4th May 2006, 21:18 | #1061 | Link | |
@ricardo.santos
I can't help here, please help the AviSynth team to fix it. Quote:
5th May 2006, 17:36 | #1063 | Link |
Just report the bug
5th May 2006, 18:17 | #1064 | Link |
I am encoding TV Mpeg-2 recordings into X264 using the latest Staxrip and I have a question. I usually do not set the resolution until after the compressability check, but I just noticed that the Dos window that does the check has the initial resolution in it. Should I be changing the resolution to my desired resolution before doing the check? Does it in fact check the compressability of the resolution I have it set to?
5th May 2006, 19:19 | #1065 | Link |
The comp. check is mostly to find the resolution, the image size influences the compressibility so you should make a good guess or in your case set the desired image size before doing the comp. check.
5th May 2006, 21:26 | #1066 | Link | |
Do you have a delay in the config dialog? What is your filename? Obviously the delay in the filename must have format StaxRip knows and obviously if StaxRip don't the format the delay can't be detected and the config dialog shows 0 then for the delay.
6th May 2006, 10:31 | #1067 | Link |
I encoded the first file with the 4 digit delay and took the command line from the log file. For the second 3 digit delay file I actually only used "Show command line" in the "Divx Container Configuration" dialog.
This is the command line StaxRip wants to process: "c:\Programme\StaxRip\Applications\DivXMux\DivXMux.exe" -v "C:\Divx-Source\XYZ2\VIDEO_TS\VTS_01_1_EncoderOutput.avi" -a (Audio -de;01) "C:\Divx-Source\XYZ2\VIDEO_TS\VTS_01_1 02 de-German 2_0ch 192Kbps DELAY 570ms.ac3" -o "C:\Divx-Source\XYZ2\VIDEO_TS\VTS_01_1.divx As you can see the audio file has its delay in the filename. I use the latest Hotfix of StaxRip... |
6th May 2006, 10:55 | #1068 | Link |
Do you have a delay in the config dialog of the track after opening that file? There should be a delay and the command line preview in the muxer dialog should show the delay will be passed to the muxer. I have absolutely no clue what is the problem here.
Edit: I think I know what is the problem, I didn't review the code yet and don't remember much detail but it seems StaxRip won't read the delay for muxing profiles, that's reasonable for muxing profiles since it's better to expect the delay was already fixed while reencoding but it can't be expected for AC3 files so you got to enter it manually, I'll fix it and likely will have to force the reset of all audio related settings another time but that seem to be necesarry very often anyway (e.g. once I add the new Nero encoder).
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 6th May 2006 at 11:20. |
6th May 2006, 11:11 | #1069 | Link |
Edit.../Audio Mux Options also shows a delay of zero...
Did not know that you can edit the delay somewhere... So I can at least change it manually. If I do set it manually to 570 StaxRip also puts it (o570) into the command line (Divx Container Configuration dialog). So for some reason StaxRip fails to get the delay from the filename. What I do is the following: I open the .d2v file StaxRip has created. StaxRip then automatically loads the .ac3 file without getting the delay from it. As you probably already saw from the naming structure the .ac3 file was also created or rather renamed by StaxRip - not by me. Edit: Ah, just saw your edit! Ok, then I will do it manually. I wonder why I did not stumble on this earlier... Last edited by Warrex; 6th May 2006 at 12:17. |
6th May 2006, 11:18 | #1070 | Link | |
6th May 2006, 14:29 | #1071 | Link |
Aging Video Hobbyist
Easier way to change -FO argument?
When opening an MPEG2 file, StaxRip performs a demux operation and then invokes DGindex with a commandline that includes FO=0 (field operation, honor pulldown iirc). I have some odd ts captures that require I use "Force Film" in DGindex (for most others the FO=0 is just fine).
I know how to change this DGindex commandline, but it's kind of a PIA to go-in and change it and then change it back again whenever I need to change the -FO argument. Wondering stax if you could think about another way to do this. Ok, as I type this I'm thinking myself that I can add another operation type for MPEG2 files and give it a name I can remember--that would be easier than actually editing the command line every time. So I have a decent workaround, but I guess I'll let this post stand--maybe someone else has the same issue as I do w/Field Operation. |
6th May 2006, 17:37 | #1072 | Link | |
6th May 2006, 21:31 | #1073 | Link | |
Not a big deal I guess--obviously I'm "thinking out loud" here. |
7th May 2006, 02:11 | #1074 | Link |
something is wrong with templates. i've made a one with quicktime import plugin (qtinput "%source_file%") and set it as startup template. when I choose .mov nothing happens, no length, no ar, no source or target path is shown. I mean, it looks like the file is correctly loaded because when I click on 'next' the file gets encoded. it just doesn't show any info about that file. I tried to save template with Directshowsource but exactly the same thing happens. i'm using 0.9.9.2. version 0.9.91 and previous were working fine.
(!sig) Last edited by krisq; 7th May 2006 at 02:16. |
7th May 2006, 09:53 | #1075 | Link |
@laserfan
It might be possible to invoke a script that shows a message box and invokes DGIndex instead of invoking DGIndex directly. There might be other solutions but like I said I'm clueless about the topic so I can't help much. Too make it clearer, I don't help with things I don't understand at least good enough to know what I'm doing is good, I mean field processing when NTSC is involved. Maybe you can send me a sample and tell me how and why you process it with DGndex manually. @krisq Please send a sample and needed filters.
7th May 2006, 12:31 | #1076 | Link |
Hi Stax.
These are my settings that doesn't work for me with any file (avi, mov, etc.). Template is with Directshowsource so I don't have to give you any additional files. my settings and startup template If you want more info I'll gladly provide it
(!sig) Last edited by krisq; 7th May 2006 at 12:36. |
7th May 2006, 12:43 | #1077 | Link |
I need a sample clip and quicktime dshow decoding filters. The defaults are supposed to work because MPEG-2 source excepts d2v and if it aint't d2v StaxRip will automatically use DirectShowSource instead (or AVISource if it's AVI), for dshow audio decoding the preparer needs to know the file extension which can be defined in the options.
7th May 2006, 13:19 | #1078 | Link |
Ok, watch it and you'll understand what i'm talking about.
bug.avi 1.2mb
(!sig) |
7th May 2006, 15:21 | #1079 | Link | |
My (extraordinarily limited and possibly even incorrect) understanding of DGindex is that the -FO=0 argument that StaxRip incorporates (which "honors pulldown flags" in MPEG2 files) is suitable for most material, and that -FO=1 (Force Film i.e. doesn't need or use the pulldown flags to work when film is encoded for video) is a special case. So I found a special case where I have to use -FO=1, at least I can't figure out any other way to get the conversion to work properly otherwise. But no worries, I will use the workaround I posted earlier for these shows. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
