Old 22nd April 2012, 14:51   #14961  |  Link
adam777
4432 is available at XhmikosR's - http://xhmikosr.1f0.de/ffdshow/
adam777 is offline   Reply With Quote
Old 24th April 2012, 06:51   #14962  |  Link
aufkrawall
Why aren't the input levels set to Auto?
It's working fine for me. Correctly flagged streams get correctly treated.
I guess that's what LAV is doing by default and you can't even change this in the GUI.
I suggest to make Auto default.
It also seems that this option is broken anyway or I haven't understood what it is doing exactly.
I extracted a frame of a source with both TV and PC input levels and both frames were bit exact.
That's why I think it is broken.
But no need to fix it, IMHO it can be entirely removed and set to Auto.
Old 24th April 2012, 14:12   #14963  |  Link
egur
QuickSync Decoder author
For normal systems "levels" should be off. It would make sense to use in order to transcode a poorly encoded file.
Eric Gur,
Processor Application Engineer for Overclocking and CPU technologies
Intel QuickSync Decoder author
Intel Corp.
egur is offline   Reply With Quote
Old 24th April 2012, 14:56   #14964  |  Link
aufkrawall
Could you explain to me what you mean?
Are we talking about the same thing?
Old 25th April 2012, 07:50   #14965  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
Hi,last ffdshow svn have a bug! when i Enabled mpeg2 by libavcodec!after I Re-open ffdshow Video decoder configuration mpeg2 still Disabled! is this a bug?
download screen recoder files! After seeing this I think you should understand!
http://www.mediafire.com/?w8aw6vbhi1mej44
betaking is offline   Reply With Quote
Old 25th April 2012, 12:52   #14966  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Strange, that problem doesn't happen over here ( r4436, XP Pro w/ SP3 )
Midzuki is offline   Reply With Quote
Old 25th April 2012, 12:52   #14967  |  Link
haruhiko_yamagata
OK, let's change it.
It is used for RGB conversion. If you grab in jpeg or some YCbCr output, it doesn't affect.
[ Download ffdshow | Wiki ]
haruhiko_yamagata is offline   Reply With Quote
Old 25th April 2012, 12:58   #14968  |  Link
betaking
betaking's Avatar
No! XP PRO SP3 have this problem too!
Old 25th April 2012, 14:56   #14969  |  Link
Octo-puss
One of you is wrong :P
Octo-puss is offline   Reply With Quote
Old 25th April 2012, 15:06   #14970  |  Link
haruhiko_yamagata
If I un-install and re-install, I can reproduce.
Old 25th April 2012, 15:53   #14971  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Hmmm... anyway, that glitch is not relevant to me, I'll keep using CLvsd.ax until the DVD-subpics problem gets fixed
Old 25th April 2012, 19:52   #14972  |  Link
aufkrawall
Ok, now I got it.
I've checked with 8 bit x264 I444 videos (PC.601, Rec601, PC.709, Rec709) if it works correctly with Auto and it does so.
Old 26th April 2012, 07:43   #14973  |  Link
Dstruct
Related bug: http://forum.doom9.org/showthread.ph...72#post1562572
Dstruct is offline   Reply With Quote
Old 26th April 2012, 15:42   #14974  |  Link
aufkrawall
What is the reason why Lagarith isn't supported, please?
Old 26th April 2012, 19:51   #14975  |  Link
hoborg
Hi.
ffdshow_rev4430_20120415_xvidvideo-ru_x86-msvc2010.zip is crashing on "i444compressed.mkv" sample. Is that a known issue?
EDIT:
ffdshow_rev4437_20120426_xhmikosr.exe working fine.
Working machine: Win10x64 + Intel Skull Canyon
My HTPC.
How to start with Bitcoin
hoborg is offline   Reply With Quote
Old 27th April 2012, 20:29   #14976  |  Link
Milardo
Hi, can one still compile latest revisions of ffdshow and include the removed vfw codecs? I would like to do that if possible.
Milardo is offline   Reply With Quote
Old 28th April 2012, 02:33   #14977  |  Link
clsid
Not possible. Also they have been removed for good reasons. There are better VFW codecs available. Use those.
MPC-HC 2.2.1
Old 28th April 2012, 19:57   #14978  |  Link
egur
Committed new version of QS decoder - some small fixes mostly for broken files.
No ffdshow code changes.
Eric Gur,
Intel Corp.
Old 2nd May 2012, 02:11   #14979  |  Link
Blight
Software Developer
Blight's Avatar
Looking at the change list for build 4437, I see "remove vobsub support (except DVD sub)." listed.
What does this mean? Is backward compatibility with vobsub broken somehow?
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 2nd May 2012, 11:47   #14980  |  Link
clsid
VobSub support has always been incomplete/buggy.
MPC-HC 2.2.1
