Old 11th April 2012, 22:06   #121  |  Link
sneaker_ger
Oh, there have been updates. Didn't notice that.
Old 22nd July 2013, 18:22   #122  |  Link
stax76
It would be interesting to know what .NET 4.0 features uses since Windows 7 has only .NET 3.5.
stax76 is online now   Reply With Quote
Old 27th July 2013, 22:33   #123  |  Link
Tappen
Windows 7 has .NET 4.0 and 4.5. Win XP SP3 supports .Net 4.0. The only limit so far is that XP doesn't support 4.5.
Tappen is offline   Reply With Quote
Old 27th July 2013, 22:55   #124  |  Link
stax76
Windows 7 was released Oktober 2009 and includes definitively only .NET 3.5.
.NET 4.0 was released much after Windows 7 at April 2010.
Old 28th July 2013, 15:21   #125  |  Link
nautilus7
nautilus7's Avatar
You can install .net 4.0 and 4.5 on windows 7 separetely. Don't see why the confusion.
nautilus7 is offline   Reply With Quote
Old 24th September 2013, 09:33   #126  |  Link
Lyris
Does anyone have a copy of this plugin? Sounds just like what I need, but I can't seem to find a working download location.
Edit: found it - domain name change!
http://www.zachsaw.com/?pg=suptitle_pgs_avisynth_plugin
Lyris is offline   Reply With Quote
Old 14th October 2014, 17:39   #127  |  Link
desperado836
subtitle no in sync
I made my avisynth script, play it in MPC-HC and the sub works, just it is behind the video approximately 5 seconds, any way to adjust the timing of the subtitle?
desperado836 is offline   Reply With Quote
Old 14th January 2015, 09:21   #128  |  Link
stax76
I tried to use SupTitle.dll in StaxRip getting some assembly loading exception with any source I tried, the scripts also crash your C# player and mpc but not necessarily on startup but in the middle or exit. Maybe you can try if you can get it working in StaxRip. This was one of the sources I tried:
General
UniqueID/String                          : 177566164073448104018223832749740118652 (0x8595FFCED77637EEA8E2852C4F63D27C)
CompleteName                             : D:\Video\Samples\MKV\AVC - DTS-MA - PGS.mkv
Format                                   : Matroska
Format_Version                           : Version 4 / Version 2
FileSize/String                          : 382 MiB
Duration/String                          : 2mn 11s
OverallBitRate_Mode/String               : Variable
OverallBitRate/String                    : 24.4 Mbps
Encoded_Date                             : UTC 2014-12-27 20:41:20
Encoded_Application                      : mkvmerge v7.4.0 ('Circles') 32bit built on Dec 12 2014 12:10:09
Encoded_Library/String                   : libebml v1.3.0 + libmatroska v1.4.1
DURATION                                 : 00:01:37.305000000
NUMBER_OF_FRAMES                         : 50
NUMBER_OF_BYTES                          : 152295
_STATISTICS_WRITING_APP                  : mkvmerge v7.4.0 ('Circles') 32bit built on Dec 12 2014 12:10:09
_STATISTICS_WRITING_DATE_UTC             : 2014-12-27 20:41:20
_STATISTICS_TAGS                         : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Video
ID/String                                : 1
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format_Profile                           : High@L4.1
Format_Settings_CABAC/String             : Yes
Format_Settings_RefFrames/String         : 4 frames
CodecID                                  : V_MPEG4/ISO/AVC
BitRate_Maximum/String                   : 37.0 Mbps
Width/String                             : 1 920 pixels
Height/String                            : 1 080 pixels
DisplayAspectRatio/String                : 16:9
FrameRate_Mode/String                    : Constant
FrameRate/String                         : 23.976 fps
ColorSpace                               : YUV
ChromaSubsampling                        : 4:2:0
BitDepth/String                          : 8 bits
ScanType/String                          : Progressive
Default/String                           : Yes
Forced/String                            : No
colour_primaries                         : BT.709
transfer_characteristics                 : BT.709
matrix_coefficients                      : BT.709
colour_range                             : Limited
Audio
ID/String                                : 2
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format_Profile                           : MA / Core
Format_Settings_Mode                     : 16
Format_Settings_Endianness               : Big
CodecID                                  : A_DTS
BitRate/String                           : Unknown / 1 509 Kbps
Channel(s)/String                        : 6 channels
ChannelPositions                         : Front: L C R, Side: L R, LFE
SamplingRate/String                      : 48.0 KHz
BitDepth/String                          : 24 bits
Compression_Mode/String                  : Lossless / Lossy
Forced/String                            : No
Text
ID/String                                : 3
Format                                   : PGS
MuxingMode                               : zlib
CodecID                                  : S_HDMV/PGS
CodecID/Info                             : The same subtitle format used on BDs/HD-DVDs
Forced/String                            : No
Old 14th January 2015, 10:36   #129  |  Link
Zachs
Suptitle, MediaPlayer.NET
SupTitle is discontinued unfortunately due to my server HDD crashing, and the only backup I had was v1.x - fortunately from that experience I now also use cloud-based version control systems for all my active projects.
Zachs is offline   Reply With Quote
Old 17th August 2018, 22:45   #130  |  Link
Dion
I hope someday you come back to this plugin and add support for Avisynth+ and make it work again.
Website seems dead.
But I have the 32bit copy still for people.
https://www.dropbox.com/s/4nvdcplz8j...8_x86.zip?dl=1
or Maybe if anyone knows an alternative plugin to this.
Dion is offline   Reply With Quote
Old 5th March 2019, 09:46   #131  |  Link
pommesmatte
I would also be very interested in an alternative, because SupTitle does not work with Avisynth+.
Anybody knowing a solution?
pommesmatte is offline   Reply With Quote
Old 5th March 2019, 17:49   #132  |  Link
Selur
Selur's Avatar
Just tested and it works fine here, using for example:
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\DGDecodeNV.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\SupTitle.dll")
SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
# loading source: E:\bd_probs\Blu-Ray 1080p AVC DTS-HD MA\BDMV\STREAM\00005.m2ts
#  input color sampling YV12
#  input luminance scale tv
DGSource(dgi="E:\Temp\m2ts_4a3535dbb7070f889ca5f92f88a54966_853323747.dgi",fieldop=2)
# current resolution: 1920x1080
# filtering
# embedding subtitles
Preroll(video=10, audio=0)
# Loading subtitle: E:\Output\00005.track_4608_lang_und.4a3535dbb7070f889ca5f92f88a54966.sup
SupTitle("E:\Output\00005.track_4608_lang_und.4a3535dbb7070f889ca5f92f88a54966.sup")
PreFetch(16)
return last
Cu Selur
Old 9th June 2019, 18:59   #133  |  Link
Selur
Selur's Avatar
As a side note: seems like SupTile crashes for subtitles created by easyavs2bdnxml
avisynth, hard sub, plugin, subtitle, suptitle
