Old 31st January 2010, 05:46   #1161  |  Link
jksmurf
Originally Posted by MrC View Post
Do you have same issue using the Installer version?
Yes, I can now confirm I do have the same issue using the installer. Windows Vista 32 Home Premium.
Can you replicate on another PC?
Works OK on a WinXP Machine.
but now there's another twist - a newly downloaded 225 no-install no longer works either ??
btw noticed a small typo "inistalled" (i.e. missing the "n") on the uninstaller message ... minor issue!
k.
jksmurf is offline   Reply With Quote
Old 31st January 2010, 07:24   #1162  |  Link
eSkRo
eSkRo's Avatar
@ jksmurf:
I'm suspecting corrupted Windows registry due to invalid entries that exist
because of software you are no longer using,
or an improper software installation or removal.
i'm not a BIG fan of Registry Cleaners but in your case,
i would try one and clean out Windows Registry...
try Eusing Free Registry Cleaner 2.6 --> http://www.softpedia.com/get/Tweak/R...-Cleaner.shtml
Tor [anonymity network]
eSkRo is offline   Reply With Quote
Old 31st January 2010, 07:30   #1163  |  Link
jksmurf
Thanks esKro, I did try CCleaner (not a fan of cleaners either ) restarted PC etc etc - no joy. Really odd.
k.
Old 31st January 2010, 07:34   #1164  |  Link
eSkRo
eSkRo's Avatar
Old 2nd February 2010, 18:00   #1165  |  Link
mikenadia
Output duration shorter than input.
I must do something wrong but I do not know what.
Output duration shorter than input. in 2.2.6, I had a warning telling me that (i clicked on Yes for test purposes: did not have that warning in 2.2.5 but same results).
The input is a Trimmed VOB from a DVD file. It plays OK in PowerDVD for the input duration.
Here is the log.
<02/02/2010 12:50:37 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 1
DVD Size: 156/4450 MB (4%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Documents and Settings\Owner\Desktop\New Folder\Output
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: A2DSource
AVS Resize Filter: Lanczos4Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6000
Video Profile Level 2: 6000
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliat Audio: 1
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: EN - English
Chapthers Interval: 5
Use Source Chapters: 1
DVD Burning Drive: E: PHILIPS DVD+-RW DVD8701 5D24
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: C:\Documents and Settings\Owner\Desktop\New Folder\test.m2v
Info: MPEG-2 Video - 1410 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Interlaced (TFF) - 2:33 minutes - 3674 frames
Audio:
Info:
Subs:
[MediaInfoLib - v0.7.26]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
LoadPlugin("C:\Program Files\AVStoDVD\Lib\LeakKernelDeint.dll")
Video = A2DVideoSource("C:\Documents and Settings\Owner\Desktop\New Folder\test.m2v", CacheFolder = "C:\DOCUME~1\Owner\LOCALS~1\Temp")
Video = Video.ConvertToYV12(interlaced = true)
#Using DGPulldown to upsize FPS
Video = Video.LeakKernelBob(1,7,false,false)
Video = Video.Lanczos4Resize(720,576)
Video = Video.SeparateFields().SelectEvery(4,1,2).Weave()
Return Video
START VIDEO ENCODING OPERATIONS
Encoding Profile: QuEnc CBR 1-pass
Target Video FileSize: 155 MB
QuEnc Parameters: -i "C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_1_test.avs" -o "C:\Documents and Settings\Owner\Desktop\New Folder\Output\DVD_1_test.m2v" -b 8500 -1 -hq -novbr -scene -trell -aspectratio 16:9 -interlaced -tff -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<02/02/2010 12:52:55 PM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: C:\Documents and Settings\Owner\Desktop\New Folder\Output\DVD_1_test.m2v (40.5 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 8500 kbps - 720x576 - DAR 1.778 - 23.976 fps (CFR) - Interlaced (TFF) - 39 seconds - 958 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "C:\Documents and Settings\Owner\Desktop\New Folder\Output\DVD_1_test.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
<02/02/2010 12:53:00 PM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: C:\Documents and Settings\Owner\Desktop\New Folder\Output\DVD_1_test.m2v (40.5 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 8500 kbps - 720x576 - DAR 1.778 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 39 seconds - 959 frames
<><02/02/2010 12:53:18 PM>
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_1_BatchMux.ini"
BatchMux ini file:
-d "C:\Documents and Settings\Owner\Desktop\New Folder\Output\DVD_1\VIDEO_TS"
-mxp "C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_1_MuxMan.mxp"
-l "C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_1_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "C:\Documents and Settings\Owner\Desktop\New Folder\Output\DVD_1_test.m2v"
-vidmode LB
<02/02/2010 12:53:26 PM>
END DVD AUTHORING OPERATIONS
Created Folder: C:\Documents and Settings\Owner\Desktop\New Folder\Output\DVD_1 (41.2 MB)
Log file created by AVStoDVD Release 2.2.6
small typo in log: "Preferences";Keep DVD Compliat Audio: 1 and Chapthers Interval: 5
Thanks in advance.
mikenadia is offline   Reply With Quote
Old 2nd February 2010, 20:36   #1166  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@mikenadia
in 2.2.6 I have added a duration congruency check, that's the reason of the new warning.
For some reason, QuEnc encoding stops after 39 seconds. Have you tried with HCenc profiles? Have you used the 'Preview Clip' function to verify if the video is decoded and played correctly (directshow approach)?
Thanks for the typo reports.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 2nd February 2010, 21:11   #1167  |  Link
mikenadia
@MrC
Thank you for your quick answer. Great program.
Preview clip shows me 1000 frames and I am able to jump forward (frame by frame) from frame number 958 till 1000.Everything looks OK.
HC also takes only 959 frames.
DGindex finds 3678 frames (3678 coded and Playback and No errors in d2v), which is slightly different from AVStoDVD (3674 frames).
Hc is able to encode the input source using DGindex 1.5.7 and encoded the 3678 frames.
The input file is problematic. It is a trimmed version from a file that gave me other problems.
Edit1: Solved. The file had to be indexed with DGindex 1.5.7 (the DGdecode.dll from DVD-RB seems to be the issue).
http://forum.doom9.org/showthread.ph...75#post1370075
Thanks a lot.
Edit2: on an unrelated note and purely cosmetics.
In the "Encoding" tab ( in the Audio-video Tab, the video minimum bitrate has been left at 2500) ,if I go to change HC-1pass preferences (lower bitrate from 6000 to 2000 (has to be smaller than 2500) and then go to HC-2pass preferences (without clicking on OK: just with the mouse), the higher bitrate is 2000 (while the lower stays at 2500) I have " Error runtime 383: "Text" property is read-only". I do not understand why the minimum bitrate of one is taken as maximum bitrate for the second one (same thing if I choose Quenc and then HC-1pass).
Old 3rd February 2010, 19:26   #1168  |  Link
mikenadia
The file is still problematic.
What I did: I used DVD-Decrypter to get the "File-No splitting" (preprocessed with VOBlanker ) VOB. I will go to the unprocessed if needed.
I indexed that file with DGindex 1.5.7. HC does not hang now.I used HC to trim that file to the same 3678 frames.
I fed that to AVStoDVD and now Preview, Quenc and HC all give me 1879 frames.
So I decided to fed the original preprocessed VOB ( 3Gb).And I have that error (that disappear quickly because it is in the "Info" line of HC (last 5 sec).
Error loading Avisynth script, Change FPS: Ratio must be less than 10 for linear access; Set LINEAR=False
Problem in Line 9 of the avs file.
If I fed HC with a simple avs (using DGindex 1.5.7 to index the 3Gb VOB), no error : Everything is OK.
This is the avs file and the ini file.
LoadPlugin("C:\Program Files\AVStoDVD\Lib\ffms2.dll")
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = FFAudioSource("C:\test-TAXI2\Output\VTS_01_1.VOB", track = -1, cachefile = "C:\DOCUME~1\Owner\LOCALS~1\Temp\A2DFFA_" + String(Rand()) + ".cache")
Video = FFVideoSource("C:\test-TAXI2\Output\VTS_01_1.VOB", track = -1, cachefile = "C:\DOCUME~1\Owner\LOCALS~1\Temp\A2DFFV_" + String(Rand()) + ".cache", seekmode = 0)
Video = Video.ChangeFPS("pal_video")
Video = Video.AddBorders(0,50,0,50)
AudioDub(Video, Audio)
*INFILE C:\test-TAXI2\Output\DVD_11_VTS_01_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Owner\Desktop\New Folder\Output\DVD_11_VTS_01_1.m2v
*LOGFILE C:\test-TAXI2\Output\DVD_11_VTS_01_1.HCenc.log
*MAXBITRATE 9000
*BITRATE 6000
*PROFILE BEST
*ASPECT 16:9
*INTERLACED
*TFF
*BIAS 60
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
Thanks in advance.
On a unrelated note, it seems that if I fed a small VOB file (40 Mb) (just to have a DVD_Structure) and I keep the output size to DVD-5 (default) , I cannot get HC (only Quenc). Setting the output to "Custom" solves the issue.
Edit: The PAL"output" works only if saved as Default Preferences.
Old 3rd February 2010, 20:31   #1169  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@mikenadia
best approach in this situation is to feed AVStoDVD with the DGIndex project file (d2v), since this one is not problematic.
Thanks for the bug report. I will fix it ASAP.
See Help/FAQ/Q3.5
Bye
MrC
AVStoDVD Homepage
Old 12th February 2010, 20:42   #1170  |  Link
glisoni
Hello, MrC.
Since my previous post, I made many fine encodes, thanks to your fine program.
Now, I have two remarks:
1. Detecting embedded subs works well now, but extracted subs are UTF-8. This maybe OK for English subs, but for CP1250 that I use (Serbian language) this is bad. Subs are not displayed correctly, because Subtitle Creator is not decoding this UTF-8 to CP1250. I still have to manually open the sub file, and to save it as regular ASCII actually, sys default, which is CP1250 for me). Olny then, Subtitle Creator will encode subs with correct characters.
2. Recently, I tried to convert .mp4 file with aac audio track, and video was fine, but I got no audio (quenc was set for audio).
Any ideas what happened?
Goran
glisoni is offline   Reply With Quote
Old 13th February 2010, 20:57   #1171  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hi Goran,
1. AVStoDVD has its own routine to convert UTF to ASCII. If you have problems, maybe it can be improved. Could you please send me a .srt file (still in UTF format), to understand what's the problem?
2. Log file needed
Bye
MrC
AVStoDVD Homepage
Old 14th February 2010, 08:12   #1172  |  Link
glisoni
MrC,
subtitle file is uploaded. Hope it won't take to long for it to get approved...I also added a print-screen with a line of text for better understanding. Marked character should be (s with a little hat in form of letter v)
Regarding the second problem, the aac issue, I'll make one encode this evening, and post logs...
BR
Goran
Old 15th February 2010, 22:20   #1173  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@glisoni
yes you are right, the UTF2ANSI routine has to be "improved"
While waiting for next AVStoDVD release, use the Windows Notepad as converter.
Bye
MrC
AVStoDVD Homepage
Old 21st February 2010, 02:37   #1174  |  Link
MilesAhead
MilesAhead's Avatar
Anyone end up with both a hard-coded and a soft subtitle? I used an .mkv with UTF-8 stream English subs. AVStoDVD detected the embedded subs. Asked me to select the stream and save the file. I saved it to movie.srt. Done processing, I have a small hard-coded or "burned in" English sub, and a selectable sub that's about 1 1/2 times the size of the burned in sub, displayed below it. Choice is either small sub or double sub. Strange.
"I don't want to belong to any club that would have me as a member."
- Groucho Marx
MilesAhead is offline   Reply With Quote
Old 23rd February 2010, 05:58   #1175  |  Link
MilesAhead
MilesAhead's Avatar
The other subtitle thing I notice is ifo/sup subs, it created selectable subs, but it seems to ignore the .ifo file. The colors are distored just as when authoring with no .ifo file. I can use PgcEdit to correct the colors easily enough but it would be cool if that wasn't necessary.
Not that I'm complaining. I'm getting some really good quality DVD9 output!
- Groucho Marx
Old 23rd February 2010, 17:26   #1176  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
I cannot exactly understand if it is a problem: have you choosen to hard-encode the subs or not?
Take note that sup format already contains the graphical info (it is a bitmap-type subtitle format). If you want to change colors/font/etc. you have to re-encode the sup.
Bye
MrC
AVStoDVD Homepage
Old 23rd February 2010, 19:57   #1177  |  Link
MilesAhead
MilesAhead's Avatar
No. But I got a small hard-coded sub and a large selectable one. As I said, if you turn subs off, you get the small hard coded sub. If you turn them on, you get both. I demuxed the video and played just the video stream in a player to verify the subs were burned in. The hard sub checkbox was not checked.
It's a file pair. There's an .ifo and a .sup. For example if you use DVDSubEdit to load a .sup, it will immediately pop open another dialog for you to load the .ifo part of the subtitle pair.
I got similar results with SVCD2DVD and DVDAuthorGui if I only have the .sup file. Which leads me to believe the .ifo file has some color conversion or other information that's needed.
edit: FAVC only supports .srt files, but I looked through the produced scripts and batch files. I calls SubtitleCreator and uses both the output .ifo and .sup files in the muxing. The .ifo must be there for a reason.
edit2: in case anyone else is using BDSup2Sub.. you can export the palette in text format for PgcEdit. After DVD created you can load in PgcEdit, then load the palette. That will give you an idea how the original colors were. You can still then change white subs to yellow or whatever if you want. It just helps avoid guessing which color in the CLUT goes to which part of the subtitle.
It is pretty fast to make the change. I'm just kind of curious why so many authoring programs seem to ignore the .ifo component or what the issue is.
- Groucho Marx
Old 24th February 2010, 16:48   #1178  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Do you still have the log file?
Again, sup format already contains the subs graphical info, while srt format does not (just text and timestamps). That's the reason because FAVC (and AVStoDVD) uses an external ifo file for palette info.
I do not know how DVDSubEdit (or other sw) manage sup files, maybe they do a sort of reconversion using the ifo graphical info.
Anyway BatchMux (MuxMan wrapper used by AVStoDVD) accepts only sup (or sst) files... thus sup remuxing with another ifo is up to you. Or if you want to automate the process, we could add it as new AVStoDVD feat.
Bye
MrC
AVStoDVD Homepage
Old 28th February 2010, 10:40   #1179  |  Link
ummus
Sir, I have converted an AVI movie file into DVD VOB files. But, the audio is not matching with video. Why Sir?
The log details are here.
<2/26/2010 12:45:21 PM>
START PROCESS
PROJECT SETTINGS
DVD Size: 4450/4450 MB (100%)
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Users\katheeja\Documents
PREFERENCES
Video Resolution: 0
Video Profile Level 2: 4500
DVD Audio Format: 0
Normalize Audio: 0
DVD Burning Drive: G:\
Save Log file: 1
Video: F:\New Folder\Movies\Tamil\SivaKaasi - Bo$$.avi
Info: XviD - 1687 kbps - 640x288 - DAR 2.222 - 23.976 fps (CFR) - Progressive - 2:55:36 hours - 252625 frames
Audio: F:\New Folder\Movies\Tamil\SivaKaasi - Bo$$.avi
Info: MPEG-1/2 L3 - 128 kbps - CBR - 48000Hz - 2ch - 2:58:49 hours
Subs:
[MediaInfoLib - v0.7.25]
AVISYNTH SCRIPT
Video = A2DVideoSource("F:\New Folder\Movies\Tamil\SivaKaasi - Bo$$.avi", CacheFolder = "C:\Users\katheeja\AppData\Local\Temp")
Audio = A2DAudioSource("F:\New Folder\Movies\Tamil\SivaKaasi - Bo$$.avi", CacheFolder = "C:\Users\katheeja\AppData\Local\Temp")
Video = Video.AddBorders(0,36,0,36)
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 4056 MB
HCenc Parameters: -ini "C:\Users\katheeja\AppData\Local\Temp\DVD_0_SivaKaasi - Bo$$.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\katheeja\AppData\Local\Temp\DVD_0_SivaKaasi - Bo$$.avs
*AVSRELOAD
*OUTFILE C:\Users\katheeja\Documents\DVD_0_SivaKaasi - Bo$$.m2v
*LOGFILE C:\Users\katheeja\AppData\Local\Temp\DVD_0_SivaKaasi - Bo$$.HCenc.log
*MAXBITRATE 9000
*BITRATE 3229
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<2/26/2010 3:29:08 PM>
A2DVideoSource: AVISource
Created File: C:\Users\katheeja\Documents\DVD_0_SivaKaasi - Bo$$.m2v (4057.8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3253 kbps - 720x576 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:55:26 hours - 252372 frames
DGPulldown Parameters: "C:\Users\katheeja\Documents\DVD_0_SivaKaasi - Bo$$.m2v" -srcfps 23.976 -destfps 25 -inplace -bff
<2/26/2010 3:36:30 PM>
DGPulldown executed on File: C:\Users\katheeja\Documents\DVD_0_SivaKaasi - Bo$$.m2v (4057.8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3250 kbps - 720x576 - DAR 1.778 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 2:55:36 hours - 252877 frames
<2/26/2010 3:36:31 PM>
START AUDIO ENCODING OPERATIONS
Wavi+Aften Parameters: "C:\Users\katheeja\AppData\Local\Temp\DVD_0_SivaKaasi - Bo$$.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -pad 0 -b 192 - "C:\Users\katheeja\Documents\DVD_0_SivaKaasi - Bo$$.ac3"
<2/26/2010 3:40:26 PM>
END AUDIO ENCODING OPERATIONS
A2DAudioSource: DirectShowSource
Created File: C:\Users\katheeja\Documents\DVD_0_SivaKaasi - Bo$$.ac3 (241.2 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 48000Hz - 2ch - 2:55:36 hours
BatchMux Parameters: -arglist "C:\Users\katheeja\AppData\Local\Temp\DVD_0_BatchMux.ini"
BatchMux ini file:
-d "C:\Users\katheeja\Documents\DVD_0\VIDEO_TS"
-mxp "C:\Users\katheeja\AppData\Local\Temp\DVD_0_MuxMan.mxp"
-l "C:\Users\katheeja\AppData\Local\Temp\DVD_0_MuxMan.log"
-prio LOW
-v "C:\Users\katheeja\Documents\DVD_0_SivaKaasi - Bo$$.m2v"
-vidmode LB
-a1 "C:\Users\katheeja\Documents\DVD_0_SivaKaasi - Bo$$.ac3"
-a1lang en
-cellfr "C:\Users\katheeja\AppData\Local\Temp\DVD_0_SivaKaasi - Bo$$_MuxMan.txt"
-progfr "C:\Users\katheeja\AppData\Local\Temp\DVD_0_SivaKaasi - Bo$$_MuxMan.txt"
-chapfr "C:\Users\katheeja\AppData\Local\Temp\DVD_0_SivaKaasi - Bo$$_MuxMan.txt"
<2/26/2010 3:48:14 PM>
Created Folder: C:\Users\katheeja\Documents\DVD_0 (4411.2 MB)
Log file created by AVStoDVD Release 2.2.5
ummus is offline   Reply With Quote
Old 28th February 2010, 12:51   #1180  |  Link
Nick
One click is all it takes
Nick's Avatar
ummus - please pm me with clarification of what this "SivaKaasi - Bo$$.avi" file is and how you obtained it.
As per forum rule 6, we do not help with movies downloaded from p2p etc here and the format of this filename sets alarm bells ringing.
Nick is offline   Reply With Quote
[IMG] code is Off
