Go Back   Doom9's Forum > Programming and Hacking > Translations
Old 26th July 2013, 11:49   #361  |  Link
Rule 13 does not apply in the Translations forum.
"13) The official language is English. Outside the translator forum English is the only allowed language."
Old 26th July 2013, 13:39   #362  |  Link
LigH
LigH's Avatar
Aus aktuellem Anlass muss ich alle Anwesenden hier darum bitten, folgendes zu unterlassen:
  • Ständig nachzufragen, ob es mal weitergeht. Außer Michael Gleitz und seinem Hoster kann das niemand sonst wissen. Wenn es wieder läuft, wird es schon einen Hinweis geben.
  • Aus Langeweile Off-Topic zu posten.
  • Meinungen über Personen zu äußern.
New German Gleitz board
Old 29th July 2013, 22:09   #363  |  Link
may24
Board ist wieder da
may24 is offline   Reply With Quote
Old 30th July 2013, 13:38   #364  |  Link
LigH
LigH's Avatar
Ich hab ihn wieder kaputt gemacht ... oder wer war's?!
__
Hat sich gefangen.
__
Oder auch nicht. Immer mal wieder ein HTTP Error 500.
Old 4th August 2013, 19:12   #365  |  Link
Wilbert
The german doom9/Gleitz board is the german speaking community of the doom9 network, so yes, it has...
Michael Gleitz migrated the users of the former German doom9 board when its administrator had to resign.
If this thread was not acceptable, it could have been questioned by moderators since 2005.
It's fine. I see the forum is up again since yesterday. Could you tell me in a few lines what happened? Did the site need more bandwidth then was paid for?
Wilbert is online now   Reply With Quote
Old 4th August 2013, 19:24   #366  |  Link
LigH
LigH's Avatar
What I heard from the admin:
The site is hosted by one of the most famous hosters in Germany. This hoster appears to "overbook" its servers with V-Servers similar to hotels in tourism strongholds, hardly leaving any CPU time for a forum. And how much does a forum need?
A PLESK update takes half an hour. Posting or editing returns a HTTP 500: Internal Server Error. An additional database backup script run by the admin is cancelled due to a timeout.
I wonder if I shall rather not mention the hoster being named "Strato".
Old 5th August 2013, 05:51   #367  |  Link
Chetwood
Chetwood's Avatar
Why not deservedly shame them? The forum is down again, BTW.
MultiMakeMKV: MakeMKV batch processing (Win)
MultiShrink
: DVD Shrink batch processing
Offizieller Übersetzer von DVD Shrink deutsch
Chetwood is offline   Reply With Quote
Old 5th August 2013, 05:59   #368  |  Link
Selur
Selur's Avatar
back online, may be it's using a more restrictive robots.txt, since the amount of robots in the board went down a lot. Or may be they just haven't found the board atm.
Old 5th August 2013, 09:48   #369  |  Link
LigH
LigH's Avatar
The issue is outside the V-Server our board is running in. Imagine our board standing in a japanese subway during rush-hour: It had more air to breathe with less other passengers in the same waggon.
Old 12th August 2013, 09:44   #370  |  Link
Selur
Selur's Avatar
seems like the server is busy again, I end up with a "Internal Server Error" message when trying to connect to the board,.. :/
Old 12th August 2013, 10:09   #371  |  Link
LigH
LigH's Avatar
Happens every once in a while, usually after several postings or edits; each change to the database which involves a log output appears to be delayed extremely. Yesterday I tried to delete a double-post for half an hour.
Old 25th August 2013, 18:42   #372  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
There is definitely a serious problem with the board's consistency.
If you look at this page, you see my post from today at 17:48 under "User-to-User Projekte".
But if you try to read that post, you'll see it isn't actually there! The last post in that thread is from "21. August 2013, 20:42".
I post this issue here, because adding more posts while the database obviously is in a corrupted state probably doesn't make thins better...
Old 25th August 2013, 18:48   #373  |  Link
LigH
LigH's Avatar
I don't understand this problem technically at all; but it seems that changes (posting, deleting, editing, moderating) are postponed, and this postponing provokes "HTTP 500: Internal Server Error" responses for several minutes.
Today I tried to moderate a thread: replying, deleting double and triple posts because the poster did not read the notice that his post has to be released by a moderator, and releasing the latest of these posts; I had to lock this thread to do so because the poster kept posting while I got error responses for moderating activities...
How few percent of the CPU cycles does STRATO assign to our V-Server?!
Old 25th August 2013, 21:30   #374  |  Link
LoRd_MuldeR
Software Developer
I just tried to post again. Interestingly, both posts (the one from 17:48 and the one from just now) appeared. But only until I reloaded the page. Now both are gone...
Well, how much do they guarantee ???
If you pay for a "cheap" hosting plan that has no guarantee minimum resources (or the guarantee minimum resources are extremely low), then you must not be surprised if you only get what you payed for - not more.
Everything that is not guaranteed, should be assumed to not be available.
If, on the other hand, they do not provide the minimum resources they have guaranteed, this should be reported to the support once. Second time, I would request my money back and go to a different hoster...
(Side note: Had a customer who complained our software crashes unexpectedly with SIGTERM. After a lot of debugging, it turned out the problem was not in our software at all. The server would simply kill all processes running for more than a few seconds! Guess what? They had selected a cheap hosting plan intended for simple www hosting only. And then they tried to run their CPU intensive transcoding tasks on that server. What a surprise that it didn't turn out well ^^)
Old 25th August 2013, 21:51   #375  |  Link
LigH
LigH's Avatar
Michael Gleitz is the customer. He will know the details (not me). I am pretty certain that he knew what to expect, and he explained to me already that the issues are most probably a result of overbooking the server like hotels in vacation seasons... And making a backup script timeout by failing to throttle all the other V-Servers running besides the one which runs our server means that the hoster cannot keep promises being part of a contract. So I was told. Well, I hope Michael will reply with first-hand facts.
Old 17th September 2013, 18:16   #376  |  Link
Selur
Selur's Avatar
new server,.. and now:
The website encountered an error while retrieving http://forum.gleitz.info/index.php. It may be down for maintenance or configured incorrectly.
Error code: 500
Old 18th September 2013, 06:54   #377  |  Link
LigH
LigH's Avatar
That was certainly the time when the admin tried to discover the reason of, and fix the issue about, empty edit boxes due to incompatibilities of vBulletin v4 with PHP 5.4, umlauts, and htmpspecialchars() without codepage parameter.
Old 17th September 2014, 16:07   #378  |  Link
LigH
LigH's Avatar
Ja, im Moment ist das Board leider nicht erreichbar ... jemand hat sich darüber beschwert, dass da irgendwo rechtlich geschützter Inhalt veröffentlicht wurde (Bildrechte sind ein heikles Thema), und unser Admin ist leider nicht dazu gekommen, diesen im zugestandenen Zeitraum zu entfernen. So hat ihn die Abschaltung des Servers durch den Hoster heute etwas überrascht. Jetzt muss er sich erst mal darum kümmern, zur Klärung des Versehens den Hoster zu erreichen, während mangels Server seine üblichen Emailadressen nicht verfügbar sind.
Manchmal ist aber auch nicht leicht zu unterscheiden, ob Emails vom Hoster jetzt Werbung oder Ernst sind. Weder für Spamfilter noch für menschliche Leser.
Old 17th September 2014, 16:10   #379  |  Link
Selur
Selur's Avatar
Danke für die Info.
Old 18th September 2014, 05:49   #380  |  Link
Chetwood
Chetwood's Avatar
All kneel to the Urheberrecht. Albern.
MultiShrink
