Old 13th November 2009, 15:17   #221  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
I didn't encounter any freezes with r1332 so far. But we should update to r1336 now, as it contains "various weightp fixes".
Hopefully the freeze problem some people encounter is gone too...
Old 13th November 2009, 23:10   #222  |  Link
LoRd_MuldeR
Software Developer
Updated x264 to r1336 (JEEB's builds). It's recommended to update from r1332, as there were "various weightp fixes".
Also the minimum x264 revision supported by the GUI was reduced to r1318 again
Old 14th November 2009, 15:43   #223  |  Link
dstln
Person
dstln's Avatar
Still stuck hanging last night on firstpass. :-\
dstln is offline   Reply With Quote
Old 14th November 2009, 15:51   #224  |  Link
LoRd_MuldeR
Software Developer
If that problem isn't specific to my launcher (which appearently is the case), then this is the wrong thread to complain.
See here:
http://forum.doom9.org/showthread.ph...96#post1343696
Old 16th November 2009, 03:02   #225  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
It seems I found a way to reproduce the crash. Edit: or maybe not...
Anyway it happened 3 times in a row when I watched something with MPC-HC in fullscreen. Message "encoding finished" appeared on top of the video, after I clicked OK, MPC-HC lost its focus (focus lost to launcher.exe) and GUI crashed.
Old 16th November 2009, 23:41   #226  |  Link
LoRd_MuldeR
Software Developer
I don't see how another process, such as MPC-HC, could crash my GUI process.
Well, unless MPC-HC injects a DLL into my process and the code in that DLL triggers a crash
So are you 100% sure it has something to with MCP-HC? I can't reproduce it here...
Old 16th November 2009, 23:42   #227  |  Link
LoRd_MuldeR
Software Developer
Updated x264 to r1342 (JEEB's builds).
It's recommended to update ASAP, because in earlier revisions Weighted P-Frame Prediction could produce out-of-spec H.264 streams.
Old 17th November 2009, 08:48   #228  |  Link
Maccara
Thanks!
I'll have to say, this is a neat utility for doing the occasional encode.
Only thing I wish this did have, was the ability to select several .avs files which would then all be encoded. Just batching.
I mean, no need for "fancy" queue system with separate settings per encode or anything like that - just set settings once, select a bunch of avs files and out comes a bunch of 264/mp4/mkv files with the avs files' basenames.
Would be a nice addition, but since the sources are provided I can add that myself at some point if I really really need it.
Maccara is offline   Reply With Quote
Old 19th November 2009, 12:32   #229  |  Link
HaraldBluetooth
Originally Posted by Maccara View Post
Thanks!
It could be very nice to have that feature, so you could go to sleep or work, without wasting too much encoding time.
HaraldBluetooth is offline   Reply With Quote
Old 22nd November 2009, 12:52   #230  |  Link
Forteen88
Herr
Thanks, but --zones doesn't work with this launcher ("error") :P I like to use zones to set even lower quality on end-credits.
EDIT: Though b=0.2 is probably better to use for end-credits than q=29 :P
Forteen88 is offline   Reply With Quote
Old 22nd November 2009, 13:21   #231  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by Forteen88 View Post
Thanks, but --zones doesn't work with this launcher ("error") :P I like to use zones to set even lower quality on end-credits (q=29).
There is no reason why that option shouldn't work. You can enter whatever "custom" parameters you like
But the GUI won't check your custom parameters at all. Not even for correct syntax! The parameters are forwarded to x264 exactly as you enter them.
So probably there was a mistake in your custom parameters. But it's impossible to, because you didn't even paste your log...
[EDIT]
Does x264.exe (not the GUI) crash when using the "--zones" parameter? If so, then this is a bug with x264 or more specifically with x264 compiled under MinGW32.
It's not related to the GUI at all. You'd probably have to get a build of x264.exe that contains the "zone parse fix" patch...
Old 22nd November 2009, 14:17   #232  |  Link
Forteen88
Herr
Originally Posted by LoRd_MuldeR View Post
... It's not related to the GUI at all. You'd probably have to get a build of x264.exe that contains the "zone parse fix" patch...
I used the parameter: --zones 148400,153528,q=29
and I used the x264.r1342 that came with your latest launcher (and it used the x64-version of x264 when I encoded something). I'll try that parameter later (after I've done my current encode without zones, which will take some days) with only x264.r1342 in commandmode (but then with x264 32-bits).
EDIT: Thanks, I'll try that x264-build after I'm done with my current encode.
EDIT2: --zones worked when I changed x264-build...
Old 22nd November 2009, 14:24   #233  |  Link
LoRd_MuldeR
Software Developer
Your error description remains extremely vague. Anyway, try to replace the "x264_x64.exe" with that one:
http://komisar.gin.by/x264.1342kGIT.core2.x86_64.exe
(Note that you must rename the download to "x264_x64.exe" and replace the existing file)
Old 23rd November 2009, 02:14   #234  |  Link
hxhxd
LoRd_MuldeR, thanks for the great tool.
There's a feature request: Would you add the "delete intermediate files" feature?
edit: another feature request: automatic save program output into a log file.
Thanks!
hxhxd is offline   Reply With Quote
Old 24th November 2009, 21:49   #235  |  Link
Rodger
Before that there really should be implemented a shutdown feature.
Maybe Lord Mulder lets us know where this little puppy is headed.
Possibly someone is able/willing to support/help?!
Rodger is offline   Reply With Quote
Old 25th November 2009, 22:01   #236  |  Link
LoRd_MuldeR
Software Developer
Updated x264 to r1347 (Komisar's builds).
Old 28th November 2009, 18:09   #237  |  Link
LoRd_MuldeR
Software Developer
Updated x264 to r1352 (Komisar's builds).
Old 28th November 2009, 18:14   #238  |  Link
poisondeathray
Nice little GUI! Simple, easy to use.
Small feature request: It's not a big deal, but since x264 supports .flv export now, can you add that too?
There might be a small spelling error, when it says "compleded" instead of "completed"
Thanks
Old 28th November 2009, 18:21   #239  |  Link
LoRd_MuldeR
Software Developer
Done.
Fixed. Please re-download.
Old 28th November 2009, 18:22   #240  |  Link
poisondeathray
Done.
Wow that was quick
