#1061 | Link | |
I get decoding errors just like you showed in post #1029. I only get them when I use a m2ts source (and I get them in all m2ts'). If I demux those same sources to elementary, they decode fine. Its also not random to each decoding: a particular source has the same error, at the same point, whether I'm playing the whole file or just trim to the timeline around an error. I'm running Vista Bus. 64, a Q6600, an 8800GT, the newest DGAVCdecNV, whatever version of CUVID server comes with that download, and AviSynth 2.5.7.5 (with MT 0.7) (I had the same errors when I was using AviSynth 2.5.8 before I switched to MT). |
#1062 | Link | |
I'll try with version 1.0.11 tonight. Sorry I can't provide more details Don. But it was happening with all sources at various times with all of your DecNV tools. I'm trying to nail it down on my end as best I can. edit: oh and only started happening around the time all progs got updated including CUVID Server.
http://www.7-zip.org/ Last edited by Audionut; 7th March 2009 at 10:55. |
#1064 | Link |
http://www.7-zip.org/ |
#1066 | Link | |
Just to be clear, when you say 1.0.11 works, you mean you cleared out all 4 of: DGAVCIndexNV DGAVCDecodeNV CUVID Server nvcuvid.dll and reinstalled the 4 from the 1.0.11 distribution? If you did not revert all 4, which components did you revert? Last edited by Guest; 7th March 2009 at 14:37. |
#1067 | Link |
Yes, I reverted the full set to 1.0.11.
However, things appear to be more complicated. Independent of version 1.0.11 or 1.0.12: a) If I index the full .m2ts => the playback of the script fails b) If I extract and demux the critical segment (my uploaded sample) and play the script immediately back, it fails. c) If I index the demuxed sample clip again and playback the new script => playback is o.k., but it does not solve my problem for the entire movie. As all of you are doing the test according to c) you cannot reproduce the problem. Doing more tests ..... Should I submit the .dga and .avs of a), b) and c)? Update / Summary: - When I index the original .m2ts, playback via CUVIDServer fails - When I index and demultiplex the video, playback via CUVIDServer still fails. The path in the .dga header points to the original .m2ts file - When I re-index the demuxed video, playback via CUVIDServer is fine. The path in the.dga header points to the .demuxed.264 Last edited by Sharc; 7th March 2009 at 17:21. |
#1068 | Link | |
Aging Video Hobbyist
1. Only AVC/H.264 elementary (raw) and transport streams can be opened (no MKV or MP4 files yet). Only one file can be opened at a time. It *appears* to work, but there can be problems (yes I have done this myself in the past ![]() |
#1069 | Link | |
Again, try always demuxing the video first, *then* indexing, and see if you can get CUVIDserver to fail. Also, how exactly are you demuxing (what tool, what command). |
#1070 | Link | |
Yes, I loaded the .m2ts original (video+audio+subs) directly into DGAVCIndexNV, then fired it up with <File/Save Project [F4]> rather than <File/Save Project and demux video>, and got the demuxed audio tracks and the index file (.dga). Up to now this has always worked, perhaps I was just lucky. After all, would I have to run DGAVCIndexNV twice, first pass to demux audio and video, and then second pass for indexing the demuxed.264 raw video? |
#1071 | Link |
I dunno Sharc...I'm sure neuron2 will weigh-in shortly and straighten us out--his doc sez "elementary (raw) and transport streams" which could be interpreted I suppose as including .m2t(ransport)s(treams).
I've had his NV tools since mid-Jan but have never tried to use them to demux anything--usually I'm using eac3to to do that, cuz I'm modifying BD or HD DVD movies. Also I use VideoReDo to demux MPEG2 OTA TV recordings I've edited. |
#1072 | Link |
Direct opening of transport streams is supported. There is no need to demux.
If it works on the demuxed file but not on the transport streams, then it could point to a problem with the transport parsing. But I will need a sample transport stream that causes the problem. Try to cut a segment of the M2TS around the problem area using DGSplit in segment mode. |
#1073 | Link |
Thanks guys. Seems we're getting closer.
@neuron2 I'll try my best to extract the questionable part of the original .m2ts. Any suggestion what segment boundaries to choose, if the problematic part is at about the middle of the 30GB .m2ts file? |
#1074 | Link | |
http://neuron2.net/misc/Sharc.zip It's a modified DGAVCIndexNV. Open the transport stream and navigate to the bad spot. Then move back about 16 < steps and hit [. Then move about 15 > steps past the bad spot and hit ]. You have defined a project range around the bad spot. Now hit F1. Specify a file name like cut.m2ts and OK. Wait for a popup saying it is finished. Then see if you can make the problem happen with just cut.m2ts. If so, upload cut.m2ts. Note that this is a rudimentary TS trimmer. It doesn't cut smartly or even on packet boundaries. But it will give me what I need. Last edited by Guest; 7th March 2009 at 21:41. |
#1075 | Link |
As requested. Hope it helps.
http://www.mediafire.com/download.php?a4i3mj5znmy |
#1077 | Link |
Yay. Thanks.
#1080 | Link | |
