Old 11th February 2013, 05:37   #1  |  Link
KeyserSoze17
KeyserSoze17's Avatar
MeediOS - madVR Video Player
For those familiar with MeediOS, it has long suffered for a good video player. Often requiring users to launch an external player. Now there is a native video player based on directshow codecs using madVR, LAV, ffdshow (optional), xy-VSFilter, XySubFilter, and Reclock (optional). If you're looking for an alternative to XBMC, JRiver, etc, you might give this a try. More features to come. To be clear, this is an internal player and requires MeediOS to be installed.
Any feedback is welcome.
Ofcourse, the strength of the player is the hard work of the developers of madVR, LAV, ffdshow, xy-VSFilter, XySubFilter, and Reclock.
madVR: http://forum.doom9.org/showthread.php?t=146228
madVR - created and maintained by Mathias Rauen,
LAV: http://forum.doom9.org/showthread.php?t=156191
LAV - created and maintained by nevcairiel
Features:
Will play any media that LAV and madVR can handle.
Reclock is supported
ffdshow raw filter supported
DVD playback with menus supported
BluRay playback supported - no menus
BluRay playlist selection with main title selection
Chapter selection
Jump to a specific time
Audio track selection
Subtitle track selection
Zoom in, Zoom out
Normal transport functions (play, pause, rrw, few)
Menus and transport bars are semi transparent so video shows through.
Movie information with poster and audio video data displayed
Graphics are shown through the madVR api in both full screen exclusive mode and windowed mode
To do:
Add mouse support
Additional Information can be found here:
http://www.meedios.com/EN/forum/view...hp?f=61&t=7704
KeyserSoze17 is offline   Reply With Quote
Old 13th February 2013, 20:24   #2  |  Link
tschi
Hi, very nice ! I will give it a try.
Is it possible to add other filter like ffdshow raw filter in chain ?
tschi is offline   Reply With Quote
Old 13th February 2013, 22:37   #3  |  Link
KeyserSoze17
Sure it's possible. It is not currently setup to intentionally add other filters but it won't prevent other filters from loading if the graph needs it. I can look into adding this as an option.
Old 14th February 2013, 03:03   #4  |  Link
Milardo
Hi, can you list all the features of the player? Can the player be installed without meedios?
Milardo is offline   Reply With Quote
Old 14th February 2013, 08:08   #5  |  Link
KeyserSoze17
The player is a MeediOS plugin and cannot be run without MeediOS.
Features:
Should play any media that LAV and madVR can handle.
Chapter selection
Zoom in, Zoom out
I think thats most of it...
Old 18th February 2013, 05:51   #6  |  Link
KeyserSoze17
New version - Added option to automatically install and update madVR and lav
Old 21st February 2013, 04:06   #7  |  Link
Dodgexander
So does this support the same customization offered by lav and madvr like installed separately?
Dodgexander is offline   Reply With Quote
Old 21st February 2013, 04:57   #8  |  Link
KeyserSoze17
Yes - It uses LAV and madVR. So whatever your settings are for these filters that is what is used. The player can install and update all filters, but you are responsible for setting them as you like.
Old 22nd February 2013, 02:40   #9  |  Link
KeyserSoze17
New version - added settings menu for filter options
Old 22nd February 2013, 20:53   #10  |  Link
madshi
The GUI looks nice to me. One tiny little request: Could you fix the case? It's "madVR" instead of "Madvr". Thanks...
Old 22nd February 2013, 23:46   #11  |  Link
KeyserSoze17
Oops. Corrected now. I'll also make sure it's correct on the MeediOS website and within the player.
Old 23rd February 2013, 00:33   #12  |  Link
hubblec4
Matroska find' ich toll
KeyserSoze17 LAV Splitter(Filter) isnt able to split mkv-ordered-chapter-mkvs.
you should use AV Splitter instead.
hubblec4 is offline   Reply With Quote
Old 23rd February 2013, 02:18   #13  |  Link
KeyserSoze17
Thanks for the heads up. While the player always adds LAV audio and video decoders it does not force the LAV splitter into the graph. I would think the splitter would load based on your filter priority settings. Regardless, I will add an option to the player to use either splitter.
Old 27th February 2013, 09:47   #14  |  Link
Dodgexander
The thing that puts me off meedios the most is the lack of mouse support
Old 27th February 2013, 16:14   #15  |  Link
KeyserSoze17
MeediOS certainly supports the use of a mouse. I just haven't coded it into the player with the madVR API. It's on the to do list.
Old 6th March 2013, 02:28   #16  |  Link
Dodgexander
When mouse support is added I'd like to give Meedios a go, but no integrated tuner will put me off. Despite trying all the solutions out there I just can't seem to beat WMC and Media Browser for reliable functionality and for me, even that lacks free customisable music playback.
Old 25th April 2013, 04:47   #17  |  Link
KeyserSoze17
New version released
- Some bug fixes
- Now uses Chapterdb.org to get chapter names.
Thanks to the ChapterDb for allowing API support.
Old 3rd October 2013, 06:38   #18  |  Link
KeyserSoze17
New version available
- now incorporates XySubFilter
Old 4th October 2013, 21:06   #19  |  Link
rvs75
Where i can find the source ?
I find in nothing in your SVN.
Don't be afraid, i am also a gpl coder
(http://zguidetv.codeplex.com/, http://zviewtv.codeplex.com/, http://www.zguidetv.net/viewtopic.php?f=35&t=1049)
rvs75 is offline   Reply With Quote
Old 4th October 2013, 22:54   #20  |  Link
KeyserSoze17
I temporarily pulled the code down to clean it up, fix some bugs, add some features and better integrate it into MeediOS WPF gui. Feel free to pm me if you have any general questions on the code and I'll be happy to help.
lav, madvr, meedios, reclock, svp
