Old 30th May 2018, 18:11   #1  |  Link
Forensic
DOS command in Avisynth
I need to execute a ffmpeg command (it has a lot of parameters) from within my Avisynth script. Is this possible?
If not, then one alternative is for my script to call a BAT file by passing a variable. My failed syntax attempt was:
  LoadPlugin("CALL_25.dll")
  Call("test.bat", "MyVariable")
I am open to any suggestions. Thank you.
Forensic is offline   Reply With Quote
Old 30th May 2018, 18:56   #2  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I don't know whether such a plugin exists, but writing it would be very simple. You'd simply call the program on CreateFilter and wait for it to exit; with no need to initialize any plugin.
Edit: same question was asked here
MysteryX is offline   Reply With Quote
Old 30th May 2018, 21:03   #3  |  Link
ChaosKing
I think this is what you want https://forum.doom9.org/showthread.p...32#post1593132
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
ChaosKing is online now   Reply With Quote
Old 31st May 2018, 00:49   #4  |  Link
Forensic
Thank you both. That is exactly what I needed.
Old 31st May 2018, 09:44   #5  |  Link
There is also RT_call(), but CallCmd() is more flexible.
Best avoid [EDIT: original] Call() plug, as it does have some problems.
avisynth, call, dos
