Old 21st March 2017, 09:49   #5041  |  Link
need4speed
Originally Posted by LigH View Post
No, since v2.3+22 it's default.
Ok great cause St least for my personal setup this has been a good step forward.
Inviato dal mio GT-N7100 utilizzando Tapatalk
need4speed is offline   Reply With Quote
Old 21st March 2017, 17:20   #5042  |  Link
Boulder
Pig on the wing
Boulder's Avatar
The latest commit seems to put --limit-tu 4 in the presets slower and veryslow. Previously it was mentioned that --limit-tu 3 would provide good subjective quality while increasing performance, so has there been some more testing regarding the option?
Old 21st March 2017, 18:10   #5043  |  Link
x265_Project
Posts: n/a
Yes. Tests showed a ~20% performance increase with almost no detectable impact to quality.
Old 21st March 2017, 18:34   #5044  |  Link
benwaggoner
Originally Posted by Shevach View Post
Thanks for a prompt reply. Frankly speaking i meant both min/max_display_mastering_luminance (signaled in MasteringDisplayColorVolume SEI) and MaxCLL/MaxFall (signaled in Content Light Level SEI).
What's about MaxCll? After encoding this value might be different from that obtained from source yuv or tiff.
In my opinion, lossy encoding may cause non-negligible changes in min/max_display_mastering_luminance and MaxFall/MaxCll.
Why? If a quantization rounding offset is less 0.5 in an encoder then reconstructed pixels tend to be smaller (leakage of energy). If the quantization rounding offset is above 0.5 then an opposite effect takes place. The quantization rounding offset is like a pump which either inhale or exhale "energy".
Consequently, after encoding MaxFall/MaxCll may differ from those in the original file.
You are entirely correct that encoding can reduce the MaxFALL and particularly MaxCLL from the source. However, industry standard behavior is to retain the values from the source as indicative of creative intent. Also, with adaptive bitrate switching, different streams could have different encoded metadata values. But Displays don't like mid-stream metadata value changes, so the same values should be used for all bitrates.
THAT said, devices don't make heavy use of MaxFALL and MaxCLL in practice, because knowing what the brightest frame and brightest pixel across an entire movie isn't that useful. Dynamic metadata ala Dolby Vision and SMPTE 2094-40 are much more useful for tone mapping.
Ben Waggoner
My Compression Book
Old 22nd March 2017, 00:07   #5045  |  Link
CruNcher
CruNcher's Avatar
MaxFALL and MaxCLL play no role in Hardware protection or could they be used to save energy more efficient per frame improving overheating statistics and overall Hardware output efficiency ?
Though not sure for what that would help you need those data in realtime and some heat buffer that corrects the latency before you need to emergency shutdown, HDR is pretty interesting in those regards how smart (adaptive) the Display Hardware must react to not get damaged or MTBF rising heavily whiich in the end also defines the end result of what you gonna percept overall
HDR + VFR overall seem also to have the potential to be very efficiently combined especially 1 compensating the others higher power output needs
Especially Nvidia and AMD currently seem to be very interested in pushing this forward in their Labs currently
HDR generates some interesting drawbacks in terms of energy output savings that have been done over the years in power consumption it lowers the output efficiency again or compensates some of the advantages done in the Mobile Power Saving space pretty rapidly.
Power Supplier are surely pretty happy about this development
It is about Time
Old 22nd March 2017, 13:51   #5046  |  Link
jairovital
I'm having problem with non English filename using StxRip on Windows 7 64, Codepage 1252/850.
Running avs2pipemod64.exe (version 1.1.1 - Aug 2016) it gives:
avs2pipemod[error]: Import: couldn't open "B:\Programas\StaxRipTemp\S? corro_temp\S? corro.x265 - MKV - Super Low 26 - AAC - 22050 Hz.avs"
Talking with its author, Stax76, he said that since it works with x264, probably x265 could be the cause of problem, once we need to implement an avifile/avisynth/vapoursynth reader. "All of Rigaya's hardware encoders have direct support for avs and vpy, x264, so it supports at least avs".
I suspected avs2pipemod was the cause of problem, but it seems not.
Greetings from me and Stax76.
jairovital is offline   Reply With Quote
Old 22nd March 2017, 15:28   #5047  |  Link
Barough
Barough's Avatar
x265 v2.3+24-a0eee4b41185 (MSYS/MinGW, GCC 6.3.0, 32 & 64bit 8/10/12bit multilib EXEs)
x265 [info]: HEVC encoder version 2.3+24-a0eee4b41185
x265 [info]: build info [Windows][GCC 6.3.0][32 bit/64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2
https://bitbucket.org/multicoreware/x265/commits/branch/default
Old 23rd March 2017, 20:40   #5048  |  Link
brumsky
msvc comiled binaries
Could someone please post the latest build while using VS 2017?
Thanks!
brumsky is offline   Reply With Quote
Old 23rd March 2017, 20:49   #5049  |  Link
Leo 69
Originally Posted by brumsky View Post
Could someone please post the latest build while using MSVC 2017?
Thanks!
http://www.mediafire.com/file/1g95yo..._vs2017-AVX.7z
http://www.mediafire.com/file/4nsvdb...vs2017-AVX2.7z
Leo 69 is offline   Reply With Quote
Old 23rd March 2017, 20:50   #5050  |  Link
Ma
Thanks!
If you don't see latest build on page www.msystem.waw.pl/x265 please refresh the page (F5 should help).
Ma is offline   Reply With Quote
Old 23rd March 2017, 21:01   #5051  |  Link
brumsky
Originally Posted by Leo 69 View Post
Awesome thank you both!!
Old 23rd March 2017, 22:28   #5052  |  Link
pingfr
I can only agree and applaud with both hands.
At the moment it is... "un-wise" to use a GCC built x265 binary.
VS2017 is (at least for now) the way to go.
pingfr is offline   Reply With Quote
Old 23rd March 2017, 22:49   #5053  |  Link
Barough
Barough's Avatar
Why is that pingfr?
GCC compiles mite be slow for 10bit encodes but thats not the case for 8bit.
Personally so am i not interested in 10bit due 2 that its not especially compatible with hardware.
Sent from my Samsung Galaxy S7 edge via Tapatalk
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 23rd March 2017, 23:09   #5054  |  Link
LigH
LigH's Avatar
Originally Posted by pingfr View Post
The differences are subtle as the preset "increases"...
Only if you prefer to look at absolute differences, instead of relative ratios. And to be frank, I see no reason to prefer absolute differences over relative ratios.
With the exception of the extremes, the relative ratios of the encoding speeds of most presets were almost constant (and the differences among these ratios most probably in a range of random influences, like interrupting kernel tasks).
At least, there is a certain advantage of the MSVC builds. Rather small yet reliable.
New German Gleitz board
Old 23rd March 2017, 23:58   #5055  |  Link
benwaggoner
I full agree about using percentage ratios.
Has anyone tried doing profile-driven optimizations for x265? I don't know if it would help much given all the assembler, but 5% on veryslow with a different compiler suggests there may be some juice to squeeze out there still.
Ben Waggoner
My Compression Book
Old 24th March 2017, 00:03   #5056  |  Link
LigH
LigH's Avatar
An analytic with a lot of spare time would probably check: Which features are only enabled in slower presets, and are they still in C code? Most probably, as I would assume they are not primitive operations, thus rather hard to implement in lower level languages.
Old 24th March 2017, 00:42   #5057  |  Link
pingfr
Thanks for making that table re-cycling the data I pasted a few days ago, glad it served a purpose.
Although it is missing the placebo preset.
I just can't be bothered waiting 45 minutes to run each placebo encodes.
Also note it is important to remind you these tests were ran using 2.3+23, it is worth mentioning the latest commit applies limit-tu to slower, veryslow presets for an up to 20% increase in FPS according to the commit, this most likely has skewed the presented data here, it has to be seen whether the delta remains and even there we're talking about 0.15 of 1 fps.
Old 24th March 2017, 01:26   #5058  |  Link
LigH
LigH's Avatar
Don't be sad; I do not even have any AVX2 capable processor available.
Old 24th March 2017, 10:15   #5059  |  Link
aymanalz
What exactly is that ratio percent in the last row? In the first comparison, one encode is faster than the other by 0.83%, which you have called as a 100.83% ratio.
So in all the comparisons, to know by how much one is faster than the other, you have to ignore the "100", and whatever remains is the percentage difference in speed.
Isn't that the relevant metric? By what percent one is faster than the other?
aymanalz is offline   Reply With Quote
Old 24th March 2017, 10:17   #5060  |  Link
aymanalz
You could run the placebo encodes on a very short clip, maybe trimmed from your original clip.
