Old 5th August 2016, 07:15   #41  |  Link
feisty2
I'm Siri
feisty2's Avatar
Originally Posted by GMJCZP View Post
Hi pinterf, and Windows XP problem?
Anyway thank you for your effort.
just drop xp already, turn to Linux if you dislike windows10 or windows7
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is offline   Reply With Quote
Old 5th August 2016, 20:17   #42  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Reel.Deel View Post
Very nice. Thank you pinterf!
Yes, both QTGMC and SMDegrain are quite bloated due to the planar YUY2 hack. A while back I started modding QTGMC to remove the hack, I never finished but MVTools supporting YV16 makes it a lot easier.
Please make the SMDegrain mod available when finished
@turment on Telegram
Old 5th August 2016, 21:34   #43  |  Link
Motenai Yoda
Motenai Yoda's Avatar
It's an hard work to add y8 and 16bit support too?
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 6th August 2016, 04:01   #44  |  Link
feisty2
I'm Siri
feisty2's Avatar
Kind of, some components like SATD were coded in asm and incompatible with high bitdepth, gotta rewrite them completely
And 16bits support is sort of practical still
Floating point support is much harder, not sure if it's possible to implement floating point support and integer support both within a single plugin
vectors are like, int vx, int vy, int sad for both uint8_t and uint16_t
And SAD(sum of absolute differences) for floating point inputs are also floating points obviously, gotta do some reinterpret_cast tricks here
Old 6th August 2016, 07:46   #45  |  Link
pinterf
y8 is possibly easy, possibly working with three planes is hardcoded now.
16 bit/float support is hard (=takes time), but even this modding to YV24 took days and was a nightmare.
I have already put high bit depth supporting code here and there and my last internal version has a working MSuper in 16 bits as a first step.
And I think I will not cut the possibility of the float version, just for my curiosity (inspired by feisty2)
pinterf is offline   Reply With Quote
Old 6th August 2016, 07:57   #46  |  Link
pinterf
Since 2.7.0.22c I have found 3-4 other use of harcoded div 2 for horizontal subsampling (affects only YV24), but will make a fix only if I have time.
Till then you are still encouraged to test it, of course.
Old 6th August 2016, 08:04   #47  |  Link
feisty2
I'm Siri
feisty2's Avatar
you're gonna get into the floating point SAD trouble if you do plan to mess with fp support,
I did a nasty reinterpret_cast trick to stuff fp SAD in vectors
static inline auto _fakeint(float a) {
	return reinterpret_cast<int32_t &>(a);
static inline auto _back2flt(int32_t a) {
	return reinterpret_cast<float &>(a);
maybe there's a better way to do this, but...
Old 6th August 2016, 11:26   #48  |  Link
Motenai Yoda
IIRC both x264 and x265 should yet sports high bitdepth SATD in asm.
Old 6th August 2016, 11:50   #49  |  Link
amayra
Quality Checker
amayra's Avatar
can you do something about SVPflow i try to updated but i failed
I love Doom9
amayra is offline   Reply With Quote
Old 6th August 2016, 13:33   #50  |  Link
Reel.Deel
I never said that I was modding SMDegrain. Ask Dogway if he's interested, I'm sure he can do more efficiently since it's his script. A while back I gave him a few suggestions (post 87-89) but nothing came of it.
Please do not cross-post. SVPflow has nothing to do with this thread.
Old 6th August 2016, 20:47   #51  |  Link
tormento
Acid fr0g
tormento's Avatar
Oh... I am so sorry.
I confused you with real.finder.
Old 6th August 2016, 22:49   #52  |  Link
GMJCZP
GMJCZP's Avatar
The version 2.7.0.22c not working in XP 32 bits. Access violation.
By law and justice!
Flea Market
GMJCZP is offline   Reply With Quote
Old 7th August 2016, 06:21   #53  |  Link
pinterf
Sad. I was compiling them with xp in mind.
One week holday begins, I'll disappear.
Old 15th August 2016, 01:28   #54  |  Link
real.finder
Originally Posted by pinterf View Post
P.S.
Could not try it with SMDegrain.avsi, because the script internally assumes YV12 for planar YUV format.
it didn't
planar  = IsYUY2(input)       ? true : false
planar in SMDegrain mean YUY2, I was surprised too
so it should work like qtgmc in yv16 and yv24, especially with http://pastebin.com/JtWFN124
My Avisynth Stuff
Old 15th August 2016, 12:51   #55  |  Link
pinterf
Originally Posted by real.finder View Post
it didn't
This modified smdegrain.avsi works!
The old version gave "image heights don't match" when using lsb=true because it assumed the dimensions of YV12 subsampling.
Old 16th August 2016, 20:44   #56  |  Link
pinterf
After-before holiday release for early adopters
  • general: supporting Y8, YV16, YV24 format besides YV12 and YUY2
  • Some additional fixes for YV24
  • Allow greyscale input (Y8) - I hope
  • dct modes >= 5 now use SATD again (so far it was in dead code, contrary to 2.5.13.1 remarks)
  • fftw 3.3.5 support (changed function names, 3.3.4 still OK), see http://www.fftw.org/download.html
  • XP support again
  • compiled to SSE2 with optional SSE4.2 paths
Download: 2.7.0.22d for 32 and 64 bit (20160816)
Old 16th August 2016, 21:08   #57  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
[*]fftw 3.3.5 support
Oh cool, didn't even notice an update for FFTW.
Looking at the Release Notes, it's not critical to little old me.
Win10 (x64) build 17134 | GPU Caps Viewer 1.40.1.0
NVIDIA GeForce GT 1030 (GP108) 2047MB/GDDR5 | (R417.22)
NTSC | DVD: R1 | BD: A
Old 16th August 2016, 21:25   #58  |  Link
pinterf
There are other nice topics on doom9
Old 16th August 2016, 23:42   #59  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
I'm too far behind to pick up on VS scripting to make regular use of VS.
But, it's good to know that the update is making rounds.
For future reference, I'll make note of it.
Old 17th August 2016, 07:53   #60  |  Link
yup
pinterf!
I see some slowdown for dct=5, approx. 10%.
FFTW updated.
yup.
yup is offline   Reply With Quote
