Old 26th May 2018, 21:20   #1541  |  Link
manolito
manolito's Avatar
Old 1st June 2018, 10:42   #1542  |  Link
Photon
Photon's Avatar
Cannot set custom quality level for AAC/MP4
Hi all,
I have been using LameXP for over a year - excellent program! However, I'm running into a bug when trying to encode using AAC (qaac 2.66). I don't encounter this problem with either OPUS, MP3 or Vorbis.
I'm currently using Version 4.16, Build 2134.
The problem is this: under the advanced settings tab, when inputting a custom encoding parameter for AAC (in this case, simply: "--tvbr 87") the encode fails, every time.
When inspecting the log, I figured out what the problem was:
As you can see, instead of replacing and overriding the default quality setting (--tvbr 91, which the slider is set to under the Compression tab), the custom setting that I want (--tvbr 87) is just appended to the command string, thus conflicting with the first setting. Naturally this means that the encode stops in its tracks before it can do anything. It throws up this message at the bottom:
Please let me know if you can replicate this. It's the only thing holding me back from using LameXP for AAC encoding (which is otherwise first class).
Photon is offline   Reply With Quote
Old 1st June 2018, 12:17   #1543  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by Photon View Post
Hi all,
Well, the "custom" parameters are simply appended to the command-line that is generated automatically. And, of course, the generated command-line must contain the switches for the selected RC mode.
If you try to set the RC mode via "custom" parameter too, RC mode will unavoidably appear in the command-line twice – as the program clearly says: "custom" parameters are not validated and you use them at your own risk.
Most CLI tools will allow to specify even "conflicting" switches, in which case simply the last option on the command-line will take effect. This way you can easily "override" options already set by the generated command-line.
But: It appears that QAAC does more "pedantic" checking and won't allow to "override" the already-set RC mode.
There is no easy solution for this, because we would need figure out any possible combination of "conflicting" options. And, if a "conflicting" option was detected, remove that option from the generated command-line...
(Maintaining a list of potentially "conflicting" options – for every supported encoder – would be a lot of work. Just to enable a use-case that was never really intended)
Old 1st June 2018, 19:52   #1544  |  Link
Photon
Photon's Avatar
Thanks for the explanation. So in short, there is no way of using a custom-defined bitrate or quality level for AAC in LameXP?
Would it be possible in that case to provide an option somehow tweak the TVBR slider so that we have more granular control? (Maybe an "advanced" slider activated by a checkbox, that allows the user to move up and down in increments of 1). That's the only solution I can think of for this but I don't know how feasible it would be to implement.
Other software allows you to select the TVBR quality level in increments of one right from the GUI, it's just that they don't have any easy was of importing your whole library in one go like LameXP does.
Old 1st June 2018, 20:08   #1545  |  Link
LoRd_MuldeR
Software Developer
Yes. Obviously QAAC doesn't allow overwrite of previous options.
Probably a case of "Placebo Effect"
From QAAC wiki:
From LameXP code:
static const int g_qaacVBRQualityLUT[16] = {0 ,9, 18, 27, 36, 45, 54, 63, 73, 82, 91, 100, 109, 118, 127, INT_MAX};
class QAACEncoderInfo : public AbstractEncoderInfo
	virtual int valueCount(int mode) const
		switch(mode)
		case SettingsModel::VBRMode:
			return 15;
			break;
	virtual int valueAt(int mode, int index) const
		switch(mode)
			return g_qaacVBRQualityLUT[qBound(0, index , 14)];
			break;
Old 1st June 2018, 21:09   #1546  |  Link
Photon
Photon's Avatar
From QAAC wiki:
Well, I just went away and encoded an album using TVBR 87 and 91 using another program... and you're right, exactly the same file size! Not a jot of difference between them. Never would have known that if I hadn't signed up here. Thanks MuldeR.
Old 7th July 2018, 12:21   #1547  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.17 Alpha-3
Changes between v4.15 and v4.16 [2018-04-30]:
* Upgraded build environment to Microsoft Visual Studio 2017.7 (MSVC 19.14)
* Updated Opus encoder/decoder libraries to v1.3-RC-1 (2018-06-01) and Opus-Tools to v0.1.10-71 (2018-04-30)
* Updated MediaInfo to v18.05 (2018-05-09), compiled with ICL 18.2 and MSVC 15.7
* Downgraded FAAD to from v2.8 to v2.7 for now, because v2.8 is currently broken with certain MP4 files
* Fixed detection of certain WMA and AAC files (regression in LameXP v4.16)
Old 7th July 2018, 15:45   #1548  |  Link
manolito
manolito's Avatar
I'm currently looking into a problem regarding the new FAAD version. Maybe I will make a new release after that issue has been resolved...
Looks to me like this is not gonna happen...
I won't bother with LameXP Alpha, Beta or RC versions any longer, it's just too annoying. I went back to the stable version 4.15 and updated a few tools, and this will do until the next stable version comes out...
Cheers
manolito
Old 11th July 2018, 17:48   #1549  |  Link
RieGo
thanks for your regular updates. still using this tool mainly for opus low bitrate encoding stuff
now there's one request i'd like to mention. in LameXP you can only choose between preset bitrate options. 8;16;24 beeing the lowest. now there is quite a big quality gap between 8 and 16 kbit/s in opus.
could you make it possible to somehow be able to set custom bitrate values?
thx
RieGo is offline   Reply With Quote
Old 13th July 2018, 20:34   #1550  |  Link
LoRd_MuldeR
Software Developer
thx
Hello,
for now you could just add "--bitrate <value>" to the custom parameters for OpusEnc, on "Adavanced Options" tab.
This will overwrite the bitrate selected on "Compression" tab.
But if you think that we should add more bitrate steps for Opus towards the lower end, then I could probably do that. Maybe adding 12 kbps and 20 kbps would suffice?
Regards.
Old 13th July 2018, 21:22   #1551  |  Link
LoRd_MuldeR
Software Developer
Hello,
Regards.
Okay, I have adjusted the bitrate mappings for OpusEnc a bit. Can you please try with new TEST version?
https://sourceforge.net/projects/mul...6.exe/download
Old 22nd July 2018, 16:49   #1552  |  Link
RieGo
I apologize for my late response, was on vacation.
just tried this new build and it works just as expected.
you are awesome!
Old 26th August 2018, 21:51   #1553  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.17 Beta-1
Changes between v4.16 and v4.17 [unreleased]:
* Upgraded build environment to Microsoft Visual Studio 2017.8 (MSVC 19.15)
* Fixed detection of certain WMA and AAC files [regression in LameXP v4.16]
Old 27th September 2018, 20:33   #1554  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.17 Beta-2
Old 3rd October 2018, 20:47   #1555  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.17 RC-1
* Updated Opus encoder/decoder libraries to v1.3-RC2 (2018-09-27) and Opus-Tools to v0.2+2 (2018-09-30)
Old 24th October 2018, 22:49   #1556  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.17 RC-4
* Updated Opus encoder/decoder libraries to v1.3 (2018-10-17) and Opus-Tools to v0.2+3 (2018-10-16)
* Updated GnuPG to v1.4.23 (2018-06-11), compiled with GCC 7.3.0
* Some improvements to the auto-update function, which is now using cURL instead of Wget
* Updated language files (big thank-you to all contributors !!!)
Old 27th October 2018, 18:12   #1557  |  Link
danlock
re: LameXP v4.17 RC-4
*grin* vielen Dank!
danlock is offline   Reply With Quote
Old 29th October 2018, 09:55   #1558  |  Link
ArnaudNime
Any plan to support DISCNUMBER tag ?
ArnaudNime is offline   Reply With Quote
Old 10th November 2018, 16:08   #1559  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.17 has been released
https://github.com/lordmulder/LameXP/releases/latest
Changes between v4.16 and v4.17 [2018-10-11]:
Old 10th November 2018, 16:08   #1560  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by ArnaudNime View Post
Probably not, sorry.
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis
