Old 8th December 2002, 16:46   #21  |  Link
hanfrunz
hanfrunz's Avatar
Thanks a lot MarcFD, you are my hero!
will you release the source code, so everybody can learn how itīs done?
hans runz
hanfrunz is offline   Reply With Quote
Old 8th December 2002, 17:06   #22  |  Link
Marc FD
XviD fan
Marc FD's Avatar
it's ugly, sbasic (~150 lines) and i don't have time to release it, but if someone really want it, i'm an opensource coder after all ^__^
Marc FD is offline   Reply With Quote
Old 8th December 2002, 22:43   #23  |  Link
WarpEnterprises
C64
WarpEnterprises's Avatar
Please, what's "sbasic" ?
WarpEnterprises is offline   Reply With Quote
Old 8th December 2002, 23:04   #24  |  Link
scmccarthy
Mark FD -
I am definitely interested in seeing the code. Did you write it in a programming language other that C++? I finally figured out how to write a YUV version of colorbars(). Dividee told me how to handle the audio, so now it works. I am using the invert filter as a pattern. I need to compare that with simple filters that work entirely differently.
Stephen
scmccarthy is offline   Reply With Quote
Old 9th December 2002, 13:06   #25  |  Link
Marc FD
XviD fan
Marc FD's Avatar
i wrote first : "simple", then i delete it simpl simp sim so s and i wrote basic => sbasic . it's a typo ^^
@stephen
i'll pack it a day with the sources if i write some new stuff.
Old 9th December 2002, 16:19   #26  |  Link
scmccarthy
No, no, sbasic is really a neat new programming language!
If you can really write a filter in basic instead of cpp I'd like to see how that is done.
Stephen
Old 9th December 2002, 16:48   #27  |  Link
Marc FD
XviD fan
Marc FD's Avatar
quoting myself :
i didn't mean basic as a langage. "basic instinct" is not a film about computers
Old 31st January 2003, 00:38   #28  |  Link
hanfrunz
hanfrunz's Avatar
Hello MarcFD,
the new 2.5 beta is out and your fantastic filter is not running anymore :
"Plugin raw422.dll is not an AviSynth 2.5 plugin"
would be cool, if you had time to fix it.
Thanks again,
hanfrunz
Old 31st January 2003, 23:45   #29  |  Link
WarpEnterprises
C64
MarcFD has abandoned development and this filter has no source code.
Stick to 2.0 for this application (you can safely use two versions)
Old 15th February 2004, 22:17   #30  |  Link
WarpEnterprises
C64
I made a new version for importing YUV-files (WITH source code):
http://www.avisynth.org/warpenterprises/
RawSource(filename, width, height, pixeltype)
e.g.
RawSource("d:\src6_ref__625.yuv",720,576,"UYVY")
Change the framerate with AssumeFPS(30) if it is not 25fps.
"pixeltype" isn't the internal AviSynth-format, but the format in the YUV-file. This will be mapped correctly, without any resampling.
Supported types:
RGB, RGBA, BGR, BGRA, YUYV, UYVY, YVYU, VYUY
Remember, this plugin reads video files which contain many frames.
It works for reading ONE frame, but not for file sequences (they must be loaded separately).
Old 16th February 2004, 09:26   #31  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
Actually I think Richards ImageReader/ImageWriter supports YUV images by now (in ebmp mode).
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 16th February 2004, 10:30   #32  |  Link
Wilbert
@WarpEnterprises,
1) what do you use to make such a yuv clip?
2) No NTSC support?
Old 16th February 2004, 14:59   #33  |  Link
ac-chan123
I have request a filter for using .yuv file in avisynth.
Sources of .yuv:
-VQEG
-xiph
-on the homepage of the most codec standardization group like mpeg and avc
AC-Chan(Robert Vincenz)
ac-chan123 is offline   Reply With Quote
Old 16th February 2004, 21:39   #34  |  Link
Wilbert
Sorry, I misread the docs. There is NTSC support.
I have one small request thought Could you add I420 and YV12 support?
The only free avi2yuv tool I could find:
http://www.ee.surrey.ac.uk/Personal/S.Worrall/dloads/
converts uncompressed RGB stuff (= tried XviD encoding, didn't work) to I420.
Old 16th February 2004, 23:04   #35  |  Link
WarpEnterprises
C64
I hate YV12 :-)
ac-chan123, your problems with the xiph videos come from that format.
It is a little more typing to add this and I have to download some frames first, but I will give it a try (which gives the answer to Wilbert, too).
Old 17th February 2004, 01:13   #36  |  Link
WarpEnterprises
C64
OK, get the new version with YV12 and I420 support.
@ac-chan: try
RawSource("d:\blue_sky.yuv",1920,1080,"YV12")
Old 17th February 2004, 03:33   #37  |  Link
ac-chan123
@WarpEnterprises: i try it and it work realy good. but if i (Source) playback "YV12" yuv file per avs in VDMod v1.5.10.1, there change the color. when i go one frame after an other, the color is ok.
Old 17th February 2004, 06:26   #38  |  Link
Richard Berg
developer wannabe
Richard Berg's Avatar
This is true. Right now it uses a small custom RIFF header to set the image parameters, but these could be specified as filter arguments (to the Reader) if there was demand.
Richard Berg is offline   Reply With Quote
Old 17th February 2004, 23:04   #39  |  Link
WarpEnterprises
C64
@Richard:
- Is that ebmp == the custom RIFFed filed?
- ImageWriter: would it be possible to APPEND all written images to ONE file (without header), with this it would be possible to generate those YUV files, maybe useful for testing purposes.
It is clear that we (ImageReader/RawSource) have some overlapping functionality but I don't see how to combine it nicely.
Old 21st February 2004, 01:30   #40  |  Link
Wilbert
I added YV12 support for you! Not bad for someone who can't program
I failed to add I420 (which is what I really want). I tried to add the code of SwapUV, but I couldn't get that to work. But there might be a simplier way.
Could you have a look at I420 support?
I420 clip (640x480, 25 fps):
http://www.geocities.com/wilbertdijkhof/raw.yuv
source+dll:
http://www.geocities.com/wilbertdijkhof/RawSource.zip
Note that if you open the clip as YV12, you will see that the output is correct except that the U and V channels are swapped. Thus YV12 input is correct since YV12 = I420 with swapped U and V.
