20th December 2018, 06:04 | #53941 | Link |
I only need FSE for HDR, SDR works very well on my 2080 Ti in fullscreen windowed.
madVR options explained |
20th December 2018, 10:02 | #53943 | Link | |
I have a RTX 2070 and windowed fullscreen works fine for me. I'm using madVR custom refresh rates and just SDR content. |
20th December 2018, 10:12 | #53944 | Link |
Anyone got any performance numbers for 2070 vs 1080/1080Ti for madVR?
Also is there a way to get madVR to output an image beyond the screen resolution? I'd like to use it for upscaling images and saving but I'm limited to a non 4K screen. Last edited by ryrynz; 20th December 2018 at 11:08. |
20th December 2018, 11:19 | #53945 | Link |
Ok so I stand corrected, not everyone with rtx needs FSE. I have tried with the latest drivers as well and am absolutely sure I need it for my setup. I get stuttering even with default madvr settings and matching refresh rates (i just cant tolerate unmatched). Have even tried a full windows reinstall. I am quite sure there are a few other users who have had the same problem and have solved it with FSE.
I dont need FSE for the exact same setup but the 2080 ti swapped out with a 1080. For what its worth, my primary PC: Intel 9900k, asus maximus xi code, 64gb ram, asus strix 2080 ti oc edition, samsung 970 evo, bunch of 10tb hdds. Sony 75" z9d as the primary display for madvr. Not sure what else could be relevant. Last edited by austinminton; 20th December 2018 at 11:23. |
20th December 2018, 12:03 | #53947 | Link |
madVR just renders to the players window size. It would be up to it to just be the size you want it to be, I would think.
20th December 2018, 13:53 | #53948 | Link | |
if you combine it with other tricks you can do quite some resolution. @austinminton don't forget the nvidia power setting there is a problem on windows 10 with windowed mode that can results in a stuttering mess on dual or more monitor setup where the refreshrate doesn't match on all screens(composition rate mismatches) this varies heavily by the used windows version. a way to test it is using overlay rendering which usually ignores such issues similar to FSE. |
20th December 2018, 18:12 | #53949 | Link |
Ah, good point huhn. I am currently running with only one screen attached.
20th December 2018, 18:50 | #53951 | Link | |
20th December 2018, 20:59 | #53952 | Link | |
He's not known to do things concurrently so I think a stable will be out when he's finished this batch of HDR development. Madshi also said to me that the new algo is basically on hold / in development with no ETA, don't hold your breath with that one. Cheers, didn't make the connection between those options and what I wanted. Last edited by ryrynz; 20th December 2018 at 21:04. |
21st December 2018, 01:33 | #53953 | Link | |||
here are the results of my tests on the 2080 ti. I am using default settings with refresh rate matching at 4k: 1) only tv hooked up - Stutter 2) only tv hooked up with overlay enabled - Stutter 3) tv + pc monitor hooked up with overlay enabled, display to tv - Stutter 4) only tv hooked up with FSE - No Stutter 5) tv + monitor hooked up, display to tv with FSE - No stutter The stutter is so obvious that I can instantly tell if FSE is enabled by looking at the video. Here are some other quotes with the same problem, so definitely not just with my setup Quote:
Its obviously not true for every rtx card, but its there for a few atleast. |
21st December 2018, 21:04 | #53957 | Link |
X Cinema Projectionist NZ
Question please...
1. If I set my video card 1080Ti to 24Hz I never get any dropped or repeated frames on ripped BDs, madvr will display "no dropped or repeated frames 4/5 days" 2. If I set the video card to 23.97 I get one repeated frame every 4/5 minutes, never any dropped frames. Is a repeated frame every 4/5 minutes something one sees on the screen or not? I would think a repeated frame is better than a dropped frame... Thoughts on this please guys, is it better to run on 1. or 2.? Personally without looking at the madvr stats I cant tell any differance between either way visually... |
21st December 2018, 23:51 | #53960 | Link |
Dropped frame is a „jump“ in playback, one frame is not presented. You can clearly see that.
Repeated frame is a „pause“ in playback, one frame is repeated and presented twice. You can also see this clearly. Both look terrible to me. Nothing is better here, both are visible. Correct me if I am wrong. |
