Go Back   Doom9's Forum > Hardware & Software > Hardware players
Old 4th April 2011, 21:10   #1  |  Link
louv68
List of BDMV-REC compatible players?
Late adopter here looking into jumping on the Bluray train. With DVDFab having sort off bypassed Cinavia protection, I'm curious if there is a list of "so called" BDMV-REC (AACS protected recordable BDMV) compatible standalone players.
Thank you in advance for your time.
louv68 is offline   Reply With Quote
Old 5th April 2011, 14:21   #2  |  Link
MickJT
I know of one. Hardly worth mentioning since it's listed on DVDFab's website, but the Sony Playstation 3.
MickJT is offline   Reply With Quote
Old 5th April 2011, 14:57   #3  |  Link
Ghitulescu
Ghitulescu's Avatar
There are few chances to get answers as BDMV-REC is quite a rara avis.
Put some samples, so people could test the players they own.
Born in the USB (not USA)
Old 5th April 2011, 22:20   #4  |  Link
setarip_old
setarip_old's Avatar
@louv68
Hi!
I'd suggest that you additionally post your question at the DVDFab Forum:
1) The BDMV-REC "solution" was devised by the folks at DVDFab, so they may already have some knowledge in this regard.
2) Additionally, their forum is far more active regarding the pursuit of this "solution".
3) You won't have to be concerned with posts that are unnecessarily made partially in Latin at this English-only forum ;>}
Also, as stated by MickJT, the PS3 is capable of playing such discs - and is likely the most prevalent...
setarip_old is offline   Reply With Quote
aacs protected, bdmv-rec, bluray, cinavia, dvdfab
