.mpg file. VideoRedo corrects the audio delay to where it usually comes out as zero. When I was trying both versions of DGMPGDecNV it would always be off by a huge amount. Sometimes minutes. I didn't think too much about it because DGMPGDecNV is still in the testing phases.
I can up some small samples if you think it will help neuron2, but the problems may be completely unrelated.
meatwad is offline
Old 10th March 2009, 22:14   #1112  |  Link
Clumpco
Clumpco's Avatar
Originally Posted by Kurtnoise View Post
Gpu-z
Just what I needed!
Thanks
Clumpco is offline
Old 11th March 2009, 00:36   #1113  |  Link
Please re-download 1.0.13. I have fixed the audio delay regression.
@Clumpco
I'm going to need a stream to duplicate any crashes.
@meatwad
DGMPGDecNV was released a while ago. Please report problems in the DGMPGDecNV thread. I'm going to update it with these fixes right now, so strike while the iron is hot.
Guest is offline
Old 11th March 2009, 03:39   #1114  |  Link
~bT~
н∂-αиαтι
with the latest version, if i step back frame by frame, preview distorts? is that normal as i had never encountered it before.
~bT~ is offline
Old 11th March 2009, 03:42   #1115  |  Link
I don't know what you mean by "preview distorts" and I always need a sample to duplicate the issue.
I assume you mean DGAVCDecodeNV as you can't step back by frames in DGAVCIndexNV.
Please try to give clear and complete trouble reports. Thank you.
Guest is offline
Old 11th March 2009, 03:50   #1116  |  Link
~bT~
н∂-αиαтι
^ i think it maybe a corrupt stream. i tried with another stream and it was fine.
if u still want a sample, let me know.
~bT~ is offline
Old 11th March 2009, 03:52   #1117  |  Link
Thank you, yes, if it's not too much trouble. It never hurts to investigate issues and the possibility of making the tools more robust.
To be specific, there is a problem with M2TS files, which have the silly 4-byte count field before the transport sync byte. When that count includes a 0x47 byte in the 2nd to 4th bytes, it become difficult to ensure proper packet sync when seeking. So it will be helpful to me to see if this is happening in your case.
Guest is offline
Old 11th March 2009, 09:39   #1118  |  Link
~bT~
н∂-αиαтι
here u go: http://www.mediafire.com/?sharekey=3...db6fb9a8902bda
~bT~ is offline
Old 11th March 2009, 11:05   #1119  |  Link
Clumpco
Clumpco's Avatar
@Clumpco
Thanks! I'm uploading it now, I'll let you have the link when it's ready.
[EDIT] - @neuron2, check your email
Clumpco is offline
Old 11th March 2009, 14:09   #1120  |  Link
@~bT~
Please help me by giving me instructions on how to make the problem happen with the stream.
Guest is offline
