Old 28th November 2012, 01:25   #2161  |  Link
ThaDraGun
Originally Posted by Sparktank View Post
Change the settings in DirectVobSub. Make sure you enable "hide subtitles".
You can use Codec Tweak Tool > DirectShow Filters and change the settings from there.
Then when I DO want to have a subtitle show I just have to go back and unhide?
ThaDraGun is offline   Reply With Quote
Old 28th November 2012, 01:28   #2162  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
That's one option.
You can extract the subtitles and convert them and let AVStoDVD load them. SRT format are the best, imo.
Converting to an IDX/SUB format tends to leave a lot of artifacts around the subtitles.
Win10 (x64) build 17134 | GPU Caps Viewer 1.40.1.0
NVIDIA GeForce GT 1030 (GP108) 2047MB/GDDR5 | (R417.22)
NTSC | DVD: R1 | BD: A
Old 28th November 2012, 01:30   #2163  |  Link
ThaDraGun
I just downloaded codec tweak 5.4.8 and dont see any option to hide subtitles
Old 28th November 2012, 01:31   #2164  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
DirectShow Filters > DirectVobSub > Misc > Hide Subtitles
Old 28th November 2012, 01:37   #2165  |  Link
ThaDraGun
Finally found it, I dunno how I missed it. Was looking at the directshow under codec and filter managemnt.
thanks
Old 9th December 2012, 22:15   #2166  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Is there anyway to change settings to the subtitles default status?
Normal subtitles (not forced) seem to be enabled by default during playback.
I have to turn them off when the disc starts whether on my DVD/BD machine or media player on my PC.
Old 10th December 2012, 11:45   #2167  |  Link
edwood
I just burned my first dual layer dvd (8 - 48min .avi files) using AVS2DVD. I like the menu setup, and the way it is easier to customize them compared to DVDFlick which I have been using for several years.
However, AVS2DVD took a total of 22 hours and 17 minutes from start to finish to complete the project. Is this normal? or did I set things up wrong? That amount of time for a project is 4 times as long as it takes DVDFlick to complete a project of the sae type (8 - 48min .avi files).
I love AVS2DVD, but obviously, I cannot tie up my laptop for a full 24 hours to complete one project when I have over 400 episodes of Perry Mason and Ironside to compile to DVD.
Any suggestions on why it took so long to complete the project? Have a great week!
Thanks,
Ed Wood
edwood is offline   Reply With Quote
Old 10th December 2012, 12:31   #2168  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@edwood
2 questions to begin:
1. What is your system? I mean: CPU, RAM, HD
2. Could you post the neverending project log file?
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 10th December 2012, 12:50   #2169  |  Link
edwood
MrC
I will search for the log file to post. Where is it located, and what is it titled?
You raised the point that is probably my problem. The laptop has a cpu speed of 1.3mhz. There is 2mb ram installed, and the hdd size is 80mb of which it is probably 1/2 full. I have a 1tb external usb drive that I will see if the laptop will recognize and use. That should speed up the process considerably if AVS2DVD will support the external drive.
Thanks,
Ed
Old 10th December 2012, 16:49   #2170  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Look in the Output Folder you selected in AVStoDVD. There is the DVD folder and a .log file. Copy and paste here the content of the .log file.
1.3 Ghz are really not that much. Mainly if the cpu is single core and the source title is HD and/or long.
BTW, let's see the project log file.
Bye
MrC
AVStoDVD Homepage
Old 11th December 2012, 14:53   #2171  |  Link
edwood
MrC
Here are the log files from my last project that took 22+ hours to complete. There are 8 of them.
#1
[Input info]
Bitrate=192
Actual rate=192.000000
Sampling Frec=48000
TotalFrames=96616
Bytesperframe= 768.0000
Filesize=74201088
FrameDuration= 32.0000
Framespersecond= 31.2500
Duration=00:51:31.712
Channels mode=2/0: L+R
LFE=LFE: Not present
[Target info]
StartFrame=5
EndFrame=96615
NotFixedDelay= 0.0000
Duration=00:51:31.552
====== PROCESSING LOG ======================
Seeking....
Done.
Processing....
Number of written frames = 96611
Number of Errors= 0
#2
[Input info]
Bitrate=192
Sampling Frec=48000
TotalFrames=96575
Filesize=74169600
Duration=00:51:30.400
[Target info]
StartFrame=5
EndFrame=96574
Duration=00:51:30.240
Seeking....
Done.
Processing....
Number of written frames = 96570
Number of Errors= 0
#3
[Input info]
Bitrate=192
Sampling Frec=48000
TotalFrames=96490
Filesize=74104320
Duration=00:51:27.680
[Target info]
StartFrame=5
EndFrame=96489
Duration=00:51:27.520
Seeking....
Done.
Processing....
Number of written frames = 96485
Number of Errors= 0
#4
[Input info]
Bitrate=192
Sampling Frec=48000
TotalFrames=96795
Filesize=74338560
Duration=00:51:37.440
[Target info]
StartFrame=5
EndFrame=96794
Duration=00:51:37.280
Seeking....
Done.
Processing....
Number of written frames = 96790
Number of Errors= 0
#5
[Input info]
Bitrate=192
Sampling Frec=48000
TotalFrames=96632
Filesize=74213376
Duration=00:51:32.224
[Target info]
StartFrame=5
EndFrame=96631
Duration=00:51:32.064
Seeking....
Done.
Processing....
Number of written frames = 96627
Number of Errors= 0
#6
[Input info]
Bitrate=192
Sampling Frec=48000
TotalFrames=96654
Filesize=74230272
Duration=00:51:32.928
[Target info]
StartFrame=5
EndFrame=96653
Duration=00:51:32.768
Seeking....
Done.
Processing....
Number of written frames = 96649
Number of Errors= 0
#7
[Input info]
Bitrate=192
Sampling Frec=48000
TotalFrames=96932
Filesize=74443776
Duration=00:51:41.824
[Target info]
StartFrame=5
EndFrame=96931
Duration=00:51:41.664
Seeking....
Done.
Processing....
Number of written frames = 96927
Number of Errors= 0
#8
[Input info]
Bitrate=192
Sampling Frec=48000
TotalFrames=96786
Filesize=74331648
Duration=00:51:37.152
[Target info]
StartFrame=5
EndFrame=96785
Duration=00:51:36.992
Seeking....
Done.
Processing....
Number of written frames = 96781
Number of Errors= 0
I have installed the 1gb external drive on my laptop and tried to access it through AVS2DVD. I was able to import the .avi files into AVS2DVD, and set the output folder to the external drive. I have not, as yet, tried to burn a DVD. I will try that next to see if there is any speedup in the project with a larger available drive to operate with.
Thanks for your help.
Ed Wood
Old 11th December 2012, 16:25   #2172  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
These are not logs from AVStoDVD.
AVStoDVD .log file is just ONE file named with the DVD label you have inserted in the main AVStoDVD window and located in the Output Folder you have selected in the main AVStoDVD window.
For example, if you have labeled you DVD as "My DVD" and you have selected "D:\Movies" as output folder, then the log file will be:
D:\Movies\My DVD.log
Bye
MrC
AVStoDVD Homepage
Old 11th December 2012, 18:33   #2173  |  Link
edwood
MrC.
I found 4 text files titled Ironside_D1_S1_0, Ironside_D1_S1_1, Ironside_D1_S1_2, Ironside_D1_S1_3. They were all document files, not log files.
I tried to post them on this forum board but each one by itself far exceeded the 16,000 characters allowed in posts.
If that is not the log file you refer to, I cannot find it on my computer. I am now in the process of burning a 2nd dvd and timing the burn, since I am writing to an external 1tb drive with 400gb free space. I will let you know what happens.
Regards,
Ed
Old 11th December 2012, 19:55   #2174  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Just saw the 2.6.0 Alpha (December 11, 2012) update on VideoHelp.com
http://www.videohelp.com/tools/AVStoDVD
Going to have fun testing with this and give any feedback in due time.
Looking forward to trying out the new features and new look.
Old 11th December 2012, 20:06   #2175  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@edwood
these 4 files are not created by AVStoDVD... are you sure you are looking at the right folder?
@Sparktank
mate, you are a lightning! Let me know your opinions.
Bye
MrC
AVStoDVD Homepage
Old 12th December 2012, 12:44   #2176  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Release 2.6.0 Alpha 121205 is available to download.
Change log:
- Some bugs fixed
- Added 'FFmpeg (Safe Mode)' to AC3 Audio Encoding profiles in 'Preferences'/'Audio'
- Added 'Adjust Frame Strategy' in 'Preferences'/'AviSynth'
- Added 'DeBlock' AviSynth deblocking filter (by Manao) in 'Title Edit'/'AviSynth'
- Added a time cap (2h) to AC3 audio encoding step (Wavi+Aften profile). Overrun leads to process kill and 'FFmpeg (Safe Mode)' start as backup.
- Added a framerate consistency check vs selected Video Standard to source titles during 'Add Title' routine
- Added audio ON/OFF control to 'Preview Clip' section
- Added ffdshow 1.2.4422.0 32bit to Installer package
- Added GraphStudio 0.3.2.0 beta to NoInstall and Installer packages
- Added 'Codecs' as new element in Main AVStoDVD Menu
- Added 'ffdshow Video Configuration' option from 'Codecs' (Main Menu)
- Added 'ffdshow Audio Configuration' option from 'Codecs' (Main Menu)
- Added 'Build Graph Filter' option from 'Codecs' (Main Menu)
- Moved 'AviSynth FrameServing Check' from 'Title' to 'Codecs' (Main Menu)
- Removed ImgBurn Installer from AVStoDVD Installer Package. There is still a link to ImgBurn webpage.
- Changed 'Adjust ffdshow Mixer Output at runtime' to 'Adjust ffdshow Settings at Runtime' (now including Raw Video and Raw Audio adjustments for Preview Clip section)
- Improved 'Quick StartUp Tutorial' section
- Improved 'Fix SRT' routine for authored subtitles
- Improved log activity (Audio Encoding section)
- Improved GUI graphics (progress bars color change)
- Re-organized AviSynth filters options disposition in 'Title Edit'/'AviSynth'
- FFmpeg updated to build git-8b6aeb1
- FFMpegSource updated to 2.17
- Haali Media Splitter updated to 1.11.96.14
- MKVToolNix updated to 5.8.0
- MediaInfo updated to 0.7.61
Happy testing.
Bye
MrC
AVStoDVD Homepage
Old 12th December 2012, 15:41   #2177  |  Link
manolito
manolito's Avatar
Thanks MrC for the new version, I like the improvements very much. I tested it with two small conversion jobs, no problems so far.
One small thing I noticed was when my source was a VOB file from a DVD (unencrypted) that GraphEdit could not build the graph. No big deal...
Thanks again
Cheers
manolito
Old 12th December 2012, 18:03   #2178  |  Link
edwood
MrC.
Regards,
Ed
The 2nd dvd burn aborted in the BatchMux process. Here is the log file for that process.
BatchMux version --> 1.3
Destination Folder --> F:\Ironside Burned DVD\DVD_0\VIDEO_TS
MuxMan Script File --> C:\Users\EDWOOD~1\AppData\Local\Temp\DVD_0_MuxMan.mxp
MuxMan Log String --> -l "C:\Users\EDWOOD~1\AppData\Local\Temp\DVD_0_MuxMan.log"
Folder of the MuxMan executable --> C:\Program Files\AVStoDVD\MuxMan
Check presence of MuxMan.exe --> PASSED
Palette File --> C:\Users\EDWOOD~1\AppData\Local\Temp\DVD_0_Palette.txt
Default Palette --> SUCCESSFULLY REDEFINED
Segment memory resources --> RELEASED
Local Stack memory --> RELEASED
File i/o structures --> DEALLOCATED
The DVD log file is to long to post.
I think the problem was caused by the external drive going to sleep and the process aborted before the drive came up. I have searched the properties of the external drive and I cannot find any way to prevent the drive from going into sleep mode.
Any suggestions?
Ed
Old 13th December 2012, 12:44   #2179  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@manolito
the VOB is indexed? If not, it should be resolved by directshow. Make sure that ffdshow is setup with libmpeg2 for mpeg1/2 decoding.
@edwood
please post the whole log file. You can attach the file.
Bye
MrC
AVStoDVD Homepage
Old 13th December 2012, 19:33   #2180  |  Link
manolito
manolito's Avatar
This is GraphStudio's fault...
Rendering a 1GB VOB from a DVD simply takes longer than 10 secs, and by default GraphStudio aborts rendering after 10 secs. There is an option in GraphStudio to turn this off, and with this option disabled the VOB is rendered correctly.
Unfortunately GraphStudio does not save this setting, and it also does not support startup parameters, so nothing can be done about it. But as I said, this is no big deal...
Cheers
manolito
[IMG] code is Off
