2nd May 2010, 07:12 | #21 | Link |
PgcEdit daemon
Control+Shift+V means Control+upper case V. So, if Caps-Lock is on, you need to type Control-v without the shift key, and if it is off, you have to hold shift. In other words, use Control+whatever key combination you use to type "V" in notepad.
2nd May 2010, 22:59 | #22 | Link | |
And here I thought hardware went bad all at once. Thanks!!! Last edited by Gothmog; 3rd May 2010 at 03:36. Reason: rule 4 |
16th July 2010, 23:11 | #23 | Link |
Is there an unattended way to open a DVD folder, search for BOVs, "Remove useless stuff", save, and then exit?
I tried to make a little app in C# to perform those tasks by retrieving the handles of PgcEdit buttons, and sending Windows messages to them, but apparently windows made in Tcl/Tk work different than regular Win32 windows, because that didn't work as I expected. For example, trying to use WM_CLOSE to close some windows (like "Verify number of streams") actually minimizes them. I guess I should study some Tcl and write a plugin to automatize that. (Sorry for my poor English.) |
17th July 2010, 09:44 | #24 | Link | |
PgcEdit daemon
Unfortunately, you cannot just launch the Remove Useless Stuff procedure from the plugin, as it opens a window. But you can launch the procedures that Remove Useless Stuff uses, one at a time. (Note however that sometimes, one of these procedures can display a dialog box if it encounters a problem, so there is no guarantee that it will work completely unattended.) Try this: Code:
# Launch Remove Useless Stuff unattended # check if a DVD has been loaded at startup if {[info exists ::dvddir]} { # Delete all useless Dead Commands ::main::clean_up_dvd 2 if {$::dvd_modified} {::main::Write_DVD false} # Delete all useless Dead Buttons and BOVs ::macros::delete_all_dead_buttons true if {$::dvd_modified} {::main::Write_DVD false} # Delete all unreferenced cell commands ::utils::delete_all_unreferenced_cell_commands true if {$::dvd_modified} {::main::Write_DVD false} # Delete completely all uncalled Titlesets ::utils::delete_uncalled_vts true if {$::dvd_modified} {::main::Write_DVD false} # Clear useless Set commands and free useless GPRMs ::macros::clear_useless_set_commands true # Clear jumps and links to void PGCs ::utils::clear_jumps_to_void_pgcs true if {$::dvd_modified} {::main::Write_DVD false} # Remove useless menu VOB files ::macros::remove_useless_menu_vobs true # Delete all uncalled PGCs ::utils::delete_all_uncalled true if {$::dvd_modified} {::main::Write_DVD false} # Delete all NOPs ::main::clean_up_dvd -2 if {$::dvd_modified} {::main::Write_DVD false} # close PgcEdit exit } Note that you will need to copy the PgcEdit installation folder elsewhere and add the plugin in that folder only, or you will not been able to use PgcEdit without running your plugin when a DVD is opened at startup. Note also that I have not tested the method. I hope it works. :-)
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 17th July 2010 at 09:52. |
21st July 2010, 14:34 | #25 | Link |
Conflict between PGCedit and Vobblanker options.
Preprocessed the VOB with PGCedit (including "remove unwanted stuff": all options checked). Then run Voblanker ( with 32k gaps unchecked, VIDEO_TS= 0k, otherwise 64k).
With 32k gaps unchecked (in Vobblanker options), no issue. With 32k gaps checked (in Vobblanker options), if I rerun "remove unwanted stuff" VIDEO_TS goes down to 0k (instead of 64k), meaning I probably have to rerun Vobblanker. It seems that it is the option "remove unnecessary Menu VOB" that makes the difference. I understand it may be normal behaviour but I would like to know what options I should unckeck in "Remove useless stuff" if I decide to rerun with a future version without having to rerun Vobblanker. Thanks in advance. Last edited by mikenadia; 21st July 2010 at 23:14. Reason: Thanks, r0lZ |
21st July 2010, 21:10 | #26 | Link |
PgcEdit daemon
PgcEdit and ImgBurn use a special technique commonly called "64K gaps" to be sure that the IFO and BUP files are placed in different ECC (error correction) blocks of the DVD. For example, when there is no VIDEO_TS.VOB file, VIDEO_TS.BUP is placed on disc after VIDEO_TS.IFO and a gap so that a read error in one ECC block doesn't ruin both files.
In the other hand, VobBlanker has an option to create a blank VIDEO_TS.VOB file to fill the gap. Therefore, the IFO and BUP will always be on different ECC blocks, even with burning program that rebuild the IFO and suppress the gap, such as Nero. If you don't burn with ImgBurn, then the VobBlanker option might be useful. But if you burn with ImgBurn or if you create an ISO with PgcEdit (with the 32k gap option enabled), then the VOB file is absolutely useless. Anyway, PgcEdit's Remove Useless Stuff does what it is supposed to do: it removes the useless VOB file. Of course, you can untick that option if you need the VIDEO_TS.VOB file, but take care. Some commercial DVDs create huge VIDEO_TS.VOB files, just to align the layer break correctly. Not removing them is a great waste of space if you want to burn the DVD on a single layer disc. And note that the other useless menu VOBs will not be removed either, and it is rarely necessary to create gaps between VTS IFO and BUP files, since there is always at least one VOB file between the two files on disc.
27th July 2010, 15:31 | #27 | Link | |
Do you run "Remove Useless Stuff" (Ctrl+Shift+R) the second time with all the options ticked or just with the the remove NOPs box ticked? Does it hurt to run as after opening the DVD with them all ticked? (I'm assuming no but thought I'd ask). thx... |
27th July 2010, 18:44 | #28 | Link |
PgcEdit daemon
You can tick all options both times, especially if you have modified the navigation. PgcEdit might find new stuff to remove. Also, sometimes, running all options two times can be useful, as some cleanup functions can free stuff that can be only removed during the second pass. (I did my best to put the functions in the most useful order, but I had to take the speed of the operations into account, and the best order depends of each DVD.)
Anyway, Remove Useless Stuff should be transparent to the navigation (unless there is a bug somewhere).
30th July 2010, 15:53 | #30 | Link |
Cosmetics
1) Straight from the rip. Code:
[71 00 00 05 00 00 00 00] 1 Set gprm(5) =(mov) 0 [71 00 00 02 00 00 00 00] 2 Set gprm(2) =(mov) 0 [00 C1 00 01 00 06 00 05] 3 if ( gprm(1) >= 6 ) then { Goto line 5 } [30 06 00 01 03 83 00 00] 4 (JumpSS) Jump to VTSM 3, Root menu (TTN 1) [30 06 00 01 07 83 00 00] 5 (JumpSS) Jump to VTSM 7, Root menu (TTN 1) [30 06 00 00 00 00 00 00] 6 (JumpSS) Jump to First Play PGC But VTSM 7 does not exist , so line 5 is a Jump to nowhere, but because line 5 is a Jump and because there is no Goto line 6 , line 6 is considered as a Dead command and is deleted while running "Remove useless stuff". 2) Sometimes, I have Code:
[71 00 00 05 20 00 00 00] 1 Set gprm(5) =(mov) 8192 [71 00 00 05 00 01 00 00] 2 Set gprm(5) =(mov) 1 [71 00 00 03 00 01 00 00] 3 Set gprm(3) =(mov) 1 [30 02 00 00 00 01 00 00] 4 (JumpTT) Jump to Title 1 Thanks in advance. |
30th July 2010, 16:10 | #31 | Link |
PgcEdit daemon
1) I don't see your point. PgcEdit can delete line 6, as normally it cannot be executed. The fact that line 5 is a jump to nowhere doesn't change that. A player should normally hang on that line. If it doesn't hang, you're lucky, but you cannot assume that all players will happily continue to the next line.
PgcEdit could be smarter and check if the condition of the test in line 3 can never be true, and when it's the case, it could delete lines 3, 5 and 6, but it is extremely difficult to do that (especially as I have to take the speed of the operations into account and verifying all possible values of a GPRM in each condition is much too slow). 2) When the second command's operator is =(mov), then yes, you can safely remove the previous set, as the value of the GPRM is overwritten anyway.
30th July 2010, 16:17 | #32 | Link |
I understand but my point is that "Remove useless stuff" should not delete line 6 (assuming that it is a Dead command) without checking that the previous Jump (here line 5) is not a Jump to Nowhere.
Otherwise, I have to make sure to have solved all the " Jump to nowhere" issues before running " Remove useless stuff". The intent of the DVD is to have lines 1, 2, 3,4, 6 left, I think. Thanks. Edit: I was not asking for lines 3, 5 , 6 to be removed and the "Jump to nowhere" check will be welcome , if there is no objection. Edit2:If you insert a conditionnal Goto to a non existing line ( the last one + 1), when you create that line, the conditionnal GOto is modified (the last one (before any modifications ) +2). Just cosmetics. One click away. (Or when you insert a conditionnal Goto to a non existing line, it may create automatically the missing lines). Also, selecting more than one line, and clicking on Add only creates one line. Last edited by mikenadia; 30th July 2010 at 17:29. |
30th July 2010, 16:28 | #33 | Link |
PgcEdit daemon
Well, I could add a global check for Jumps to Nowhere as the first step of Remove useless stuff or just before Delete Dead Commands, and issue a warning when there are jumps to nowhere, but as I have explained, it is not possible to check every command before processing them, because that's too slow.
7th September 2010, 09:58 | #34 | Link |
Banned
Hello r0lZ,
I want to set the sound on as standard in PgcEditPreview.exe. It's very useful when I check the chapterpoints for noise. How to do it? I don't see a PgcEdit option at the options dialog menu. Perhaps you can implement a button? |
7th September 2010, 11:55 | #35 | Link |
PgcEdit daemon
The Preview options are in the Preview menu.
Tick Preview -> Playback Mode -> Real Time With Audio, and select the option you prefer in Preview -> Default Audio Stream. If you tick "Based on Virtual Player Setup", be sure to set the right language code in the Player Setups for SPRM 16.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 7th September 2010 at 11:57. |
9th October 2010, 15:27 | #37 | Link |
Cosmetics.
Straight from the rip (lines 2 to 5 of the pre-command highlighted in purple). Code:
[20 04 00 00 00 00 00 02] 1 LinkPGCN PGC 2 [61 00 00 05 00 8D 00 00] 2 Set gprm(5) =(mov) sprm(13:Parental level) [79 00 00 05 00 0F 00 00] 3 Set gprm(5) &=(and) 15 (preserve bits 0-3) [20 C4 00 05 00 06 00 04] 4 if ( gprm(5) >= 6 ) then { LinkPGCN PGC 4 } [71 00 00 05 00 00 00 00] 5 Set gprm(5) =(mov) 0 ********** post commands: [00 B1 00 05 00 01 00 03] 1 if ( gprm(5) != 1 ) then { Goto line 3 } [00 03 00 00 00 00 08 04] 2 (SetTmpPML) Set parental level =(mov) 8, Goto line 4 [20 04 00 00 00 00 00 03] 3 LinkPGCN PGC 3 [20 04 00 00 00 00 00 04] 4 LinkPGCN PGC 4 ********** cell commands: (lines 2 to 7 of the pre-command highlighted in purple). Code:
[20 04 00 00 00 00 00 02] 1 LinkPGCN PGC 2 [56 00 00 00 04 00 00 00] 2 (SetHL_BTN) Set Highlighted Button =(mov) 1024 (button 1) [71 00 00 05 00 01 00 00] 3 Set gprm(5) =(mov) 1 [00 B1 00 05 00 01 00 06] 4 if ( gprm(5) != 1 ) then { Goto line 6 } [00 03 00 00 00 00 04 07] 5 (SetTmpPML) Set parental level =(mov) 4, Goto line 7 [20 06 00 00 00 00 00 02] 6 LinkPGN Program 2 [20 04 00 00 00 00 00 06] 7 LinkPGCN PGC 6 ********** post commands: [56 00 00 00 04 00 00 00] 1 (SetHL_BTN) Set Highlighted Button =(mov) 1024 (button 1) [71 00 00 05 00 01 00 00] 2 Set gprm(5) =(mov) 1 [00 B1 00 05 00 01 00 05] 3 if ( gprm(5) != 1 ) then { Goto line 5 } [00 03 00 00 00 00 04 06] 4 (SetTmpPML) Set parental level =(mov) 4, Goto line 6 [20 06 00 00 00 00 00 02] 5 LinkPGN Program 2 [20 04 00 00 00 00 00 06] 6 LinkPGCN PGC 6 ********** cell commands: Thanks in advance. Last edited by mikenadia; 9th October 2010 at 21:50. Reason: Thanks, rOlz |
9th October 2010, 18:43 | #38 | Link |
PgcEdit daemon
You're right. PgcEdit should have removed the purple lines. (Purple is assigned to the "dead" lines: the lines that cannot be executed due to non-conditional jumps or gotos.)
I'm not sure why PgcEdit has not removed them. (The function that removes the dead lines is new and still not perfect, and I prefer to leave some dead lines than to remove useful ones!) Anyway, I will have a look. Thanks for the detailed example. :-)
9th October 2010, 23:10 | #39 | Link |
PgcEdit daemon
Hum, I don't know how you did your tests, but on my system, PgcEdit has removed the dead commands correctly.
If you still have the files, can you try DVD -> Delete All Dead Commands alone? Also, what version are you using?
10th October 2010, 02:25 | #40 | Link |
I am using 9.3.0.1000 . The dead commands are deleted when using the "Delete Dead command" alone.
The problem arises when , in " Remove useless stuff", the Delete Dead command" is used in combination with "Remove useless menu VOB when possible". Then I am asked to Kill Playback on the two "Parental Mgt" menus (recognized as useless) and the "deleted command " reappear somehow. After having done "Remove useless stuff" with only the "Delete Dead command" and "Remove useless menu VOB when possible" checked, I have Code:
[20 04 00 00 00 00 00 02] 1 LinkPGCN PGC 2 [00 00 00 00 00 00 00 00] 2 NOP [56 00 00 00 04 00 00 00] 3 (SetHL_BTN) Set Highlighted Button =(mov) 1024 (button 1) [71 00 00 05 00 01 00 00] 4 Set gprm(5) =(mov) 1 [00 00 00 00 00 00 00 00] 5 NOP [00 B1 00 05 00 01 00 08] 6 if ( gprm(5) != 1 ) then { Goto line 8 } [00 03 00 00 00 00 08 09] 7 (SetTmpPML) Set parental level =(mov) 8, Goto line 9 [20 04 00 00 00 00 00 03] 8 LinkPGCN PGC 3 [20 04 00 00 00 00 00 04] 9 LinkPGCN PGC 4 Edit: after only doing "Remove useless menu VOBS, some dead commands are added (now, lines 2 to 13 are highlighted purple). Actually, the lines 7 to 13 are added everytime I run "Remove useless menu VOBs", that is why they reappear if I run "Remove useless stuff " twice even I do not have any "Killing Playback" the second time. And those lines are identical if I "kill Playback" on those two " Parental Mgt " PGCs straight from the rip (they are also dead commands). Code:
********** pre commands: [20 04 00 00 00 00 00 02] 1 LinkPGCN PGC 2 [61 00 00 05 00 8D 00 00] 2 Set gprm(5) =(mov) sprm(13:Parental level) [79 00 00 05 00 0F 00 00] 3 Set gprm(5) &=(and) 15 (preserve bits 0-3) [20 C4 00 05 00 04 00 02] 4 if ( gprm(5) >= 4 ) then { LinkPGCN PGC 2 } [71 00 00 05 00 00 00 00] 5 Set gprm(5) =(mov) 0 [00 00 00 00 00 00 00 00] 6 NOP [56 00 00 00 04 00 00 00] 7 (SetHL_BTN) Set Highlighted Button =(mov) 1024 (button 1) [71 00 00 05 00 01 00 00] 8 Set gprm(5) =(mov) 1 [00 00 00 00 00 00 00 00] 9 NOP [00 B1 00 05 00 01 00 0C] 10 if ( gprm(5) != 1 ) then { Goto line 12 } [00 03 00 00 00 00 04 0D] 11 (SetTmpPML) Set parental level =(mov) 4, Goto line 13 [20 06 00 00 00 00 00 02] 12 LinkPGN Program 2 [20 04 00 00 00 00 00 06] 13 LinkPGCN PGC 6 Last edited by mikenadia; 10th October 2010 at 04:05. |
