Old 4th May 2018, 18:06   #261  |  Link
Stereodude
Anyone have a working download link for .18?
Stereodude is offline   Reply With Quote
Old 4th May 2018, 19:28   #262  |  Link
poisondeathray
MP_Pipeline-0.18 mirror
http://www.mediafire.com/file/vsmamx...eline-0.18.rar
Old 4th May 2018, 20:24   #263  |  Link
Stereodude
Originally Posted by poisondeathray View Post
Thanks!
Old 30th December 2018, 12:14   #264  |  Link
Dogway
I'm trying to load 32-bit plugins in avs+ x64 latest build 2772 without success, I put the content of MP_Pipeline 0.18 64 folder into plugins+64 and try to preview the next script with AvsPmod.v2.5.1_x64 (also tried vdub2).
Did more tests with other code explicitly loading x86 avisynth dll.
MP_Pipeline("""
### platform: win32
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins+\JpegSource.dll")
jpegSource("D:\Profiles\Usuarios\Administrador\Desktop\147.jpg",length=1)
But I get an error as if I still was using 64-bit avisynth.
MP_Pipeline: Unable to create slave process. Message: Script error: Cannot load a 64 bit DLL in 32 bit Avisynth: 'C:/Program Files (x86)/AviSynth+/plugins64+/firstfoundplugin_x64.dll'.
Old 31st December 2018, 19:34   #265  |  Link
Dogway
I have doing more tests and I'm still unable to mix 32 and 64 bit plugins.
Here's my clean scenario.
Installed avs+ r2772 both x86 and x64, x86 through Avisynth Repository
Current registry paths:
[HKEY_LOCAL_MACHINE\SOFTWARE\Avisynth]
@="D:\\Rip\\workshop\\Front_Ends\\AvisynthRepository\\AVSPLUS_x64"
"PluginDir2_5"="D:\\Rip\\workshop\\Front_Ends\\AvisynthRepository\\AVSPLUS_x64\\plugins"
"PluginDir+"="C:\\Program Files (x86)\\AviSynth+\\plugins64+"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Avisynth]
@="D:\\Rip\\workshop\\Front_Ends\\AvisynthRepository\\AVSPLUS_x86"
"PluginDir2_5"="D:\\Rip\\workshop\\Front_Ends\\AvisynthRepository\\AVSPLUS_x86\\plugins"
"PluginDir+"="C:\\Program Files (x86)\\AviSynth+\\plugins+"
MP_Pipeline x64 is 318Kb v0.18 version:
plugins+ folder:
	ConvertStacked.dll
	DirectShowSource.dll
	ImageSeq.dll
	MtModes.avsi
	Shibatch.dll
	TimeStretch.dll
	VDubFilter.dll
plugins64+ folder:
	ConvertStacked.dll
	ImageSeq.dll
	MP_Pipeline.dll
	MP_Pipeline.dll.slave.exe
	MP_Pipeline.dll.win32
	MP_Pipeline.dll.win32.slave.exe
	MP_Pipeline_readme.avs
	MtModes.avsi
	Shibatch.dll
	SmoothAdjust.dll
	TimeStretch.dll
	VDubFilter.dll
This is my script loaded in AvsPmod 2.5.1 x64 from this link.
Plugin Autoload Folder in AvsPmod is set to: C:\Program Files (x86)\AviSynth+\plugins64+
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64+\MP_Pipeline.dll")
MP_Pipeline("""
### platform: win32
imageSource("D:\Profiles\Usuarios\Administrador\Desktop\147.jpg")
and error:
MP_Pipeline: Unable to create slave process. Message: Script error: Cannot load a 64 bit DLL in 32 bit Avisynth: 'C:/Program Files (x86)/AviSynth+/plugins64+/ConvertStacked.dll'.
Trying to explicitly load x86 avisynth:
MP_Pipeline("""
### platform: win32
### dll: "C:\Windows\SysWOW64\AviSynth.dll"
MP_Pipeline: Unable to create slave process. Message: Unable to load "C:\Windows\SysWOW64\AviSynth.dll", code = 126
Old 7th January 2019, 17:38   #266  |  Link
Stereodude
The combo works find for me (r2772 and MP 0.18). What program are you trying to load the script with? It looks like you're trying to load your script with a x86 (32-bit) program. This causes AVIsynth+ to try to load your 64-bit script in the x86 version and it fails.
Have you tried loading the script with the 64-bit version of VD2 or AVSmeter?
Old 7th January 2019, 17:51   #267  |  Link
Dogway
My setup is posted above. r2772 yes, MP 0.18 yes 64bit AvsPmod, VD2, avsmeter64... and so on.
I had to fix the registries because AvisynthRepository was messing with them bad time but still no luck.
Now they are:
[HKEY_LOCAL_MACHINE\SOFTWARE\AviSynth]
@="C:\\Program Files (x86)\\AviSynth+\\plugins64+"
"plugindir2_5"="C:\\Program Files (x86)\\AviSynth+\\plugins64"
"plugindir+"="C:\\Program Files (x86)\\AviSynth+\\plugins64+"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\AviSynth]
@="C:\\Program Files (x86)\\AviSynth+\\plugins+"
"plugindir2_5"="C:\\Program Files (x86)\\AviSynth+\\plugins"
"plugindir+"="C:\\Program Files (x86)\\AviSynth+\\plugins+"
In my opinion MP_Pipeline is failing to load avisynth x86 for some reason.
It can't even load an avisynth.dll
### dll: C:\Windows\SysWOW64\AviSynth.dll
MP_Pipeline: Unable to create slave process. Message: Unable to load "C:\Windows\SysWOW64\AviSynth.dll", code = 193
By the way I'm on Win7 SP1 x64 if that makes a difference.
Old 8th January 2019, 17:44   #268  |  Link
Yanak
Hello,
Not sure if it will help anything but I have both x86 and x64 version of avisynth, also on Win7 SP1 x64 , installed via the AviSynthPlus-MT-r2772.exe installer provided by pinterf here
One thing that ticks me in your script is " LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64+\MP_Pipeline.dll") "
Why program files x86 ?, the x64 version should be in "Program Files", the x86 version of avisynth is the one that should be in Program Files (x86),
according to your reg entries the "plugins+" & " plugins64+ " are located at the same place for both x86 and x64 version, both in Program Files (x86), seems strange, unless i'm not seeing clear tonight it looks like both your avisynth installs are locate at the same place in program files x86
I checked and i do not have any "plugins64+" folder in the x86 version at "C:\Program Files (x86)\AviSynth+", only a "plugin+" folder is present there.
My reg entries :
@="C:\\Program Files\\AviSynth+"
"plugindir2_5"="C:\\Program Files\\AviSynth+\\plugins64"
"plugindir+"="C:\\Program Files\\AviSynth+\\plugins64+"
"plugindir2_5"="C:\\Program Files\\AviSynth+\\plugins"
MP-pipeline files :
MP_Pipeline.dll
All located inside the x64 version of avisynth, here : "C:\Program Files\AviSynth+\plugins64+"
My x64 version of avisynth is installed at C:\Program Files\AviSynth+\
My x86 version of avisynth is nstalled at C:\Program Files (x86)\AviSynth+\
also with avisynth+ you don't need to call the Mp_pipeline dll at the start of the script , it is auto loaded so this line should not even be needed in the script.
Tested also within the 2.5.1 x64 version of AvsPmod that is, unless i make an error, the same as yours, there again no need to use the " LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64+\MP_Pipeline.dll") ", only this to load a pic .
MP_Pipeline("""
### platform: win32
imageSource("F:\My Pic.png")
Like i said not sure it it will help with anything, maybe you can compare and find something that is odd.
Good luck, took me a while before getting MP_pipeline to work, hopefully the forum good souls helped me at this time
Yanak is offline   Reply With Quote
Old 8th January 2019, 18:10   #269  |  Link
Dogway
Thanks for the help. I just preferred to have all my plugins in the same location for practical purposes, I investigated if this made a difference (like not taking advantage of 64bit features) and it seems it doesn't. The location of 64-bit executables is unrelated to their performance (despite some saying otherwise). BUT it could be MP_Pipeline wasn't designed in this particular way, I should have a look at what line 193 says in the source. I use MP_Pipeline since years ago, but recently just switched to avs+ x64 and after some hurdles this issue is pretty much the only thing irking me.
I'm finishing a project so I will have a deeper look in a few days. Maybe installing though the official installer this time.
Old 8th January 2019, 18:24   #270  |  Link
Yanak
I see, maybe it is not liking it this way indeed, i have not looked into the code plus I am not a coder so i don't know much more than this sadly.
The very last thing that come to my mind and might help figure out thing is in avspmod to only do this as script, without using the LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins64+\MP_Pipeline.dll") that is not needed anymore with avs+ ( it is needed inside the win32 or win64 loops of mp_pipeline as this nice tool can't auto-load plugins sadly ), anyways :
MP_Pipeline("""
### platform: win32
Version()
And after the same with win64 variant
MP_Pipeline("""
### platform: win64
Version()
and see what the preview window returns you for the versions of avisynth+ it is using, this is if it managed to load anything at all with mp_pipeline.
good luck
Old 8th January 2019, 19:55   #271  |  Link
Groucho2004
Groucho2004's Avatar
I'm assuming you mean that the Universal Installer messed with your registry entries. That shouldn't happen if you set up the batch file correctly. Can you describe the problem in more detail?
Groucho's Avisynth Stuff
Old 8th January 2019, 20:59   #272  |  Link
real.finder
try put those in plugins64 folder not the + one
	MP_Pipeline.dll
and those in plugins
	MP_Pipeline.dll
	MP_Pipeline.dll.win64
	MP_Pipeline.dll.win64.slave.exe
and you can try my edit too https://forum.doom9.org/showthread.p...79#post1746479
and make sure that you dont use teracopy or whatever since it did some problems back then for my friend, to check that try to load avs dll using ### dll: from other location
My Avisynth Stuff
Old 8th February 2019, 16:40   #273  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I just wanna report that Planar RGB 16bit (RGBP16) produces a green clip. Converting it back to yuv in the same block "solves" the issue.
MP_Pipeline("""
FFVideoSource("I:\Production\RAW\test8K.mkv")
Crop(0, 0, -0, -630)
AddBorders(0, 314, 0, 314)
Spline64Resize(848, 480)
trim(1081, 5220)
ConvertBits(16)
ConvertToPlanarRGB()
Cube("C:\Programmi\AviSynth+\LUTs\void_null.cube", cpu=1, fullrange=false)
Converttoyuv420()
MP_Pipeline("""
trim(1081, 5220)
ConvertBits(16)
Converttoyuv420()
Broadcast Encoder
LinkedIn
Old 9th February 2019, 14:13   #274  |  Link
Stereodude
I've also noticed it doesn't handle passing at least some of the new AVS+ formats between "blocks" correctly. Not all of them fail in such an obvious manner though.
avisynth, multi-process, pipeline
