Old 26th August 2010, 10:07   #1001  |  Link
schweinsz
Originally Posted by sneaker_ger View Post
stage0
stage1
DiAVC init successed
start receive
start receive
start receive ... ("start receive" loops forever)
no crash
Ok, but do you observed the output of frames? Do the MPC-HC keep black screen forever?
schweinsz is offline   Reply With Quote
Old 26th August 2010, 10:09   #1002  |  Link
schweinsz
Originally Posted by xv View Post
For me it didnīt crash (on Windows XP x64, Athlon 64 X2). I also checked the output file, seems ok, only the frame order doesnīt seem to be ok on the file you provided. I also tested some other files, no problem with them. The new version makes no difference for me, only more verbose output.
If the win32.exe works fine, I believe the frame order is OK. The sequence is one of my test sequences, I often use it to verify the correctness of my decoder.
May I ask when you fix the comptability problem of DiAVC with DVBViewer?
I fixed a bug yesterday, perhaps it relate to the compatibility problem.
Old 26th August 2010, 10:47   #1003  |  Link
sneaker_ger
It will only output black frames (though with the correct width & height it seems). It would sometimes output 1 or 2 non-black frames in older versions, but I cannot reproduce it anymore.
Old 26th August 2010, 10:56   #1004  |  Link
xv
I resized/compressed the output of your decoder and attached it to this post. During the zoom it jumps back several times. With other files I decoded that didnīt happen, but I only tested progressive files.
Great! Could you send me a trial version to check that? Iīll already send you a mail. If it works Iīll buy DiAVC immediately.
xv is offline   Reply With Quote
Old 26th August 2010, 12:14   #1005  |  Link
schweinsz
Which splitter do you use?
Old 26th August 2010, 12:22   #1006  |  Link
sneaker_ger
mkv: haali, gabest
mp4: gabest
ts: gabest
Old 26th August 2010, 12:47   #1007  |  Link
@schweinsz
What splitter(s) do you recommend?
Old 26th August 2010, 13:02   #1008  |  Link
schweinsz
@schweinsz
I use the Haali and gabest, but I can't get the question.
Old 26th August 2010, 13:23   #1009  |  Link
I just meant which ones do you think work best with your decoder.
You have apparently answered the question. Thank you.
Old 26th August 2010, 15:40   #1010  |  Link
schweinsz
I verified the output of the DiAVC cmd with the jm just then and found that it IS correct. The sequence is generated using the JM by me to verify the correctness of my decoder, but I don't know why it is so bad.
Old 26th August 2010, 23:04   #1011  |  Link
DeathWolf
DeathWolf's Avatar
Download the new built DiAVC filter, try it with the UAC opening. I built the new version with the "UAC Execution Level"==RequireAdministrator. Perhaps it helps.
I tried this one, but I only get black frames in mpc-hc, regardless of the splitter.
stage0/stage1/diavc init appear first, then the frame resizes, and after that start receive, but no matter how many times I press ok I never get any actual valid non black frame.
EDIT: forgot to mention, core i7 on windows 7 x64(but 32 bit player)
EDIT2: oh and UAC is off, so no UAC issues
DeathWolf is offline   Reply With Quote
Old 28th August 2010, 19:29   #1012  |  Link
TheRyuu
warpsharpened
Same boat as DW.
On Windows 7 64bit and DiAVC is crashing (with 32bit mpc). I also have UAC off and on the same setup as DW as well.
TheRyuu is offline   Reply With Quote
Old 28th August 2010, 21:45   #1013  |  Link
Fadeout
The filter hasn't been updated in months, so we have to wait at the very least to try a new version.
Fadeout is offline   Reply With Quote
Old 29th August 2010, 10:49   #1014  |  Link
paulvdb
I just tested the x64 diavcx64v1.7z. It works on Windows 7 x64 but crashes on Windows XP x64. It goes as far as this:
nHighestFeature  11
nLogicalProcessors   32
intelcpu 1 corenum 32  multithrd 1  decoders 16 inited!
 1 decoder inited!
 2 decoder inited!
 3 decoder inited!
 4 decoder inited!
 5 decoder inited!
 6 decoder inited!
 7 decoder inited!
 8 decoder inited!
 9 decoder inited!
10 decoder inited!
11 decoder inited!
12 decoder inited!
13 decoder inited!
14 decoder inited!
15 decoder inited!
And then it crashes.
paulvdb is offline   Reply With Quote
Old 29th August 2010, 18:55   #1015  |  Link
schweinsz
nHighestFeature  11
 1 decoder inited!
 2 decoder inited!
 3 decoder inited!
 4 decoder inited!
 5 decoder inited!
 6 decoder inited!
 7 decoder inited!
 8 decoder inited!
 9 decoder inited!
10 decoder inited!
11 decoder inited!
12 decoder inited!
13 decoder inited!
14 decoder inited!
15 decoder inited!
I am curious that the __cpuid get the wrong number of the logical processors on XP x64.
Ok, download the new DiAVC x64 cmd and try it.
Old 29th August 2010, 22:55   #1016  |  Link
TheRyuu
warpsharpened
I'm on Windows 7 64bit and that new one says I have 16 logical processors (I have an i7 with HT on) so shouldn't it say 8?
Edit:
diavcx64>win32.exe   tempete_704x480.264            tempe
te_704x480.yuv
nHighestFeature  11
nLogicalProcessors   16
intelcpu 1 corenum 16  multithrd 1  decoders 14 inited!
 1 decoder inited!
 2 decoder inited!
 3 decoder inited!
 4 decoder inited!
 5 decoder inited!
 6 decoder inited!
 7 decoder inited!
 8 decoder inited!
 9 decoder inited!
10 decoder inited!
11 decoder inited!
12 decoder inited!
13 decoder inited!
249 frames decoded totally.
68138 counters used by decoder and 461222 counters used by others.
Decoding speed: 12923 fps
D:\Encoding\diavcx64v2\diavcx64>pause
Old 30th August 2010, 01:58   #1017  |  Link
Stephen R. Savage
Stephen R. Savage's Avatar
[...]\diavcx64>win32.exe tempete_704x480.264 te
mpete_704x480.yuv
nHighestFeature 10
nLogicalProcessors 2
intelcpu 1 corenum 2 multithrd 1 decoders 5 inited!
1 decoder inited!
2 decoder inited!
3 decoder inited!
4 decoder inited!
609686 counters used by decoder and 1018987 counters used by others.
Decoding speed: 795 fps
[...]\diavcx64>pause
Press any key to continue . . .
Windows 7 64-bit, Core 2 Duo. I am a bit curious as to why it chooses to start 5 threads. Incidentally, DiAVC 1.1 works fine in MPC-HC 32-bit for me.
Stephen R. Savage is offline   Reply With Quote
Old 30th August 2010, 06:40   #1018  |  Link
paulvdb
nHighestFeature  11
intelcpu 1 corenum 32  multithrd 1  decoders 14 inited!
 1 decoder inited!
 2 decoder inited!
 3 decoder inited!
 4 decoder inited!
 5 decoder inited!
 6 decoder inited!
 7 decoder inited!
 8 decoder inited!
 9 decoder inited!
10 decoder inited!
11 decoder inited!
12 decoder inited!
13 decoder inited!
55817866 counters used by decoder and 562498740 counters used by others.
Decoding speed: 14903 fps
Old 31st August 2010, 00:35   #1019  |  Link
TheRyuu
warpsharpened
So what's the eta on fixing this for Windows 7 64bit?
Old 31st August 2010, 12:44   #1020  |  Link
schweinsz
I meet some trouble that I am not familar with, so I need several days to fix it.
avc, diavc, fastest decoder, h.264, software
