Old 13th December 2008, 20:00   #821  |  Link
Sulik
@moviefan: I don't think ATI's Stream API provides any video-decode-related functionality.
Sulik is offline
Old 13th December 2008, 20:39   #822  |  Link
CruNcher
CruNcher's Avatar
i wouldn't say so though if UVD will be accessible we gonna see December 16, but it would be bad in public if it wouldn't as Nvidia provides it for Windows same as for Linux
Though sure Ati could decide only Licensed 3rd Party ISVs but why should they makes no sense except if they cant provide a secure way to the UVD part without interfering with Blu-Ray security
It is about Time
CruNcher is offline
Old 14th December 2008, 02:39   #823  |  Link
Originally Posted by rica View Post
Are you sure? Looks like DTS HD Master Audio to me.
Guest is offline
Old 14th December 2008, 03:53   #824  |  Link
rica
No, i'm not sure.
Looks like MA:
http://bluray.highdefdigest.com/1416/27dresses.html
But eac3to gives this information:
[C:\>eac3to\eac3to E: 1)
M2TS, 1 video track, 5 audio tracks, 19 subtitle tracks, 1:50:49
1: Chapters, 25 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Hi-Res, English, 5.1 channels, 24 bits, 3018kbps, 48khz
   (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz)
4: DTS, Italian, 5.1 channels, 24 bits, 768kbps, 48khz
5: DTS, Spanish, 5.1 channels, 24 bits, 768kbps, 48khz
(Btw PowerDVD gives the same info...)
While it gives this info for Close Encounters BD:
M2TS, 1 video track, 2 audio tracks, 20 subtitle tracks, 2:17:13
1: Chapters, 20 chapters
3: TrueHD/AC3, English, 5.1 channels, 48khz
   (embedded: AC3, 5.1 channels, 448kbps, 48khz)
4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz
rica is offline
Old 14th December 2008, 05:12   #825  |  Link
Hmm, strange. Maybe you should ask madshi about it.
Guest is offline
Old 14th December 2008, 13:59   #826  |  Link
nautilus7
nautilus7's Avatar
I really think eac3to gives the correct format. It's very precise.
EDIT: rica, what is this sample (audio.dtshd.m2ts)? Is this a remux? Using tsmuxer perhaps? Maybe that buggy program uses wrong id for the audio track. Send a sample from the original file. If you are willing to help, please send original samples.
(neuron2, the samples i promised will be up soon. Do you want them to have VC-1 video only? You will add these changes to your other apps as well, correct?)
nautilus7 is offline
Old 14th December 2008, 14:51   #827  |  Link
I'm working on DGAVCDec(NV) right now, so I prefer AVC at this point. But I'll happily accept samples with VC-1 too. Yes, I will update the other apps next. I was hoping to release something today, so it would be helpful if you could upload your samples ASAP. Thank you.
Guest is offline
Old 14th December 2008, 15:07   #828  |  Link
rica
The sample cut by eac3to first, recut/remuxed to m2ts by TSMuxer. But it is not the source of the issue.
Here is a direct cut from the original by clip.exe (27_cut.m2ts):
http://www.mediafire.com/?sharekey=6...5f4ee94eb39148
I'm uploading a direct cut by eac3to into the same folder as well. (27_cut.dtshd raw audio)
Edit: Uploaded...
rica is offline
Old 14th December 2008, 15:37   #829  |  Link
madshi
I've found that some streams do not strictly follow the specs. E.g. sometimes there's an E-AC3 track with a stream_type for AC3 or vice versa. The same might be true with DTS-HD High Resolution vs. DTS-HD Master Audio.
eac3to only does rough stream_type checks. E.g. all AC3 and E-AC3 stream_type streams are running through the same general parser which supports both AC3 and E-AC3. And all DTS related stream_type streams are running through one and the same DTS parser which supports all types of DTS streams. The exact stream parameters are then determined by parsing the audio bitstream. This way eac3to cannot be confused by incorrect stream_type values.
madshi is offline
Old 14th December 2008, 15:43   #830  |  Link
nautilus7
nautilus7's Avatar
I mixed the threads that's why i mentioned vc-1. I meant h.264.
Anyway, give me 1 hour (top) because i have to change hdds to find the proper samples.
Old 14th December 2008, 16:39   #831  |  Link
nautilus7
nautilus7's Avatar
National Treasure 2 sample
track list
1: h264/AVC, 1080p24 /1.001 (16:9)
2: h264/AVC, 480p24 /1.001 (20:11)
3: TrueHD/AC3, 5.1 channels, 48khz
   (embedded: AC3, 5.1 channels, 640kbps, 48khz)
4: AC3 Surround, 2.0 channels, 192kbps, 48khz
5: AC3, 5.1 channels, 640kbps, 48khz
6: AC3, 5.1 channels, 640kbps, 48khz
7: AC3, 5.1 channels, 640kbps, 48khz
8: AC3, 5.1 channels, 640kbps, 48khz
9: AC3 Surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
10: DTS Express, 2.0 channels, 24 bits, 192kbps, 48khz
Jumper sample
track list
3: DTS Master Audio, 5.1 channels, 24 bits, 48khz
4: DTS, 5.1 channels, 24 bits, 768kbps, 48khz
5: DTS, 5.1 channels, 24 bits, 768kbps, 48khz
6: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
7: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
8: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
9: AC3, 2.0 channels, 224kbps, 48khz, dialnorm: -27dB
10: DTS Express, 2.0 channels, 16 bits, 192kbps, 48khz
Transformers sample
track list
3: TrueHD/AC3, 5.1 channels, 48khz, dialnorm: -27dB
   (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB)
4: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
5: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
6: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
7: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
8: AC3 Surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
9: E-AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
Old 14th December 2008, 17:06   #832  |  Link
rica
nautilus7,
DTS-HD HR is still missing since we are not sure yet whether my cut is HR or MA.
Edit: Ok, i've found one. Gonna upload soon.
Last Edit: Here it is:
Hitman:
http://www.mediafire.com/?sharekey=6...aa14c0f07f9723
2: DTS, 5.1 channels, 24 bits, 768kbps, 48khz, -769ms
3: DTS Hi-Res, 5.1 channels, 24 bits, 3018kbps, 48khz   (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz), -1003ms
4: DTS, 5.1 channels, 24 bits, 768kbps, 48khz, -769ms
5: DTS, 5.1 channels, 24 bits, 768kbps, 48khz, -769ms
6: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, -865ms
7: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, -865ms
8: AC3 Surround, 2.0 channels, 224kbps, 48khz, dialnorm: -27dB, -545ms
9: Subtitle (PGS)
rica is offline
Old 14th December 2008, 23:08   #833  |  Link
rica
I checked again; latest versions of both TMT and PDVD give the same info: (TMT 2.1.6.126, PDVD 8.0.2217a.00)
27 is DTS-HD HR; eac3to/madshi is right.
rica is offline
Old 16th December 2008, 15:28   #834  |  Link
moviefan
A general question: I've experimented with encoding speeds and wonder, if it makes a huge difference when the GPU decodes the video stream. I created a blank clip with AviSynth at 1920x1080 and encoded that with x264. I got something around 15 fps or so, which should be close to a GPU decoding (in terms of CPU usage when decoding because there are no details - completely black picture), right? So am I right saying if the CPU isn't REALLY fast, x264 is the bottleneck anyway and decoding only a couple of frames per second isn't too much of an effort for a C2D CPU. So since x264 cannot encode so fast due to the CPU, it only requires some few frames per second which takes only little CPU usage (for the decoding). The impact of a GPU decoded video stream increases, when the CPU is able to encode at let's say real time or something like that, when this amount of frame decoding would take a lot CPU usage. Is this theory correct?
moviefan is offline
Old 16th December 2008, 15:43   #835  |  Link
Comatose
The idea is that x264 will use 100% of your CPU. A decoder can eat some of the available CPU, and even if it's very little (because of the general slowness), some of us do veeeeeeeeery long encodes so even 1% CPU has a big impact in the long run.
Comatose is offline
Old 16th December 2008, 15:49   #836  |  Link
rack04
On some machines there may be a small performance improvement, but the main purpose of using CUDA is to get correct decoding for the streams that are not handled by libavcodec, and to access some of the post-processing capabilities of CUDA. Also, to add support for VC-1 in the future.
This may be appropriate here.
rack04 is offline
Old 25th December 2008, 12:42   #837  |  Link
Renzz
Had my first ever crash of CUVID server while trying to encode. Windows Event log shows:
Faulting application CUVIDServer.exe, version 0.0.0.0, time stamp 0x49328ce7, faulting module nvcuvid.dll, version 0.0.0.0, time stamp 0x4937286b, exception code 0xc0000005, fault offset 0x00039399, process id 0x1624, application start time 0x01c9667ee9e9ae00.
On examination of the source TS, there is a broadcast glitch at the point that I get the crash. DGAVCIndex doesn't complain and creates the DGA file ok - it's just the Server that doesn't like it.
I've cut the relevant portion out here (60MB):
http://www.mediafire.com/?sharekey=0...db6fb9a8902bda
The glitch is about 75% of the way through.
Should the code handle glitches like this, or is a crash likely if you have glitches in the original stream?
Thanks, and Happy Christmas!
Renzz is offline
Old 25th December 2008, 12:47   #838  |  Link
chr2000
a question, why set Disable Display, the CPU ulity is about 10% in my computer, which is compared with 40% CPU ulity when Enable Display.
why I/O will consum so much cpu resource? isn't the display card push the YUV file to monitor directly?
if the process of coverting yuv to RGB consumed much cpu resource? then is there any display card support YUV input directly?
chr2000 is offline
Old 2nd January 2009, 19:31   #839  |  Link
ultratoto14
Hi neuron2, I recorded a stream from DVB-T in france.
Frame Size 1440x1080
SAR 4:3
Display Size 1920x1080
When i load the dga via DGAVCDecodeNV the resulting frame is 1440x1080. Is it the normal behavior ?
Happy new year.
ultratoto14 is offline
Old 2nd January 2009, 20:22   #840  |  Link
Yes. You need to resize anamorphic video in your Avisynth script.
Guest is offline
