Old 1st July 2013, 03:35   #21  |  Link
vdcrim
Originally Posted by real.finder View Post
hi, first thank you for wonderful macros
I wonder if you could made macro that create x264 qpfile from the mkv chapters with support v1 & v2 timecodes and cfr too
Here's a demo (actually just a quickly modified 'Insert Trims from Matroska chapter file'). Not really what you ask for, because:
  • Only CFR
  • May not work properly for some ordered chapters or editions
Is it worth to make a better version? I'm sure you already know that vfr.py can create a qpfile at the same time as the chapter file.
Last edited by vdcrim; 3rd July 2013 at 12:56. Reason: updated link to the final version
vdcrim is offline   Reply With Quote
Old 1st July 2013, 05:18   #22  |  Link
real.finder
thank you for demo
yes, I know that, but the vfr.py create it from trims only.
And the author said: "Conversion from a different input fps to output fps is not accurate"
and I'm working on a lot of sources, most of them have output fps =\= input fps (Whether vfr or cfr)
So I think I can create the chapter by vfr.py and then convert the chapter to qpfile
Because whatever the input fps different from the output fps, the chapter is Time Stats
So when I convert it to qpfile, I can choose the new fps for new video as I want
Thank you in advance
Old 2nd July 2013, 03:25   #23  |  Link
vdcrim
From what I see the frame numbers are corrected before writing them to the qpfile when the output fps is different from the input. That means that vfr.py and the macro above should produce the same result if all is correct.
To avoid that possible inaccuracy the readme talks about you can instead add a new line of contiguous Trims at the bottom of the script, and then use the --ofps value as --fps and drop the former from the command line, and add --reverse as well.
Old 2nd July 2013, 09:00   #24  |  Link
real.finder
I see, so I have to write new trims line after the new fps
In this case it will not differentiate much than I wrote qpfile manually
Also, vfr.py work from the trims only, it is not convert chapter to qpfile
anyway, thank you
Old 2nd July 2013, 13:13   #25  |  Link
vdcrim
anyway, thank you
I've never used vfr.py's fps convertion option and can't really talk about its possible inaccuracy, but anyway as the chapter file and the qpfile are created from the same corrected frames/times the frames in the qpfile should match the chapter starting times. If I understand well the thing that could be not completely exact is those starting times. So you would still have to write new trims anyway. Better try asking RiCON/wiiaboo about this.
Old 2nd July 2013, 14:39   #26  |  Link
real.finder
thank you, I'll try to edit your demo myself
Old 2nd July 2013, 14:46   #27  |  Link
vdcrim
What I'm saying is that a macro may not be more accurate that vfr.py's qpfile. Again, ask wiiaboo what he means by 'conversion from a different input fps to output fps is not accurate'.
Old 2nd July 2013, 14:58   #28  |  Link
real.finder
from vfr.py Thread
"Can output a qpfile with converted frames meant to be used for an ivtc'd encode using non-ivtc'd frames (feature inspired by automkvchapters) (not completely accurate, obviously);"
and like I say, I need a chapter to qpfile converter
Because I work on sources not need to trim and have a chapter already
thank you again
Old 2nd July 2013, 15:18   #29  |  Link
vdcrim
from vfr.py Thread
That doesn't say from where the inaccuracy comes from. And anyway a macro would have exactly the same input data to produce a qpfile, so there's not reason to think it would be better. Again, as I don't use --ofps I can't say if vfr.py works as expected.
OK then, I'll work on it.
Old 3rd July 2013, 01:25   #30  |  Link
vdcrim
Timecode support added. Try this (raw link).
Old 3rd July 2013, 06:54   #31  |  Link
real.finder
thank you very much I'll try it
Old 3rd July 2013, 10:25   #32  |  Link
real.finder
it work great
thank you, you are life saver
Old 17th March 2014, 10:19   #33  |  Link
real.finder
hi, I have two mod
Insert Trims from bookmarks MOD (single-line).py
to make a full trims line from 1 bookmark or more
QP file from Matroska chapter file (IDR).py
same as "QP file from Matroska chapter file" but the qp file will be I (IDR) instead of k, useful for open-gop, more details here
edit: another mod macros https://forum.doom9.org/showthread.p...49#post1770449
Old 18th March 2014, 00:39   #34  |  Link
vdcrim
i-frames with recovery point SEI (that your link shows that K uses for open-gop) should be seekable as well. Did you misread somewhere or did you really notice artifacts when using K instead of I?
Old 20th March 2014, 00:48   #35  |  Link
real.finder
I did't notice anything, but for more safety, and good place to cut without re-encoding
See My Avisynth Stuff
Old 15th June 2016, 03:59   #36  |  Link
real.finder
hi
I did some edit, in "time2ms" and make "QP file from Matroska chapter file" work with mp4 chapters too, I change the name to "QP file from chapter file"
edit: added .ogm too
mod 3 for fix some float cases
github https://github.com/realfinder/AvsP-macros
Old 20th May 2018, 16:54   #37  |  Link
JudgeDredd
what exactly are my options for -c switch ? I tried utf-8 etc but non works
JudgeDredd is offline   Reply With Quote
Old 27th May 2021, 12:18   #38  |  Link
real.finder
I did try to make this https://github.com/realfinder/AvsP-m...%20Subtitle.py
it work but sometimes it not accurate, I already try random fix but I think there are something missing, maybe peoples who has knowledge in vsfilter or libass can explain how to correctly convert subtitle time to frames
edit: I get an answer in irc.libera.chat/#libass, ceil(start timestamp in seconds * frames per second)
Old 8th July 2023, 19:56   #39  |  Link
real.finder
Matroska chapters from Trims.py update https://github.com/realfinder/AvsP-m...rom%20Trims.py
there are also some other updates in https://github.com/realfinder/AvsP-macros I didn't mention here
Old 9th July 2023, 02:58   #40  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
avsp.MsgBox(stdout, _('vfr.py rrror'))
Intentional ?
avisynth, avsp, ordered chapters, subtitles
