Old 5th February 2013, 13:53   #1  |  Link
LanguidLegend
Batch file editing using MKVToolNix
So basically what I'm trying to do is to recursively search out MKV and AVI files in a particular folder and change their apsect ratios to 16:9.
Here is the folder/files setup:
MainFolder\
MainFolder\file1.mkv
MainFolder\file2.avi
MainFolder\Subfolder1\
MainFolder\Subfolder1\file1.mkv
MainFolder\Subfolder1\file2.avi
MainFolder\Subfolder2\
MainFolder\Subfolder2\file.mkv
Here is what I have so far in my batch file (fixAspect.bat):
@echo off
SET mkvmerge="C:\Program Files (x86)\MKVToolNix\mkvmerge.exe"
CD [C:\...\MainFolder]
FOR /R %%I IN (*.mkv) DO (mkvmerge -v -o "%%~nI (remux).mkv" "--aspect-ratio 16/9" "%%~I")
PAUSE
However it seems to skip right down to the PAUSE line every time.. any ideas why?
LanguidLegend is offline   Reply With Quote
Old 5th February 2013, 14:02   #2  |  Link
sneaker_ger
Any error messages?
For --aspect-ratio you have to supply a trackID: --aspect-ratio 0:16/9
Mkvpropedit can edit display width and height without remuxing, btw.
Old 5th February 2013, 14:09   #3  |  Link
LanguidLegend
Originally Posted by sneaker_ger View Post
Any error messages?
Thanks for the quick reply!
So how would I replace mkvmerge with mkvpropedit in that example?
Old 5th February 2013, 14:19   #4  |  Link
sneaker_ger
You can either set the values in pixels (most common), like e.g.:
mkvpropedit "%%I" --edit track:v1 --set display-width=1920 --set display-height=1080
Or less common:
mkvpropedit "%%I" --edit track:v1 --set display-width=16 --set display-height=9 --set display-unit=3
Be careful when working on files without a backup. What exactly has to be done depends highly on the source files - working with anamorphic files is not trivial.
Old 5th February 2013, 14:34   #5  |  Link
LanguidLegend
Do you know where I can find a complete list of options for the command, because the source website doesn't list those.
Old 5th February 2013, 15:00   #6  |  Link
sneaker_ger
Just run the very first command listed on that website:
mkvpropedit -l
Explanations for valid values are listed in the mkv specs.
Old 5th February 2013, 15:37   #7  |  Link
LanguidLegend
That's awesome, think I got it working!
Thanks
One last thing: I've also been trying to write a batch file which would search folders recursively, merging subtitles (.srt files) with the video files of the same name. Would you know how to do that?
Old 5th February 2013, 16:07   #8  |  Link
sneaker_ger
FOR /R %%I IN (*.srt) DO (
if exist "%%~nI.mkv" mkvmerge -o "%%~nI (remux).mkv" "%%~nI.mkv" "%%I"
Old 5th February 2013, 16:09   #9  |  Link
LanguidLegend
Actually I'm stuck on one snag.
Here is my batch file now:
@echo on
SET /P folder=Source folder:
CD /D %folder%
PAUSE
FOR /R %%I IN (*.mkv) DO (mkvpropedit "%%~I" --edit track=v1 --set display-width=16 --set display-height=9 --set display-unit=3)
but I get this output:
A:\#Videos\Movies\#Comedy>(mkvpropedit "A:\#Videos\...\file.mkv" --edit track=v1 --set display-width=16 --set display-height=9 --set display-unit=3)
Error: Invalid selector in '--edit track=v1'.
Old 5th February 2013, 16:13   #10  |  Link
sneaker_ger
--edit track:v1 with ":".
Old 5th February 2013, 16:13   #11  |  Link
LanguidLegend
oh.... haha thanks
Old 5th February 2013, 16:29   #12  |  Link
LanguidLegend
Thanks for all your help sneaker!
Do you know if there is any utility like this which raises or lowers a video's overall volume?
Old 5th February 2013, 16:31   #13  |  Link
sneaker_ger
None that I know of. There are programs like mp3 gain, aac gain and maybe a few others which could be incorporated into a batch but I don't think anything exists that works directly on mkvfiles without re-encoding.
Old 5th February 2013, 16:36   #14  |  Link
LanguidLegend
Aw too bad, because its weird - I have some files (even within the same season/folder) which are very noticeably louder or quieter than the others. I've tried the replay gain option with VLC but it didn't really make a difference..
Old 5th February 2013, 17:29   #15  |  Link
sneaker_ger
I'm not saying it's impossible, but it requires some work (time) and depending on the format you'll have to live with quality degradation (though it may be impossible not hear).
Old 18th February 2013, 10:46   #16  |  Link
LanguidLegend
Hey sneaker, got another quick followup question for ya.
So here's my code:
@echo off
setlocal enabledelayedexpansion
CD /D %folder%
FOR /R %%I IN (*.avi) DO (
	ECHO %%~fI
	IF EXIST "%%~fI" ( :if an avi file exists, convert it
		echo "%%~I" exists
		mkvmerge -o "%%~dI%%~pI%%~nI.mkv" "%%I"
		IF EXIST "%%~nI.mkv" ( :if mkv conversion successful, then delete source file
			RECYCLE "%%~fI"
			ECHO "%%~I DELETED" )
FOR /R %%I IN (*.mp4) DO (
	ECHO %%~fI
	IF EXIST "%%~fI" ( :if an mp4 file exists, convert it
		echo "%%~I" exists
			RECYCLE "%%~fI"
pause
FOR /R %%I IN (*.mkv) DO (mkvpropedit "%%~I" --edit track:v1 --set display-width=16 --set display-height=9 --set display-unit=3)
It is going through folders I know have avi & mp4 files in them but the IF EXIST conditional keeps failing for some reason..
Old 18th February 2013, 10:53   #17  |  Link
LanguidLegend
Actually, figured it out -- had to comment out the setlocal line..
aspect ratio, batch, mkvmerge, mkvtoolnix, subfolders
