Old 20th July 2017, 15:16   #44381  |  Link
device -> "your device name" -> hdr -> passthrough... -> send meta HDR metadata to... -> use Nvidia's private API.
leave windows at defaults.
Old 20th July 2017, 17:44   #44382  |  Link
x7007
You mean Nvidia Use Default Color Settings ? in Change Resolution ?
x7007 is offline   Reply With Quote
Old 20th July 2017, 18:25   #44383  |  Link
this is about madVR not the nvidia control center.
Old 20th July 2017, 19:12   #44384  |  Link
P.J
strange i can do about everything at 1080p output using a 960.
the HDR SDR conversation takes a lot of processing power but that to be expected but that doesn't mean it is resource hungry.
madVR:
EVR-CP:
P.J is offline   Reply With Quote
Old 20th July 2017, 20:48   #44385  |  Link
Asmodian
You can turn the quality down in madVR if you want to, there are a lot of options for the HDR -> SDR conversion and some change the performance a lot.
madVR options explained
Old 20th July 2017, 20:57   #44386  |  Link
P.J
Shouldn't it work well with default settings?
I think the colors are better with MPC video decoder+EVR-CP
Old 20th July 2017, 21:08   #44387  |  Link
change the HDR brightness settings in madVR.
you can check the nvidia power settings to they shouldn't be at "optimal".
the white details are clearly more clipped on the be conversation.
Old 20th July 2017, 22:39   #44388  |  Link
DragonQ
try is from a CVT reduced blank.
What?
and read the guide so you will stop aiming at the 23.976 hz.
So basically the most important statistic is MadVR's estimation of a frame repeat/drop every x minutes rather than the raw calculated refresh rate?
HTPC Hardware: Intel Celeron G530; nVidia GT 430
HTPC Software: Windows 7; MediaPortal 1.19.0; Kodi DSPlayer 17.6; LAV Filters (DXVA2); MadVR
TV Setup: LG OLED55B7V; Onkyo TX-NR515; Minix U9-H
Old 20th July 2017, 22:51   #44389  |  Link
Asmodian
Start from the "CVT Reduced Blank" default timing option.
Sadly the most important stat is the reported repeated/dropped frames, even madVR's estimate is not accurate (madshi has stressed this point many times). You have to see what actually happens if you want it perfect, nothing can measure the true clock rates accurately enough.
Old 21st July 2017, 13:22   #44390  |  Link
x7007
Hey, ok I understand how to enable HDR.
but performance question.
When watching in Exclusive Full Screen my rendering time MS is very high
Windowed mode works fine.
If I'm using 4K resolution + HDR or without HDR for that matter.
What should I lower so I can watch movies properly ? I watch usually movies and series 1080P and 720P MKV , now I use
Chroma Upscaling NGU AntiAlias- Very High quality
Image Downscaling Jin - Scale in linear light On , activate anti-ringing filter - relax On
Image Upscaling NGU Anti-Alias - Luma doubling Very High all the rest is let madVR decide
which options can I change without affecting the quality of the picture ?
I have
3770K
1080 GTX
Old 21st July 2017, 13:25   #44391  |  Link
ryrynz
ryrynz's Avatar
Drop back those NGU AA settings.. easy. Did you really need to ask? Is madVR really that hard to configure? =/
Old 21st July 2017, 13:28   #44392  |  Link
x7007
I know, I just lowered in the upscaling in dobling . luma doubling to High or Medium. that fixed it.
It's not hard, but I just ask a simple question , you saw how simple was that. Why getting mad ? it's a forum , there are many options , there are many issues. didn't you ever asked a question and you got the same question you gave ? what would you feel...
Always think about what happen when you get the same answer you wanted to give.
Old 21st July 2017, 13:30   #44393  |  Link
ryrynz
ryrynz's Avatar
"It's a forum" Ask questions for answers you can find yourself with two mouse clicks.. C'mon.
Old 21st July 2017, 19:29   #44394  |  Link
jkauff
Actually, it is for a lot of people, especially new users and people who don't understand video technology very well.
I think madshi has said a few times that making madVR easier to configure is a major priority before he'll do a 1.0 release.
Old 21st July 2017, 21:37   #44395  |  Link
PurpleMan
Can anyone help explain why I'm getting dramatically different performance with kodi-dsplayer+madvr vs mpc-hc+madvr ?
kodi-dsplayer+madvr+lavfilters (external) = >50ms rendering time
mpc-hc+madvr+lavfilters (external) = ~15ms rendering time
Same renderer, same settings, same decoder filters.
I have kodi set to NOT manage madvr, so it's the exact same settings as when I close kodi and run mpc-hc (both are x86).
Whats the difference I'm missing here?
PurpleMan is offline   Reply With Quote
Old 21st July 2017, 22:06   #44396  |  Link
sneaker_ger
Are GPU clocks the same during playback with both of them? Maybe with kodi the GPU is in lower power state for some reason.
Old 21st July 2017, 22:07   #44397  |  Link
Asmodian
Luma doubling quality is more important than chroma upscaling quality. Lower chroma down to medium before lowering the luma doubling quality.
Old 21st July 2017, 23:13   #44398  |  Link
PurpleMan
I would assume so, as I've set the power mode in the nvidia control panel to Adaptive instead of power save. However, how would I go on making sure? I can run something like GPU-Z, but how would I know what it shows while playing fullscreen?
Old 21st July 2017, 23:23   #44399  |  Link
el Filou
el Filou's Avatar
Are Kodi's GUI & OSD still available when using madVR? The player's interface rendering might interfere with the video renderer, I know it does with MediaPortal.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 21st July 2017, 23:36   #44400  |  Link
PurpleMan
They're available by design, but this happens regularly even if I don't have any GUI elements displayed. Either way, I would assume this shouldn't have that kind of dramatic effect on performance. It basically makes it unusable if it's by design like this.
