Old 20th January 2019, 13:59   #221  |  Link
gugglu
Originally Posted by real.finder View Post
if anyone interested, I made an update to mpp (MP_Pipeline) using last code from official github https://github.com/SAPikachu/MP_Pipeline
there are two changes aside from support old avs mt, one is "Add support for specifying cores", and the 2nd one is "Fix crash on systems with many CPUs"
you can get it from here https://github.com/realfinder/MP_Pipeline/releases
Can you please write one example how to use core future?
this is my script i've tried with ### cores:4 at the end of script, can you clear this to me am i ordering it correct or not , thanks.
o = last
mb1 = o.minblur(1)
mb2 = o.mt_adddiff(mt_makediff(mb1,mb1.removegrain(4)))
ss = seesaw(o, mb2, ssx=1.30, ssy=1.30)
rep = ss.repair(o,1,1,1,false)
mt_lutxy (o, rep, expr="x y < y 1 - x y > y 1 + y ? ?", y=3, u=3, v=3)
Can you please check my 8-bit process and i think it needs some correction. if possible pls look below mt_adddiff(mt_makediff(mb1,mb1.removegrain(4))) i tried seesaw / repair / mt_lutxy i think they need swapping up or down with each other i tried replacing them what not sure where thats how they should be placed or need correction. i would be greatly thankful to you if you clear this illusion in script.i have 14Core/28thread cpu i need an script example for
thanks a ton ,your efforts are very much appreciated.
gugglu is offline   Reply With Quote
Old 20th January 2019, 22:56   #222  |  Link
real.finder
it's just the old
### lock threads to cores
but now you can set the thread/core like this
mp_pipeline("""
### platform
1st block here
### lock threads to cores 1
### platform
2nd block here
### lock threads to cores 2
and so, and ofc you can use another threads/cores as you like
Regarding 8-bit process Question, it's off topic but anyway seesaw need denoised clip in 2nd clip input, o.mt_adddiff(mt_makediff(mb1,mb1.removegrain(4))) give sharp noisily output
aside from that why you still use lsb not the native clean and fast HBD in avs+?
My Avisynth Stuff
Old 6th February 2019, 11:44   #223  |  Link
gugglu
it's just the old
mp_pipeline("""
### platform
1st block here
### platform
2nd block here
Hello, and sorry for late reply (it is my working hour very long).thanks for the example.i have done two test on my laptop both works.
mp_pipeline("""
### platform:win32
### dll:avisynth.dll
Setmemorymax(1536)
DGDecode_mpeg2source("C:\Users\Kalik\Videos\VTS.d2v", cpu=4, info=3)
ColorMatrix(hints=true, threads=0)
crop(2, 66, 0, -66)
### prefetch:128,32
### lock threads to cores: 2
### platform:win64
setmemorymax(2048)
SMDegrain(Tr=3)
### prefetch:64,16
or
mp_pipeline("""
### platform:win32
Setmemorymax(1536)
crop(2, 66, 0, -66)
### prefetch:128,32
### platform:win64
setmemorymax(2048)
SMDegrain(Tr=3)
### prefetch:64,16
AVS+ Native HBD perform better gives nicer output, but i don't know any Debanding filter which works with Avs+ Native HBD so i can stick that just after smdegrain this is why i use lsb thing some time(but i tried Avs+ Native HBD and to be honest i like the result more than the lsb ting).
Please can you correct this if u have some free time , i've core-i9 7940x 14cores/28threads only thing where i get confused ### lock threads to cores , do i have to type cores number or threads number? thanks for your precious work i really like mp_pipeline and i use it every time i encode any clip.
mp_pipeline("""
### platform:win32
Setmemorymax(1536)
crop(2, 66, 0, -66)
### prefetch:128,32
### lock threads to cores 14
### platform:win64
setmemorymax(2048)
SMDegrain(Tr=3)
### prefetch:64,16
Old 7th February 2019, 05:30   #224  |  Link
real.finder
from the old read me of mpp
Slave processes with this statement will lock their worker threads into a core. This may improve performance for some scripts.
Core selection is on a round-robin manner, with awareness of hyper-threading.
the new change is
Affinity: Add support for specifying cores
so every block should has different number (or using some threads/cores that has no heavy load, mean you can balance that in which way make the script run faster), and those numbers should be up to cores counts (or maybe threads, you should ask a Developer ) in the cpu
the old mpp as the read me said, does it automatically I think, maybe even in the new one still does that if not specified by user
and Regarding
vs
I think the 1st one is the correct as I understand from the Source code, the 2nd one may act like old method (ignore the number) or maybe work as it should, see what you got in the task manager in windows
My Avisynth Stuff
Old 7th February 2019, 06:13   #225  |  Link
real.finder
you can use flash3kyuu_deband, it's can use interleaved format which is like Native in speed, https://f3kdb.readthedocs.io/en/late...arg-input-mode with using ConvertToDoubleWidth() in avs+
My Avisynth Stuff
Old 18th February 2019, 19:22   #226  |  Link
real.finder
SMDegrain update
new divide parameter (Dogway) and some edits for avs+ and avs neo cases and some others changes
there are many of my scripts already use some method for avs+ detection since years, but unfortunately it not work with avs neo so updates will come soon for those, and from now on you will need SMDegrain.avsi more than ever since it have the IsAvsNeo(), IsAvsPlus() and AvsPlusVersionNumber() functions. why?
My Avisynth Stuff
Old 21st February 2019, 16:38   #227  |  Link
real.finder
almost all filters updated, and SMDegrain.avsi is needed now for many scripts since it have the IsAvsNeo(), IsAvsPlus() and AvsPlusVersionNumber() functions
My Avisynth Stuff
Old 21st February 2019, 16:49   #228  |  Link
Thankyou RF for you continued work, I'm gonna have to steal some of your code, so thanx in advance.
Old 21st February 2019, 16:55   #229  |  Link
ChaosKing
Thx for the update(s).
Old 6th March 2019, 17:59   #230  |  Link
Vitality
also AKA A.SONY's Avisynth Stuff
note:- SMDegrain.avsi (v3.1.2.101s or up) is needed now for many scripts since it have the IsAvsNeo(), IsAvsPlus() and AvsPlusVersionNumber() functions. why?
DeHalo_alpha_MT2
I have SMDegrain v3.1.2.101s but I still get the AvsPlusVersionNumber() missing error with DeHalo_alpha_MT2.
Vitality is offline   Reply With Quote
Old 19th April 2019, 18:14   #231  |  Link
real.finder
I did update dfttestMC (now "dfttestMC and MC things")
there are new mcKNLMeansCL(), you can also try with sMCwarper(prefilter=1,"SMDegrain_KNLMeansCL(d=2)")
edit: there was some bug, re-download it
My Avisynth Stuff
Old 19th April 2019, 19:28   #232  |  Link
tormento
Acid fr0g
tormento's Avatar
Well, we need a OpenCL DFTtest
@turment on Telegram
Old 6th May 2019, 11:03   #233  |  Link
Natty
Noob
i recently upgraded to ryzen + radeon. i am getting weird frames while using knlmeans prefilter in smdegrain like this
https://i.imgur.com/YL2rHpH.jpg
it didnt happen in intel + nvidia... is there any solution ?
Natty is offline   Reply With Quote
Old 6th May 2019, 11:42   #234  |  Link
real.finder
other prefilter's work fine? if not then it's mvtools problem, if they work fine then it's knlmeans
My Avisynth Stuff
Old 6th May 2019, 13:05   #235  |  Link
Natty
Noob
yes prefilter 2 and 3 work fine.. even prefilter 4 works good in normal noised sources.. craps out on too noisy sources.
Old 30th May 2019, 15:58   #236  |  Link
tormento
Acid fr0g
tormento's Avatar
new SMDegrain edit
I hope some day you will release changelog with new versions
Old 30th May 2019, 17:04   #237  |  Link
real.finder
too late for that, anyway I did in the top of script for most new things, other updates mostly for bug fix, the last update for this
My Avisynth Stuff
Old 16th June 2019, 12:42   #238  |  Link
Zetti
I can't choose Prefilter4 in AvsPmod
Can it be a bug??
Edit I forgot to mention i use SMDegrain v3.1.2.102s
Zetti is offline   Reply With Quote
Old 19th June 2019, 14:51   #239  |  Link
real.finder
Can it be a bug??
this in avspmod? you should report it in avsp Thread
My Avisynth Stuff
Old 19th June 2019, 15:29   #240  |  Link
ChaosKing
Can it be a bug??
The profile/config for smdegrain needs to be updated in avsp mod. This is a manual task and can't be detected automatically as far as I know.
avisynth, avs script, avs+, banding, generator, hbd, mod
